Part Number: UNIFLASH
I want to know how to save a log (* Error * or * Fail * data) as a text file using the Command line tool.
Can it be set in the command line options ?
Koki
Hi Koki,
Depending on the terminal program you use to run Uniflash, the program should provide a method to capture its content.
It is a general practice in command line tools that the program doesn't typically provide a option to save logs, intead pipe (|) is used.
