LSF0108: Application of lsf0108 rks
Part Number: LSF0108
We have used lsf0108 rks of Ti, a 20pin QFN material, to do the voltage conversion of SDIO signal. The SDIO voltage at the main control end is 3.3V, and the SDIO voltage at the module end is 1.8V. At present, SDIO signal recognition is abnormal. We want to confirm whether this IC can support SDIO signal voltage conversion, or whether you have similar use before? Is there any other recommendation if there is any problem?
