TXB0108 direction seperate for each channel?
Other Parts Discussed in Thread: TXB0108
Hi Team,
Does TXB0108 support different direction for each channel?
For example, 6 channels A => B, 2 channels B => A at same time.
Customer found A to B operation is correct while B to A operation is not correct wihout any pull-up/down resistor.
Thank you.
Jade
  • As shown in section 8.2 of the datasheet, all channels have independent automatic direction sensing.
    Section 8.1 says:
    This device can only translate push-pull CMOS logic outputs. If for open-drain signal translation, please refer to TI TXS010X products.
