I am using TM4C1290NCPDT customized board. External EEPROM(M95040) read/write not working using SSI2 for communication.
MAP_SSIConfigSetExpClk(SSI2_BASE, ui32SysClock, SSI_FRF_MOTO_MODE_0,
SSI_MODE_MASTER, 2000000, 8);
Using Manual Chip select PH0, GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_0, GPIO_PIN_0); will it required to make chipselect high low every 8 bit?
Read always getting 0, I have noticed after read instruction & address clock not generated. What could be the reason.
Here I attached signals for reference.
Kindly help.
Thaniks.
