Part Number: SN74LVC2G74
customer sees a high current on pin clear when changing the voltages clear pin voltage. What is the max current on this pin?
Regards, Holger
Regards, Holger
Hey Holger,
This is listed in the datasheet under the 'Input clamp current'
You'll see this doesn't have a positive clamp diode. Here's some more information as well on the internal clamping in case it helps with their design.
https://e2e.ti.com/support/logic/f/logic-forum/723607/faq-can-the-input-voltage-vi-to-my-logic-device-be-higher-than-the-supply-voltage-vcc
Rami
