PRU not detecting 'kick' by ARM on BeagleBone Black Wireless
I am working on a BeagleBone Black Wireless running Debian.  The output of version.sh will be posted at the end of the message.
I am writing in C on both the ARM and PRU0 sides of this solution.
I am using a simple approach of sending the PRU 'keywords' that cause the PRU to perform specific actions.
Such as the keyword 'POST' causes the PRU to run a set of self-test routines and report back through RPMSG.
I can send the initiation keyword to the PRU and it reads and responds correctly and sends data back.
I now need to send a second keyword from the ARM while the PRU is executing in a loop to read sensors and control a process.  The purpose of this is to instruct the PRU to halt what it is doing.
But, it seems that the second time that I send the PRU a keyword while the process is running, the PRU doesn't detect that it has been kicked by the ARM a second time.
The PRU code snippet that accepts the initial command from the ARM is below.
// Check bit 30 of register R31 to see if the ARM has kicked us
		if (__R31 & HOST_INT)
		    FlashPanelLEDs(1, 1, 10,0,0,0,0);
			// Clear the event status
			CT_INTC.SICR_bit.STS_CLR_IDX = FROM_ARM_HOST;
			// Receive all available messages, multiple messages can be sent per kick
			while (pru_rpmsg_receive(&transport, &src, &dst, payload_in, &len) == PRU_RPMSG_SUCCESS)
Inside the loop on the PRU that is running the process, the following code is present.
FYI - the loop is reading three analog channels over and over and running the timer.  It does send three messages back to the ARM which it reads just fine.
// now check for a STOP message from the ARM
		    							__R30 |= PanelRedLED;	// turn yellow LED on to indicate receipt of msg
										// Clear the event status bit
											if (strcmp(payload_in,"HALT----")==0)  // if the payload is the instruction to stop do this
My debugging indicates that
in the second code snippet is never true so the code within the if statement never executes.
Somewhere I think I read that there have been issues with these 'kick' from the ARM to the PRU with remoteproc.
If this is the case, is there a fix or workaround?
Or is there simply a better way to alert the PRU to stop its routine and return to monitoring for commands from the ARM?
I have Version 5.0 of the pru-software-support-package and the manifest file is dated 7/12/2018.  I will gladly supply the specific release if I can get instructions for finding that.
Output of version.sh::
git:/opt/scripts/:[e4e4854ef8ff9ada5c85553376043ee7679167ca]
eeprom:[A335BNLTBWA51824BBWG0173]
model:[TI_AM335x_BeagleBone_Black_Wireless]
dogtag:[BeagleBoard.org Debian Buster IoT Image 2021-02-15]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2019.04-00002-gc9b3922522 (Aug 24 2020 - 16:42:18 -0500)]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2019.04-00002-gc9b3922522]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-19-TI-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0.bb.org-overlays]
UBOOT: Loaded Overlay:[BB-BBBW-WL1835-00A0.bb.org-overlays]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.bb.org-overlays]
kernel:[4.19.94-ti-r64]
nodejs:[v10.23.1]
/boot/uEnv.txt Settings:
uboot_overlay_options:[enable_uboot_overlays=1]
uboot_overlay_options:[disable_uboot_overlay_video=1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[uboot_overlay_pru=AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
uboot_overlay_options:[enable_uboot_cape_universal=1]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20210809.0-0~buster+20210816]
pkg:[bb-customizations]:[1.20210810.1-0~buster+20210810]
pkg:[bb-usb-gadgets]:[1.20200504.0-0~buster+20200504]
pkg:[bb-wl18xx-firmware]:[1.20200813.1-0~buster+20200813]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.5-git20200715.0-0~buster+20200716]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input bluetooth netdev i2c gpio admin spi iio docker tisdk weston-launch xenomai cloud9ide pwm eqep remoteproc]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 7964.140436] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[ 8265.121346] remoteproc remoteproc1: powering up 4a334000.pru
[ 8265.129459] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115008
[ 8265.150971] remoteproc remoteproc1: registered virtio0 (type 7)
[ 8265.150989] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[ 8341.453012] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13172.104288] remoteproc remoteproc1: powering up 4a334000.pru
[13172.104927] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115008
[13172.140871] remoteproc remoteproc1: registered virtio0 (type 7)
[13172.140881] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13261.616423] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13381.591040] remoteproc remoteproc1: powering up 4a334000.pru
[13381.591931] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115036
[13381.618159] remoteproc remoteproc1: registered virtio0 (type 7)
[13381.618170] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13424.825070] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13538.656251] remoteproc remoteproc1: powering up 4a334000.pru
[13538.664587] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115036
[13538.679857] remoteproc remoteproc1: registered virtio0 (type 7)
[13538.679868] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13588.768502] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13702.536641] remoteproc remoteproc1: powering up 4a334000.pru
[13702.537282] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115032
[13702.559485] remoteproc remoteproc1: registered virtio0 (type 7)
[13702.559496] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13956.972165] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13957.305762] remoteproc remoteproc1: powering up 4a334000.pru
[13957.306403] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115032
[13957.329738] remoteproc remoteproc1: registered virtio0 (type 7)
[13957.329749] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13994.017816] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[14092.361140] remoteproc remoteproc1: powering up 4a334000.pru
[14092.361815] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115032
[14092.386065] remoteproc remoteproc1: registered virtio0 (type 7)
[14092.386085] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[14203.088787] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[14209.575296] remoteproc remoteproc1: powering up 4a334000.pru
[14209.575937] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115036
[14209.596797] remoteproc remoteproc1: registered virtio0 (type 7)
[14209.596807] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[15013.912153] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[15020.485616] remoteproc remoteproc1: powering up 4a334000.pru
[15020.486251] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115036
[15020.510781] remoteproc remoteproc1: registered virtio0 (type 7)
[15020.510792] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[15326.586121] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[15333.381832] remoteproc remoteproc1: powering up 4a334000.pru
[15333.386846] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115520
[15333.410956] remoteproc remoteproc1: registered virtio0 (type 7)
[15333.410968] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[15558.817561] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[15559.146563] remoteproc remoteproc1: powering up 4a334000.pru
[15559.147208] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115520
[15559.172278] remoteproc remoteproc1: registered virtio0 (type 7)
[15559.172289] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[15630.012657] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[15636.783742] remoteproc remoteproc1: powering up 4a334000.pru
[15636.788632] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115464
[15636.809275] remoteproc remoteproc1: registered virtio0 (type 7)
[15636.809295] remoteproc remoteproc1: remote processor 4a334000.pru is now up
dmesg | grep pru
[ 7553.869799] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.876830] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.883870] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.890899] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.897930] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.904961] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.911990] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.919020] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.926051] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.933082] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.940113] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.947144] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.954175] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.961206] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.968237] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.975270] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.982302] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.989333] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7553.996365] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.003394] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.010427] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.017458] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.024488] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.031519] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.038550] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.045580] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.052610] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.059642] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.066672] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.073703] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.080733] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.087763] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.094789] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.101819] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.108849] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.115880] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.122910] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.129941] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.136972] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.144004] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.151034] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.158063] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.165094] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.172124] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.179153] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.186183] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.193213] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.200247] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.257814] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.265016] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.272066] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.279118] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.286154] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.293184] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.300215] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.307246] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.314303] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.321338] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.328368] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.335403] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.342429] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.349460] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.356492] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.363524] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.370550] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.377580] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.384639] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.391672] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.398702] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.405733] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.412764] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.419794] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.426823] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.433853] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.440884] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.447914] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.454944] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.461974] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.469009] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.476039] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.483069] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.490099] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.497128] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.504163] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.511193] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.518224] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.525253] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.532283] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.539313] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.546343] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.553374] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.560405] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.567434] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.574465] