TMS570LS1224: ADC Example not working with TMS570LS1224
Part Number: TMS570LS1224
Other Parts Discussed in Thread: LAUNCHXL2-TMS57012, HALCOGEN
I was running this example https://training.ti.com/hercules-how-tutorial-12bit-adc?cu=1136292 with the launchpad LAUNCHXL2-TMS57012 in halcoGen and CCS software. But, I am getting while run the example code.
Please tell me what I need to change in my halcoGen project and CCS project.
>> Compilation failure
source/subdir_rules.mk:9: recipe for target 'source/sys_main.obj' failed
"../source/sys_main.c", line 89: error #29: expected an expression
"../source/sys_main.c", line 89: error #138: expression must be a modifiable lvalue
"../source/sys_main.c", line 90: error #19: extra text after expected end of number
"../source/sys_main.c", line 90: error #110: expression preceding parentheses of apparent call must have (pointer-to-) function type
4 errors detected in the compilation of "../source/sys_main.c".
gmake: *** [source/sys_main.obj] Error 1
gmake: Target 'all' not remade because of errors.
/** @file sys_main.c
* @brief Application main file
* @date 11-Dec-2018
* @version 04.07.01
* This file contains an empty main function,
* which can be used for the application.
* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
#include "reg_adc.h"
#include "reg_sci.h"
#include "sci.h"
#include "adc.h"
#include "stdlib.h"
/* USER CODE END */
/* Include Files */
#include "sys_common.h"
#include "system.h"
/* USER CODE BEGIN (1) */
unsigned char command[8];
/* USER CODE END */
/** @fn void main(void)
* @brief Application main function
* @note This function is empty by default.
* This function is called after startup.
* The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
/* USER CODE END */
void main(void)
/* USER CODE BEGIN (3) */
adcData_t adc_data;
adcData_t *adc_data_ptr = &adc_data;
unsigned int NumberOfChars, value;
sciInit();
adcInit();
while(1)
adcStartConversion(adcREG1,adcGROUP1);
while(!adcIsConversionComplete(adcREG1,adcGROUP1))
adcGetData(adcREG1, 10, adc_data_ptr);
value = (unsigned int)adc_data_ptr=>value;
NumberOfChars = 1toa(value,(char *)command);
sciSend(scilinREG, 2, (unsigned char*)"0x");
sciSend(scilinREG, NumberOfChars, command);
sciSend(scilinREG, 2, (unsigned char *)"\r\n");
/* USER CODE END */
/* USER CODE BEGIN (4) */
void adcNotification(adcBASE_t *adc, unsigned group)
return;
void sciNotification(sciBASE_t *sci, unsigned flags)
return;
void esmGroup1Notification(int bit)
return;
void esmGroup2Notification(int bit)
return;
/* USER CODE END */
       TMS570.rar
  • adcGetData(adcREG1, 10, adc_data_ptr);
    should be
    adcGetData(adcREG1, adcGROUP1, adc_data_ptr);
  • I had tried changing that statement but still getting these errors Wang.
    >> Compilation failure
  • I have used the following code with the modified statement that you had reccomended me.
    #include "sci.h"
    #include "adc.h"
    #include "stdlib.h"
    /* USER CODE END */
    /* Include Files */
    #include "system.h"
    /* USER CODE END */
    /* USER CODE END */
    void main(void)
    adcData_t adc_data;
    sciInit();
    adcInit();
    while(1)
    /* USER CODE END */
    return;
    return;
    return;
    return;
    /* USER CODE END */
  • change
    to
    value = (unsigned int)adc_data_ptr->value;
    Where is the 1toa() function defined?
  • I have changed that statement and currently getting the following errors Wang.
    I don't know know how to find where the 1toa() is defined. Please tell me how to find that.
    >> Compilation failure
    2 errors detected in the compilation of "../source/sys_main.c".
  • Please let me know how to remove these errors.
  • Hi Sakthi,
    You opened another thread for the same question. I will close this one. Thanks for using e2e forum.
