UNIFLASH: Question about how UNIFLASH works
Part Number: UNIFLASH
Other Parts Discussed in Thread: TMS320F28374S
I have two questions about how UNIFLASH works.
We conducted verification at UNIFLASH. As a result, an error occurred.
1. Does the verify check the entire area? Or does it stop at the address where the "error" is found?
2. When writing to Flash with UNIFLASH, it is written for each sector. Is my perception correct?
    It will stop after the first failure is encountered and reported. There may be more mismatches after that but they will not be detected/reported.
    This may vary depending on the type of flash. What device are you referring to?
    ki
  • Hi, Ki
    Thank you for the quick response.
    → Is there a way to check the accuracy of the remaining memory values after the first failure?
    → The device is TMS320F28374S.
    Koki
  • → Is there a way to check the accuracy of the remaining memory values after the first failure?
    One option is to do a memory dump to a binary file to analyze the contents and compare with the expected results.
    Thank you. I will bring this question to the attention of the device exerts
  • Thank you. I will bring this question to the attention of the device exerts
    For 28x, different addresses within the same sector can be written to separately on c28, so a sector doesn’t have to be written to in a single chunk.
