Part Number: TMS570LC4357
We are in the process of releasing an update to our application and as part of the due diligence investigation for compiler issues that have been resolved since the version we are using, I have a question regarding the problem described by CODEGEN-8736 Specifically, our application is still using compiler version ARM_20.2.1.LTS. It should also be noted that we have compiler optimizations disabled.
Our code does indeed have several conditional statements using "bool" values.
However,
1. The report seems to indicate that the problem was found and fixed in ARM_20.2.5.LTS and if true, our application would not be affected. Is this understanding correct?
2. The report also indicates that the fault lies within the optimization process and since we have that set to off, we should also not be affected (in case my understanding of #1 is incorrect). Is this also correct?
Thank you for your help in clarifying this for me.
