Part Number: TXB0106
Other Parts Discussed in Thread: LSF0108, , SN74AXC4T774
Hi Team,
Good day!
We need your help to check our customer’s concern below:
- We would like to use TI level translator for 3.3V to 1.8V bi-directional translation for SPI bus. Currently we use TXB0106 but we need higher performance. Should LSF0108 product support higher rate transactions?
- I see that TI recommends TXB0106 for SPI interface. However according to its spec, LSF0108 does support push/pull interfaces (like SPI) so if possible I'd be happy to understand better the rationale behind TI recommendation.
Also, in the practical level, if I do switch to LSF, should I expect achieving lower data rate than what I currently get with the TXB (~30MHz)?
Thank you so much in advance.
Kind regards,
Jonathan
