SN74AXC8T245: Signal direction time using DIR signal
Part Number: SN74AXC8T245
Hi Team,
How long does it take to change the signal direction of A port and B port using DIR signal?
The A port is 1.2V and the B port is 1.8V.
  • If you believe the abstract diagram in section 8.2 of the datasheet, enabling/disabling of the output drivers due to OE and DIR is handled by the same block. So tswitch-direction should be the maximum of tdis and ten.
