Hi team,
My customer wants to use TXS0108EZXYR.
But they have some questions:
How the chip can support the open-drain and push-pull? (The open drain and push-pull are decide by the circuit behind?) Can it be used for I2C function? ( I think yes, could you please help explain why the chip can support open-drain and push-pull).
If they use it as the level shift for 3.3v to 1.8v for 27Mhz clock, does it have some problems for clock level shift function?
The chip has internal pull up resistor, if the I/O behind is high resistance state, so the pin is high level here, right?
Thank you.
BR
Frank
