TMS570LS3137: Question about n2het pin_nDIS
Part Number: TMS570LS3137
Hello, when I was using the n2het module, I found that I could not find the pin_nDIS pin, and I did not find the corresponding setting in the pin multiplexing settings of the iomm module. In the function description of the n2het module, I found that pin_nDIS is the same as GIOA[ 5] Shared, but the multiplex description of pin_nDIS is not found in the description part of GIOA[5] of the iomm module, then how does this pin_nDIS use the input signal?