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.581494] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.588525] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.595555] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.602582] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.609622] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.616653] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.623683] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.630708] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.637739] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.644770] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.651800] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.658825] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.665856] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.672886] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.679916] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.686945] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.693975] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.701006] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.708037] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.715066] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.722096] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.729132] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.736162] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.743193] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.750223] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.757252] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.764284] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.771314] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.778339] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.785375] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.792407] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.799437] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.806468] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.813498] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.820533] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.827563] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.834597] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.841627] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.848658] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.855688] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.862714] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.869745] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.876775] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.883805] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.890831] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.897862] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.904892] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.911922] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.918952] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.925982] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.933012] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.940043] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.947073] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.954104] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.961135] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.968165] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.975195] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.982225] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.989255] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7554.996290] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.003320] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.010350] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.017380] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.024410] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.031440] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.038471] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.045500] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.052531] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.059566] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.066596] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.073627] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.080659] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.087689] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.094719] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.101750] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.108780] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.115810] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.122837] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.129866] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.136896] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.143926] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.150957] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.157987] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.165017] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.172047] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.179082] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.186112] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.193143] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.200173] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.257818] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.264997] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.272047] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.279087] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.286118] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.293169] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.300203] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.307253] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.314286] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.321340] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.328383] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.335413] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.342469] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.349504] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.356536] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.363566] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.370594] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.377625] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.384656] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.391686] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.398713] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.405743] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.412800] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.419840] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.426873] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.433905] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.440936] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.447966] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.454995] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.462025] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.469055] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.476086] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.483115] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.490146] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.497177] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.504213] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.511242] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.518273] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.525303] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.532337] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.539367] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.546399] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.553429] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.560460] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.567491] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.574521] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.581552] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.588582] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.595617] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.602643] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.609674] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.616703] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.623733] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.630760] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.637803] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.644834] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.651884] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.658912] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.665944] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.672974] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.680005] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.687034] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.694065] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.701095] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.708126] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.715156] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.722186] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.729221] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.736252] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.743285] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.750315] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.757345] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.764376] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.771411] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.778436] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.785467] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.792499] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.799529] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.806556] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.813587] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.820618] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.827649] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.834680] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.841712] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.848745] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.855777] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.862806] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.869838] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.876870] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.883900] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.890931] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.897963] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.904994] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.912030] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.919061] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.926090] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.933121] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.940151] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.947186] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.954216] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.961248] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.968278] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.975308] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.982339] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.989369] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7555.996399] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.003430] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.010461] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.017491] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.024521] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.031551] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.038578] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.045609] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.052640] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.059669] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.066696] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.073727] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.080757] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.087791] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.094817] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.101847] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.108914] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.115952] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.122983] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.130014] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.137045] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.144076] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.151105] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.158136] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.165166] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.172196] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.179227] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.186257] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.193288] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.200319] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.257864] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.265075] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.272128] