TXS0102 Open-Drain and Push-Pull
Guru 16770 points
Other Parts Discussed in Thread: TXS0102, TXB0102
Hi
TXS0102 works as ether Open-Drain or Push-Pull device.
Should we care about which type of device is connected to TXS1012?
When does it work as Open-drain device ( or Push-Pull device)?
BestRegards
    The TXS0102 can be used for either open drain or push pull interfaces. If your application is push pull I would recommend the TXB0102 translator instead due to the buffer driven output. We usually recommend TXS devices for open-drain and TXB devices for push pull.
