Other Parts Discussed in Thread: TXS0108E
Dear Team,
Could you help to answer below questions?
1. TXS0108E internal PU/PD , does it work follow Input status to decide PU or PD on Output side ?
2. If Input signal is floating , what status will be on Output signal ?
3.When OE pin is disable, the A、B channel should be High-Z state ; If we pull high on Output side, is there any leakage current will effect Input signal ?
Thank you