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.279163] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.286196] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.293229] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.300261] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.307292] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.314343] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.321377] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.328420] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.335450] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.342481] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.349512] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.356544] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.363605] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.370635] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.377667] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.384698] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.391728] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.398754] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.405784] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.412815] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.419845] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.426871] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.433901] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.440933] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.447963] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.454993] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.462025] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.469055] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.476085] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.483115] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.490151] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.497184] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.504224] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.511256] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.518287] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.525317] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.532348] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.539381] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.546408] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.553437] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.560467] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.567497] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.574523] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.581553] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.588584] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.595614] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.602645] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.609675] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.616705] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.623735] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.630761] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.637792] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.644821] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.651851] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.658877] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.665907] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.672939] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.679969] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.686999] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.694030] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.701060] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.708091] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.715122] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.722156] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.729187] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.736218] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.743248] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.750291] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.757328] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.764358] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.771389] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.778419] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.785451] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.792482] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.799511] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.806537] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.813567] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.820597] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.827628] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.834653] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.841683] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.848713] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.855742] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.862768] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.869799] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.876830] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.883860] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.890886] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.897916] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.904947] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.911978] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.919007] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.926038] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.933068] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.940099] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.947129] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.954162] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.961193] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.968223] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.975259] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.982284] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.989314] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7556.996343] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.003373] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.010403] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.017437] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.024469] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.031498] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.038529] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.045560] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.052590] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.059620] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.066646] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.073677] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.080707] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.087737] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.094763] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.101792] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.108822] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.115853] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.122879] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.129910] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.136942] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.143972] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.151002] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.158031] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.165061] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.172091] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.179122] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.186155] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.193189] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.200220] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.257858] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.265012] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.272060] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.279092] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.286125] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.293156] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.300187] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.307217] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.314247] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.321296] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.328328] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.335358] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.342388] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.349418] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.356479] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.363511] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.370541] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.377572] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.384602] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.391636] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.398663] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.405694] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.412724] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.419753] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.426779] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.433813] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.440844] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.447874] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.454901] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.461931] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.468960] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.475990] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.483020] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.490050] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.497081] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.504117] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.511149] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.518179] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.525208] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.532238] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.539268] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.546298] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.553328] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.560359] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.567388] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.574418] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.581451] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.588483] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.595513] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.602540] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.609574] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.616604] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.623635] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.630666] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.637697] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.644726] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.651760] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.658786] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.665817] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.672846] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.679877] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.686903] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.693932] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.700963] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.707994] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.715023] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.722054] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.729084] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.736114] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.743143] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.750173] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.757203] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.764233] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.771263] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.778293] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.785324] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.792354] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.799384] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.806414] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.813447] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.820478] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.827512] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.834538] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.841569] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.848599] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.855629] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.862654] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.869688] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.876719] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.883748] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.890775] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.897805] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.904835] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.911864] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.918890] