TMS570LC4357-EP: Resistance to solvents
Part Number: TMS570LC4357-EP
We are going to use the TMS570LC4357-EP in a New Space application and our customer is asking us about its resistance to solvents, which one is recommended and which one shall not be used.
Thanks in advance.
Best regards.
      First of all, there is no such information (resistance to solvents) documented on the datasheet for this product. Can you please clarify what is "resistance to solvent" and what is the purpose of this and why is your customer using this? I have done some searches on e2e and have not come across any posts relevant. If you have provide more information on questions I just asked, I can check internally. Please also note that today's is US holiday. Response will be delayed.
  • Hello Charles,
    Is there any product recomendation for cleaning the component after soldering (IPA or others)? Our client is asking if they can use VIGON A200 which is a Water-based, alkaline PCB cleaner for defluxing.
    Best regards.
  • Hi Jesus,
      Sorry, I can only answer technical questions related to how MCU works. I have no knowledge and in no position to recommend which cleaning solution is the choice for PCB cleaning. You should check with VIGON for technical support. I can only say I have seen flux remover by MicroCare and Techni-Tool in our lab. But I'm not endorsing any particular product.
