Other Parts Discussed in Thread: HALCOGEN,
Hello!
I have a dev.kit HERCULES TMS570LS3137HDK debug board.
As part of the training on communication between the microcontroller and the MATLAB environment, I tried to compile the Simulink model with the TI v20.2.4.LTS compiler.
I have generated the library in HALCoGen v04.07.01. I connected all files from HALCoGen to my toolchain.
I managed to build the model, get the output .out file.
I used loadti.bat to load onto the board. I took the configuration file from another project built in Code Composer Studio.
When uploading an executable file to the board, I get two messages:
CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset
After receiving these messages, nothing happens, and the D2 LED on the target blinks.
The loadti program does not terminate and continues to hang.
I attach to the message MATLAB log and loadti log.
### Generating code and artifacts to 'Model specific' folder structure
### Generating code into build folder: C:\Users\User1\Desktop\Study\titargetpacket\demo_toolchain_ti
### Generated code for 'demo_toolchain' is up to date because no structural, parameter or code replacement library changes were found.
### Using toolchain: TI Toolchain
### Creating 'C:\Users\User1\Desktop\Study\titargetpacket\demo_toolchain_ti\demo_toolchain.mk' ...
### Building 'demo_toolchain': "C:\PROGRA~1\POLYSP~1\R2021a\bin\win64\gmake" -f demo_toolchain.mk all
_GNU_ARM_TOOLS_PATH = C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin
C:\Users\User1\Desktop\Study\titargetpacket\demo_toolchain_ti>cd .
C:\Users\User1\Desktop\Study\titargetpacket\demo_toolchain_ti>if "" == "" ("C:\PROGRA~1\POLYSP~1\R2021a\bin\win64\gmake" -f demo_toolchain.mk all ) else ("C:\PROGRA~1\POLYSP~1\R2021a\bin\win64\gmake" -f demo_toolchain.mk )
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="demo_toolchain.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti/demo_toolchain.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="errata_SSWF021_45.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/errata_SSWF021_45.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="esm.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/esm.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="gio.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/gio.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="notification.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/notification.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="pinmux.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/pinmux.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_dma.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_dma.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_main.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_main.c"
"C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_main.c", line 80: warning #112-D: statement is unreachable
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_pcr.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_pcr.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_phantom.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_phantom.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_pmm.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_pmm.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_selftest.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_selftest.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_startup.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_startup.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_vim.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_vim.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="system.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DTID01EQ=0 -DMODEL=demo_toolchain -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -iC:/Users/User1/Desktop/Study/titargetpacket -iC:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti -iC:/PROGRA~1/POLYSP~1/R2021a/extern/include -iC:/PROGRA~1/POLYSP~1/R2021a/simulink/include -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/src/ext_mode/common -iC:/PROGRA~1/POLYSP~1/R2021a/rtw/c/ert "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/system.c"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="dabort.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/dabort.asm"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_core.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_core.asm"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_intvecs.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_intvecs.asm"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_mpu.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_mpu.asm"
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink" --include_path="C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/include" --include_path="C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="sys_pmu.d" --obj_directory="C:/Users/User1/Desktop/Study/titargetpacket/demo_toolchain_ti" "C:/Users/User1/Desktop/Study/TMSProjects/GpioLedBlink/source/sys_pmu.asm"
"### Creating standalone executable "../demo_toolchain.out" ..."
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -Ooff -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi -z -m"demo_toolchain.map" --heap_size=0x800 --stack_size=0x800 -i"C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/lib" -i"C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --reread_libs --diag_wrap=off --display_error_number --warn_sections --xml_link_info="demo_toolchain_linkInfo.xml" --rom_model --be32 "C:/Users/User1/Desktop/Study/titargetpacket/sys_link.cmd" -lrtsv7R4_T_be_v3D16_eabi.lib -o ../demo_toolchain.out demo_toolchain.obj errata_SSWF021_45.obj esm.obj gio.obj notification.obj pinmux.obj sys_dma.obj sys_main.obj sys_pcr.obj sys_phantom.obj sys_pmm.obj sys_selftest.obj sys_startup.obj sys_vim.obj system.obj dabort.obj sys_core.obj sys_intvecs.obj sys_mpu.obj sys_pmu.obj
<Linking>
"### Created: ../demo_toolchain.out"
"### Invoking postbuild tool "Executable Size" ..."
"C:/ti/ccs1031/ccs/tools/compiler/TI-CGT~3.LTS/bin/armsize" ../demo_toolchain.out
text data bss dec hex filename
26140 0 2048 28188 6e1c ../demo_toolchain.out
"### Done invoking postbuild tool."
"### Successfully generated all binary outputs."
