Part Number: LSF0108
Other Parts Discussed in Thread: SN74AVC2T45, SN74AVC4T774, SN74AXC8T245
Hi Sir,
Create a new e2e questions to continue discussion from below e2e link,
And now, my customer can fix the rising time slow issue by using smaller pull up resistor (from 1K to 220 ohm) on LSF0108.
Now they’re considering to change solution to address this issue directly. and they just found AVC4T774 can fix it without external pull up resistor tuning.
So could you please help to check if this is the right solution to use? Thanks
http://www.ti.com/lit/ds/symlink/sn74avc4t774.pdf
In parallel, they also asking for 8 channels solution and below seems proper fit? Please help to check. Thank you
