Other Parts Discussed in Thread: SN74VMEH22501A
HI, In one of our assemblies, we plan to insert the SN74VMEH22501A as a bus driver. To limit the number of different component types in this assembly, I am planning to use the block even to drive some indicator LEDs, which will operate in pulsed mode. The LED will be driven by the output and therefore we would like to know if the IC limit the current to 100ma,at 25% duty-cycle. Unfortunately, the data sheet does not specify a permissible pulse handling for the block. Would the IC be affected by the reliability when such a pulse is generated to the LED..
