Hello Sir
Can u tell me how many analog to digital out put conversions are available in CD4078B.
I'm developing a device that implements 3 separate Hall Effect current sensors ( CR Magnetics part # CR2550 series at max. of 100 amps each. These current sensors function in a magnetic field that varies and fluctuate the 3/11 volts input voltage exciting the doughnut shape coils in which the line insulated conductors passing through the hole in center core of each current sensor. I need a processor to measure differentiating analog measurements and translate the signals to digital format of at least 3 current sensors. Also my project controller has 14 other analog signals that will require conversion to a digital format. so does TI have something to cover this requirement..
Thank You
I'll await your response.
Regard
Edward Helbling
eddie@mastercoolingcorp.com
516-779-0946
