Part Number: TMS570LS3137
Other Parts Discussed in Thread: HALCOGEN
We are developing products with your company's TMS570LS3137. In a recent software version, the chip reported an ERROR of ESM Group 1 Channel 6 Event.
The lookup manual finds that this means flash ECC has found a single-bit correctable error.
Our application scenario does not allow this error, even if it is correctable.
So, my question has the following three points:
1. What is the cause of this error?
In addition to hardware failures, what software operations can cause Flash ECC errors?
The MPU module of TMS570 can prevent unexpected flash write operations. Since rewriting flash is blocked, why does ecc check fail?
2. How can we track this problem?
3. I don't understand the meaning of bits[2:0] of FCOR_ERR_ADD register in the Technical Reference Manual, and the description of FCOR_ERR_POSbits[7:0]. Can you explain it in detail, for example?
Looking forward to your reply, thank you!
