Part Number: TXS0102-Q1
Other Parts Discussed in Thread: TXS0102
Customer is using a GPIO from AMD CPU to control OE pin of TXS0102-Q1. Meanwhile, the same GPIO is also used to control the EN pin of another chip. Can you suggest how to calculate the pull-down resistor value that should be connected to OE pin under such application scenario?
We see"The minimum value of the pulldown resistor to ground is determined by the current-sourcing capability of the driver." in the datasheet, but still not sure how to calculate this.
THanks!
Antony
