Part Number: SN74LVC1T45
Other Parts Discussed in Thread: SN74LVC1G04
Hi team,
do we have an alternative part to the level translator sn74lvc1t45 which has an inverted output? Same functionality is enough.
Thanks and best regards,
Adrian
Hi team,
Adrian
Adrian,
I have to make some assumptions since there isn't any info provided. I assume you are basically looking for a Inverter that can down translate 3.3V to 1.8 V. If that is correct then the SN74LVC1G04 will be what you want. Not sure if you are wanting the same 148.5 MHz, but it should be able to handle that frequency.
