MSP432P401R: GPIO output open drain configuration
Part Number: MSP432P401R
I am trying to migrate a software that communicates with a temperature sensor using I2C.
The old software is using a custom driver for I2C communication.
The data line is configured as output open drain. When the data line is released (output = high) the sensor sends data to the microcontroller. the driver does not change the data line configuration to input and reads the data input register. (old part is STM32).
I did not find in the datasheet something that says it's possible to configure a GPIO as output with open drain (except for I2C as data line).
Is it possible to configure a GPIO as output with open drain? and if it is, is there a risk the pin would be damaged if I use it the way mentioned above.
Thank you,
Dhafer.
