digital /analog switch/multiplexer for RS232 signals
Expert 1105 points
Other Parts Discussed in Thread: MAX232
is there an IC in TI portfolio that I can use to digitially control for switching/multiplexing on / off RS232 signals?
In my search, I wasn't able to find one due to negative voltage level requirements for RS232
I have an application where multiple controller modules are connected serially. Each controller acts as a uart forwarder and thus the system can scale up / down without any problems
I am looking for a fail safe mechanism for the case where a controller module fails to function properly due to a problem (MAX232 chip dead) and kills the communication with the rest of the healthy, functioning modules connected to it.
I thought that I can route a bypass track connected to a switch for the RS232 signals and then in case a problem occurs,  the switch can be turned on automatically  to bypass the problematic controller module.
thanks a lot
rifo
