Part Number: LSF0102
I used LSF0102DQER – 2 channels Auto-Bidirectional Multi-Voltage Level Translator for Open-Drain and Push-Pull Applications with DQE package.
We have some problems with the assembly of this component on the PCB.
The PCB manufacturer omit the solder mask between the pads according to note D in page 29 in the data sheet (attached).
According to the assembly factory the lack of solder between the pads cause shorts between the component legs, Because the lack of solder we have to assemble the component in rework machine.
The stencil thickness is 3.5 mils.
We would like to know if TI have experience with soldering this component without solder between the pad? Can TI ensure that it’s possible to solder this component without solder between the pads?
Tank's
Alex Kievsky
