Hi Expert,
SN75AHC367 is used to as a 3.3V => 5V level shift to control some logic/controller IC on board(Enable and input from other ICs), several output are connected to a connector.
There is a possibilty that SN75AHC367 output 1Y1, 2Y2 and 2Y1 are damaged(shorted to GND) due to unknow reason. We want to add serial resistor at the output to protect it again interference.
Is there a recommend value for serial resistor? What is the maximum resistor we can add, is there a calculation for this resistor?
And the resisor should be as close as possible to device pin?
Thanks a lot.
Zhou
