Part Number: LSF0102
Hi team,
customer need a voltage shift for 3.3V to 5V. they want to know how to select pull up resistors of LSF0102. They use 200k pull up resistor for EN pin, and found that the high voltage level of B side is only about 4.3V. how to improve the B side output voltage? can we use low value resistor?
In the datasheet, LSF0102 can be used in open drain and push-pull,so I want to know, what's the output voltage if not add pull up resistors?
what's the inside structure of LS0102. thanks!