C:\Users\User1\Desktop\Study\titargetpacket\demo_toolchain_ti>exit /B 0
***** DSS Generic Loader ***** START: 16:00:43 GMT+0300 (MSK) Configuring Debug Server for specified target... Done TARGET: Texas Instruments XDS100v2 USB Debug Probe Connecting to target... CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0 Resetting target... testEnv.outFiles: C:\Users\Vladislav\Desktop\Work\titargetpacket\demo_toolchain.out Loading C:\Users\Vladislav\Desktop\Work\titargetpacket\demo_toolchain.out CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset
GpioLedBlink is name of my project in HALCoGen.
My loadti command:
"C:\ti\ccs1031\ccs\ccs_base\scripting\examples\loadti\loadti.bat" -a -r --cfg-file="C:\Users\User1\Desktop\Study\TMSProjects\GpioLedBlink\targetConfigs\TMS570LS3137.ccxml" "C:\Users\User1\Desktop\Study\titargetpacket\demo_toolchain.out"
loadti log files:
A working version of downloading the firmware to the microcontroller.
Used file GpioLedBlink.out generated code composer studio.
<?xml version="1.0" encoding="windows-1251" standalone="no"?> <?xml-stylesheet type="text/xsl" href="C:/ti/ccs1031/ccs/ccs_base/scripting/examples/loadti//DefaultStylesheet.xsl"?> <log> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069224</millis> <sequence>6</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceSetFileLevel</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069240</millis> <sequence>7</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message> ***** DSS Generic Loader ***** </message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069240</millis> <sequence>8</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>START: 14:54:29 GMT+0300 (MSK) </message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069240</millis> <sequence>9</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Configuring Debug Server for specified target...</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069240</millis> <sequence>10</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>getServer</method> <thread>1</thread> <message>ENTRY sServerName: DebugServer.1</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069240</millis> <sequence>11</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>getServer</method> <thread>1</thread> <message>Getting definition for: DebugServer.1</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069255</millis> <sequence>12</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>getServer</method> <thread>1</thread> <message>Constructing server</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069255</millis> <sequence>13</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>getServer</method> <thread>1</thread> <message>RETURN com.ti.debug.engine.scripting.DebugServer@2e5c649</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069255</millis> <sequence>14</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>setConfig</method> <thread>1</thread> <message>ENTRY sConfigurationFile: C:\Users\User1\Desktop\Study\TMSProjects\GpioLedBlink\targetConfigs\TMS570LS3137.ccxml</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069255</millis> <sequence>15</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>setConfig</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069255</millis> <sequence>16</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Done</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069255</millis> <sequence>17</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>debuggerOpen</method> <thread>1</thread> <message>ENTRY sBoardName: * sCPUName: *</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069255</millis> <sequence>18</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069255</millis> <sequence>19</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Firing: onServerStarting()</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069255</millis> <sequence>20</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Connecting to XPCOM DebugServer</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069349</millis> <sequence>21</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Initializing DebugServer using specified configuration: "C:\Users\User1\Desktop\Study\TMSProjects\GpioLedBlink\targetConfigs\TMS570LS3137.ccxml"</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069365</millis> <sequence>22</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer$Callback</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>23</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>CPU Name: CortexR4</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>24</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>PartNum: TMS570LS3137</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>25</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Family: 470</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>26</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>SubFamily/MajorISA: d</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>27</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Revision/MinorISA: 0</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>28</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Platform: EMULATOR</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>29</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Processor ID: 1971336192</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>30</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method><init></method> <thread>14</thread> <message>DBName: ArmAdvancedFeatures</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>31</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>CPU Name: IcePick</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>32</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>PartNum: TMS570LS3137</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>33</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Family: 240</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>34</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>SubFamily/MajorISA: 2</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>35</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Revision/MinorISA: 0</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>36</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Platform: NONE</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>37</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Processor ID: 1006635013</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>38</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>CPU Name: Dap</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069646</millis> <sequence>39</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>PartNum: TMS570LS3137</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>40</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Family: 224</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>41</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>SubFamily/MajorISA: 1</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>42</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Revision/MinorISA: 0</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>43</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Platform: NONE</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>44</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Processor ID: 939525125</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>45</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer$Callback</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>46</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Firing: onServerStarted()</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>47</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Searching for devices</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>48</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>49</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>Found debuggable device: Texas Instruments XDS100v2 USB Debug Probe/CortexR4</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>50</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>Found non-debuggable device: Texas Instruments XDS100v2 USB Debug Probe/IcePick</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>51</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>Found non-debuggable device: Texas Instruments XDS100v2 USB Debug Probe/Dap</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>52</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>53</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>54</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>debuggerOpen</method> <thread>1</thread> <message>RETURN Texas Instruments XDS100v2 USB Debug Probe/CortexR4</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>55</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>setString</method> <thread>1</thread> <message>ENTRY ID: FileIODefaultDirectory Value: undefined</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>56</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>setString</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>57</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>TARGET: Texas Instruments XDS100v2 USB Debug Probe</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>58</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Connecting to target...