Part Number: TM4C129XNCZAD
Other Parts Discussed in Thread: EK-TM4C1294XL
i am using dk-tm4c129x tiva board .
in that i am using on board spi flash memory (MX25L25635F)
i am write two way code in that my buffer size is 105535
1)only flash write
2)only flash read
in that am successfully work sequentially upload but when i am murge both code read or write that in not work properly . in that merge code only 60 bytes read or write properly more than 60 bytes in upload then code is not working.
i want 105535 byte read or write.
in that read_write code is not work.
write_spi
// usb_dev_msc.c - Main routines for the device mass storage class example.
// write_spi
#include <stdbool.h>
#include <stdint.h>
#include "inc/hw_memmap.h"
#include "driverlib/gpio.h"
#include "driverlib/rom.h"
#include "driverlib/rom_map.h"
#include "driverlib/pin_map.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "driverlib/udma.h"
#include "grlib/grlib.h"
#include "usblib/usblib.h"
#include "usblib/device/usbdevice.h"
#include "usblib/device/usbdmsc.h"
#include "utils/ustdlib.h"
#include "fatfs/src/diskio.h"
#include "drivers/frame.h"
#include "drivers/kentec320x240x16_ssd2119.h"
#include "drivers/mx66l51235f.h"
#include "drivers/pinout.h"
#include "usbdspiflash.h"
#include "usb_msc_structs.h"
#define NUM_SSI_DATA 105535
// Graphics context used to show text on the display.
tContext g_sContext;
// A buffer used for updating the read/write counts.
uint8_t g_pcBuffer[NUM_SSI_DATA];
uint8_t Data[NUM_SSI_DATA];
// The system clock frequency in Hz.
uint32_t g_ui32SysClock;
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
_error_(char *pcFilename, uint32_t ui32Line)
#endif
// This is the main loop that runs the application.
int
main(void)
uint32_t ui32Read, ui32Write,ui32Index;
uint32_t ui32PLLRate;
// Run from the PLL at 120 MHz.
g_ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
SYSCTL_OSC_MAIN | SYSCTL_USE_PLL |
SYSCTL_CFG_VCO_480), 120000000);
for(ui32Index=0;ui32Index<NUM_SSI_DATA;ui32Index++)
Data[ui32Index]=ui32Index/5;
g_pcBuffer[ui32Index]=0;
// Configure the device pins.
PinoutSet();
// Initialize the display driver.
Kentec320x240x16_SSD2119Init(g_ui32SysClock);
// Initialize the graphics context.
GrContextInit(&g_sContext, &g_sKentec320x240x16_SSD2119);
// Draw the application frame.
FrameDraw(&g_sContext, "usb-dev-msc");
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_USB0);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOQ);
while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOQ))
GPIOPinTypeGPIOOutput(GPIO_PORTQ_BASE, GPIO_PIN_7);
// Enable the SSI3 used by SPI flash.
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI3);
ROM_SysCtlPeripheralReset(SYSCTL_PERIPH_SSI3);
// Configure and enable uDMA
MX66L51235FInit(g_ui32SysClock);
USBDMSCStorageWrite(0, Data, 0,NUM_SSI_DATA);//write buffer
SysCtlDelay(g_ui32SysClock/10);
while(1)
uint8_t c=!c;
GPIOPinWrite(GPIO_PORTQ_BASE, GPIO_PIN_7,c<<7);
SysCtlDelay(g_ui32SysClock/10000);
//read_spi
#include <stdint.h>
#ifdef DEBUG
void
#endif
int
main(void)
PinoutSet();
USBDMSCStorageRead(0, g_pcBuffer, 0,NUM_SSI_DATA);//read buffer
while(1)
uint8_t c=!c;
}// read_ write_spi
#include <stdint.h>
#ifdef DEBUG
void
#endif
int
main(void)
PinoutSet();
while(1)
uint8_t c=!c;
