Part Number: TMS570LS3137
Other Parts Discussed in Thread: HALCOGEN
I am using the Halcogen tool to generate PWM through HET1 (TMS570LS3137 - HDK board).
The maximum capability of the Halcogen tool is 8 for PWM generation configuration under HET1.
But my application needs more than 8. As per the datasheet, I could see that the TMS570LS3137 has capability of totally 32 input/output signal generations from the HET module.
Is there any possibility to configure for more than 8 PWM outputs via Halcogen?
If not, will I be able to generate more than 8 PWM output signals if I manually alter the HET1 driver related files?
Please provide me some information on this.
Thanks in advance.
