Part Number: TXB0108
Hi. team
My customer wants to use QSPI with 33MHz through TXB0108, Please tell if this is a suitable device.
And he wants to know: 1. how long does it take to detect the direction of the signal/levelshifter
Thank you.
Hi. team
Thank you.
If VCCA is at least 2.5 V, this might be possible. See section 8.3 of the datasheet for restrictions. (Long traces, connectors, cables, or resistors are forbidden.)
The direction is never detected; the TXB inputs and outputs are always active in both directions. A TXB pin switches if some external device drives a voltage with higher drive strength the the TXB's output.
thank you for your answers. he will use 1V8 and 3V3 to shift the signal between those voltage-layers. so this is higher than 2V5 and with very small connection lines. You did not mentioned the time delay between input and output. can you please give an example?