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.925920] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.932950] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.939980] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.947010] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.954040] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.961070] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.968100] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.975129] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.982159] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.989189] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7557.996218] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.003248] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.010278] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.017307] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.024337] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.031367] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.038398] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.045438] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.052468] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.059497] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.066527] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.073556] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.080587] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.087620] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.094646] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.101675] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.108706] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.115735] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.122761] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.129791] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.136821] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.143850] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.150875] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.157905] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.164936] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.171966] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.178995] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.186024] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.193055] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.200085] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.257883] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.265056] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.272124] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.279161] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.286194] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.293229] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.300259] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.307290] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.314333] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.321366] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.328396] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.335427] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.342453] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.349484] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.356515] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.363545] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.370575] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.377605] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.384635] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.391665] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.398695] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.405726] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.412768] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.419800] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.426831] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.433862] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.440893] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.447959] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.454993] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.462024] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.469055] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.476086] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.483115] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.490145] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.497177] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.504212] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.511242] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.518278] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.525308] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.532338] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.539369] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.546399] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.553430] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.560460] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.567489] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.574520] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.581550] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.588580] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.595610] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.602635] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.609666] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.616697] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.623726] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.630752] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.637782] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.644812] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.651842] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.658873] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.665903] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.672934] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.679968] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.686998] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.694028] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.701057] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.708088] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.715118] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.722148] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.729177] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.736213] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.743242] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.750272] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.757303] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.764339] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.771370] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.778401] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.785431] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.792462] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.799492] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.806523] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.813553] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.820583] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.827611] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.834641] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.841670] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.848701] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.855731] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.862758] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.869787] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.876818] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.883848] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.890874] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.897905] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.904939] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.911969] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.919000] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.926031] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.933060] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.940091] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.947121] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.954156] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.961186] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.968216] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.975247] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.982276] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.989307] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7558.996342] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.003370] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.010400] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.017432] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.024462] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.031492] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.038517] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.045547] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.052578] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.059608] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.066638] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.073668] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.080699] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.087729] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.094760] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.101791] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.108820] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.115850] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.122877] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.129910] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.136940] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.143971] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.151000] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.158031] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.165061] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.172096] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.179125] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.186154] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.193184] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.200214] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.207244] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.257886] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.265049] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.272095] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.279131] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.286182] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.293217] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.300250] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.307298] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.314332] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.321363] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.328430] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.335461] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.342493] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.349524] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.356556] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.363586] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.370612] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.377642] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.384673] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.391703] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.398731] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.405762] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.412791] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.419820] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.426852] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.433891] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.440922] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.447953] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.454983] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.462015] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.469046] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.476077] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.483109] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.490139] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.497170] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.504211] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.511241] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.518271] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.525301] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.532332] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.539363] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.546394] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.553429] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.560460] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.567490] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.574520] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.581551] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.588580] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.595611] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.602643] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.609672] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.616703] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.623733] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.630759] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.637788] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.644819] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.651848] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.658875] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.665906] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.672936] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.679966] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.687000] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.694031] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.701061] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.708090] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.715120] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.722154] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.729185] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.736217] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.743246] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.750277] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.757308] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.764339] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.771368] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.778402] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.785432] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.792463] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.799492] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.806518] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.813548] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.820579] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.827609] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.834638] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.841670] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.848701] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.855731] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.862761] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.869791] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.876821] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.883850] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.890877] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.897912] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.904941] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.911972] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.919002] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.926033] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.933059] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.940085] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.947111] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.954136] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.961162] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.968187] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.975213] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.982239] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.989265] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7559.996291] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7560.003317] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7560.010342] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7560.017368] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7560.024393] rpmsg_pru virtio0.rpmsg-pru.-1.30: Message length table is full
[ 7964.140369] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[ 7964.140390] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[ 7964.140436] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[ 8265.121346] remoteproc remoteproc1: powering up 4a334000.pru
[ 8265.129459] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115008
[ 8265.134125] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[ 8265.134145] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[ 8265.147997] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[ 8265.148982] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[ 8265.150989] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[ 8341.452944] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[ 8341.452965] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[ 8341.453012] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13172.104288] remoteproc remoteproc1: powering up 4a334000.pru
[13172.104927] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115008
[13172.117816] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[13172.117838] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[13172.139337] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[13172.140597] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[13172.140881] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13261.616364] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[13261.616384] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[13261.616423] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13381.591040] remoteproc remoteproc1: powering up 4a334000.pru
[13381.591931] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115036
[13381.602755] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[13381.602777] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[13381.613899] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[13381.614976] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[13381.618170] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13424.824999] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[13424.825021] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[13424.825070] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13538.656251] remoteproc remoteproc1: powering up 4a334000.pru
[13538.664587] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115036
[13538.665799] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[13538.665815] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[13538.678465] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[13538.679552] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[13538.679868] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13588.768439] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[13588.768460] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[13588.768502] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13702.536641] remoteproc remoteproc1: powering up 4a334000.pru
[13702.537282] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115032
[13702.544723] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[13702.544743] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[13702.558068] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[13702.559175] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[13702.559496] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13956.972103] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[13956.972125] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[13956.972165] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[13957.305762] remoteproc remoteproc1: powering up 4a334000.pru
[13957.306403] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115032
[13957.316041] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[13957.316054] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[13957.328495] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[13957.329452] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[13957.329749] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[13994.017755] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[13994.017777] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[13994.017816] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[14092.361140] remoteproc remoteproc1: powering up 4a334000.pru
[14092.361815] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115032
[14092.372038] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[14092.372060] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[14092.382417] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[14092.383377] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[14092.386085] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[14203.088702] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[14203.088724] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[14203.088787] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[14209.575296] remoteproc remoteproc1: powering up 4a334000.pru
[14209.575937] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115036
[14209.584045] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[14209.584067] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[14209.595476] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[14209.596493] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[14209.596807] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[15013.912089] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[15013.912109] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[15013.912153] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[15020.485616] remoteproc remoteproc1: powering up 4a334000.pru
[15020.486251] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115036
[15020.494838] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[15020.494860] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[15020.509528] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[15020.510481] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[15020.510792] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[15326.586042] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[15326.586063] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[15326.586121] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[15333.381832] remoteproc remoteproc1: powering up 4a334000.pru
[15333.386846] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115520
[15333.387743] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[15333.387759] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[15333.408593] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[15333.409708] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[15333.410968] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[15558.817493] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[15558.817514] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[15558.817561] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[15559.146563] remoteproc remoteproc1: powering up 4a334000.pru
[15559.147208] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115520
[15559.156585] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[15559.156606] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[15559.168876] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[15559.170551] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[15559.172289] remoteproc remoteproc1: remote processor 4a334000.pru is now up
[15630.012589] pruss 4a300000.pruss: unconfigured system_events[63-0] = 00000000,00030000
[15630.012609] pruss 4a300000.pruss: unconfigured host_intr = 0x00000005
[15630.012657] remoteproc remoteproc1: stopped remote processor 4a334000.pru
[15636.783742] remoteproc remoteproc1: powering up 4a334000.pru
[15636.788632] remoteproc remoteproc1: Booting fw image am335x-pru0-fw, size 115464
[15636.790239] pruss 4a300000.pruss: configured system_events[63-0] = 00000000,00030000
[15636.790256] pruss 4a300000.pruss: configured intr_channels = 0x00000005 host_intr = 0x00000005
[15636.801821] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[15636.802773] rpmsg_pru virtio0.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
[15636.809295] remoteproc remoteproc1: remote processor 4a334000.pru is now up
dmesg | grep pinctrl-single
dmesg | grep gpio-of-helper
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
END
  • Hello Walter,
    There could be something wrong with the logic. Potential things to look at or try:
    Does ARM wait to receive a message back from the PRU before it sends the second RPMsg kick? If not, it is possible that both messages are sent from ARM to PRU before the PRU clears the SICR bit for the first time.
    The PRU is actually reaching the second "if (__R31 & HOST_INT)", right? If the firmware never gets to that spot, it can't poll for an interrupt.
    Start from known good code and work towards the broken code. e.g., does the PRU RPMsg example in your PRU Software Support Package (PSSP) work with multiple messages from ARM? If so, start adjusting that example to be closer to your current code until it breaks.
    Nick
  • Nick,
    Thanks so much for the reply.  I agree that that there could be a logic problem here.  I've had another developer going over the code and they think the logic is ok.  They have also been learning all they can about remoteproc and rpmsg over the last two days.
    To your point, we have within the same ARM code the option to just send a POST type command to the PRU.  The PRU receives that and replies back.  I modified that to essentially establish a couple of back and forth messages.  So, the ARM sends "POST" and the PRU responds with "POST:ACK".  Then the ARM sends another message "POST2" and the PRU responds with "POST2:ACK".  That works fine.
    To debug in the main routine that isn't working, I turn on some LEDs on our test  platform and actually flash them right before the  second "if(__R31 & HOST_INT) line and right after the closing bracket of the if statement.  They flash so it appears for some reason we aren't getting that second interrupt.
    I'm also using the clock/timer and TSC_ADC in this routine.  Could those be interfering somehow?
    Walter
