TMS570LS0714: CANBUS problem in recieving data using example_canCommunication.c
Part Number: TMS570LS0714
Other Parts Discussed in Thread: HALCOGEN
Hi.
I am using TMS570ls07 with example_canCommunication from Halcogen and  Can monitor program with CAN adaptor I am able to send data from TMS570ls07 to and see them on Can monitor program but when I can not recieve data in TMS570 means My tms570 is only working as sender so what is the problem ?
here is my Schematic
here is my halcogen settings
and my code is below
* Copyright (C) 2009-2015 Texas Instruments Incorporated - www.ti.com
*  Redistribution and use in source and binary forms, with or without
*  modification, are permitted provided that the following conditions
*  are met:
*    Redistributions of source code must retain the above copyright
*    Redistributions in binary form must reproduce the above copyright
*    documentation and/or other materials provided with the
*    distribution.
*    Neither the name of Texas Instruments Incorporated nor the names of
*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES INCLUDING, BUT NOT
*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION HOWEVER CAUSED AND ON ANY
*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
*  INCLUDING NEGLIGENCE OR OTHERWISE ARISING IN ANY WAY OUT OF THE USE
*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "sys_common.h"
#include "system.h"
/* USER CODE BEGIN (1) */
#include "can.h"
/* Include ESM header file - types, definitions and function declarations for system driver */
#include "esm.h"
#define  D_SIZE 9
uint8  tx_data[D_SIZE]  = {'H','E','R','C','U','L','E','S','\0'};
uint8  rx_data[D_SIZE] = {0};
uint32 error = 0;
uint32 cancounter = 0;
uint32 checkPackets(uint8 *src_packet,uint8 *dst_packet,uint32 psize);
/* USER CODE END */
/* USER CODE BEGIN (2) */
/* USER CODE END */
void main(void)
/* USER CODE BEGIN (3) */
    /* initialize can 1 and 2   */
    canInit(); /* can1 -> can2 */
    /* transmit on can1 */
    canTransmit(canREG1, canMESSAGE_BOX1, tx_data);
    /* ... run forever */
    while(1){
//        /*... wait until message receive on can2 */
//        while(!canIsRxMessageArrived(canREG1, canMESSAGE_BOX2));
//        canGetData(canREG1, canMESSAGE_BOX2, rx_data);  /* receive on can2  */
        if(canIsRxMessageArrived(canREG1, canMESSAGE_BOX2)){
        cancounter++;
/* USER CODE END */
/* USER CODE BEGIN (4) */
   uint32 err=0;
   uint32 cnt=psize;
   while(cnt--)
     if((*src_packet++) != (*dst_packet++))
        err++;           /*  data error  */
   return (err);
/* USER CODE END */
