Other Parts Discussed in Thread: SN74CB3Q3245
Customer is looking for a bidirectional buffer to support hot plug in IPC buffer, signal frequency 33MHz.
Could you suggest a suitable part?
Thanks a lot.
Oliver Ou
Thanks a lot.
Oliver Ou
From customer's feedback, the spec is: 3.3V VDD, 33Mhz frequency, bi-direction, single end, 8~10 channels.
multi chips are accepted too is no 8~10 channels in one chip.
SN74CD3Q3245 can meet this requirement or not?
Oliver Ou
Strictly speaking, the word "buffer" would imply that the device actively drives its own outputs; the SN74CB3Q3245, however, has passive switches. If the only purpose of the device is to disconnect the bus, then this is no problem.
The SN74CB3Q3245 is OK, as are other analog switches. Also see the Digital Bus Switch Selection Guide (SCDB006).
