Part Number: LSF0102
Other Parts Discussed in Thread: TXS0102, TPS54527, LSF0204
I'm considering using the LSF0102 component, but i worry about the leakage between VCCB(3.3V) to VCCA(1.8).
1. What is the diffrent between LSF0102 VS TXS0102 about the leakage?
2. Does this TXS0102 have more or less leakage between the VCCB(3.3V) to VCCA(1.8V)?
3. in my design i connect the VCCA line to power supply with 50K FB resistor (TPS54527-output=1.8V), if I use the LSF0102 and turn on the VCCB (3.3) what will be the voltage level in the output supply (TPS54527-output=1.8V) when the power supply is off(EN pin of TPS54527= "0")
Attached photos:
