I require i2c timing diagram for TXS02324 DUAL-SUPPLY 2:1 SIM CARD MULTIPLEXER/TRANSLATOR at the moment it's not present at the datasheet from TI. Kindly, anyone post the timing diagram
Hello Lingaraj,\
Have you looked at the TXS02326A data sheet. It has some timing diagrams and should be similar to your application.
http://www.ti.com/lit/ds/symlink/txs02326a.pdf
-Francis Houde
Hello Lingaraj,
If you are looking for a full specification and timing diagram for the I2C then just go ahead and Google it and will pop right up. We follow the I2C bus specifications but we did not actually write them.
http://www.nxp.com/documents/user_manual/UM10204.pdf
-Francis Houde
Hello Lingaraj,
I would like to know what you are trying to do? Are you trying to develop code to produce the I2C signals to interface with something? Have you written code and it isn't working with the TXS02324? If you want, you can contact me and I we can have a phone conference to discuss your specific needs. TI has a variety of material on I2C and a huge selection of parts to help solve your technical problems. I need to know at what stage you are at with your development. If you are using one of our micros then I can send you sample code and even if you aren't using our micro, the code should help you develop yours. I am posts a few links here with additional material about I2C including sample code, guide, etc. Please let me know if you want additional information and we can setup a phone conference.
http://www.ti.com/lit/ug/spruer0d/spruer0d.pdf
http://www.ti.com/lit/ug/spru721c/spru721c.pdf
http://www.ti.com/lit/an/slaa382a/slaa382a.pdf
http://focus.ti.com/pdfs/logic/i2cselguide.pdf
Sincerely,
-Francis Houde
