Part Number: SN74LVC1T45
Other Parts Discussed in Thread: SN74LVC1G17
I am using a SN74LVC1T45 for repeater purposes, after some wire, for a logic 5VDC signal. I am supplying with 5VDC Vcca,Vccb; and also DIR pin. The 5vdc supply signal is the same for all three pins. It could be any issue because of that, in the power sequence or in the turn off? I have read in the data sheet that pin DIR must be supplied with Vcca, but is it bad if it is shared with Vccb?
Thank you in advance for your response.
Carlos López Cernuda
