Other Parts Discussed in Thread: SN74LVC04A, SN74HC04
I have a PICAXE AXE027 FTDI cable and the Serial Data at 9600 BAUD I'm sending through the cable I think needs to be inverted to be compatible with the SpeakJet chip that needs to receive the data.
I am not an electronics engineer so I'm trying to find the simplest solution to invert 9600 BAUD serial data as it flows from the cable to the chip.
The SpeakJet chip can run on 3.3V to 5V no problem. I normally tie the SpeakJet chip to a 3-AA cell battery pack connecting grounds together.
I'm looking for a simple schematic with a part number and if there's a resistor, the value of the resistor.
R2Pv1.com
