Other Parts Discussed in Thread: SN74AXC1T45
There's no leakage current in datasheet, can you check the value? Thanks!
There is a leakage current in the data sheet, its represented by Ii and is in the Electrical Characteristics table.
SN74AHC1G09 is a different IC form SN74AXC1T45. The output type is also different between two ICs. The leakage current in SN74AXC1T45 datasheet is defined in input leakage. I want to know SN74AHC1G09 open drain output ILKG SPEC while Q1 is off. Thanks!
Hey Weiyu,
I understand what you are looking for now, the output leakage would be +/- 2.5 uA.
