Part Number: LSF0108
Hi
I get confused about pull up resistor.On Figure at page 17,there is no pull up resistor at Vref_A side.
At the section 9.2.1.2.1, it is mentioned that it does not need the pull up rsistor if the master has the push pull output.
On the other hand,there is no any explain about what is the output type of this device at datasheet.So that, I understand as below.
If the master (unidirection) is the open drain output , the pull up resistor need.
If the master (unidirection) is the push pull output, the pull up resistor does not need.
At the output of this device need the pull up resistor always.
Is my understanding correct?
Koji Hamamoto