</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>59</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>connect</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>60</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>61</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>Target is not connected</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>62</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>RETURN false</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>63</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>connect</method> <thread>1</thread> <message>Requesting target connect</message> </record> <record> <date>2021-11-12T14:54:29</date> <millis>1636718069662</millis> <sequence>64</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target$OnConnectedListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071108</millis> <sequence>65</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>INFO</level> <class>com.ti.debug.engine.scripting.DebugSession$DebuggerInfoListener</class> <method>onEvent</method> <thread>13</thread> <message>CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>66</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.AbstractListener</class> <method>log</method> <thread>13</thread> <message>Target is now connected</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>67</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target$OnConnectedListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>68</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>69</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>Target is connected</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>70</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>71</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>connect</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>72</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Resetting target...</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>73</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>reset</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>74</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>reset</method> <thread>1</thread> <message>Requesting target reset</message> </record> <record> <date>2021-11-12T14:54:31</date> <millis>1636718071171</millis> <sequence>75</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target$OnResetListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073217</millis> <sequence>76</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target$OnResetListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073217</millis> <sequence>77</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>reset</method> <thread>1</thread> <message>Target reset</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073217</millis> <sequence>78</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>getBoolean</method> <thread>1</thread> <message>ENTRY ID: AutoRunToLabelOnReset</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073217</millis> <sequence>79</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>getBoolean</method> <thread>1</thread> <message>RETURN false</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073217</millis> <sequence>80</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>reset</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073233</millis> <sequence>81</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Loading C:\Users\User1\Desktop\Study\titargetpacket\GpioLedBlink.out</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073233</millis> <sequence>82</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Memory</class> <method>loadProgram</method> <thread>1</thread> <message>ENTRY sFileName: C:\Users\User1\Desktop\Study\titargetpacket\GpioLedBlink.out</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073233</millis> <sequence>83</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Memory</class> <method>load</method> <thread>1</thread> <message>Requesting program load</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073233</millis> <sequence>84</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer$OnCompleteWithErrorInfo</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:33</date> <millis>1636718073358</millis> <sequence>85</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>INFO</level> <class>com.ti.debug.engine.scripting.DebugSession$DebuggerInfoListener</class> <method>onEvent</method> <thread>13</thread> <message>CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset </message> </record> <record> <date>2021-11-12T14:54:51</date> <millis>1636718091705</millis> <sequence>86</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>INFO</level> <class>com.ti.debug.engine.scripting.DebugSession$DebuggerInfoListener</class> <method>onEvent</method> <thread>13</thread> <message>CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset </message> </record> <record> <date>2021-11-12T14:54:51</date> <millis>1636718091971</millis> <sequence>87</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer$OnCompleteWithErrorInfo</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:51</date> <millis>1636718091971</millis> <sequence>88</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Memory</class> <method>load</method> <thread>1</thread> <message>Program load successful</message> </record> <record> <date>2021-11-12T14:54:51</date> <millis>1636718091971</millis> <sequence>89</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>getBoolean</method> <thread>1</thread> <message>ENTRY ID: AutoRunToLabelOnRestart</message> </record> <record> <date>2021-11-12T14:54:51</date> <millis>1636718091971</millis> <sequence>90</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>getBoolean</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T14:54:51</date> <millis>1636718091971</millis> <sequence>91</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer</class> <method>waitForHaltIfPropertySet</method> <thread>1</thread> <message>Waiting for halt</message> </record> <record> <date>2021-11-12T14:54:51</date> <millis>1636718091971</millis> <sequence>92</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer$OnHaltListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092361</millis> <sequence>93</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.AbstractListener</class> <method>log</method> <thread>13</thread> <message>Target has halted at 0x000063EC</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092361</millis> <sequence>94</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer$OnHaltListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092361</millis> <sequence>95</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Memory</class> <method>loadProgram</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092361</millis> <sequence>96</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Done</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092377</millis> <sequence>97</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Target running...</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092377</millis> <sequence>98</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>setScriptTimeout</method> <thread>1</thread> <message>ENTRY nTimeout: -1</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092377</millis> <sequence>99</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>setScriptTimeout</method> <thread>1</thread> <message>Timeout is infinite</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092377</millis> <sequence>100</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>setScriptTimeout</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092377</millis> <sequence>101</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>ENTRY sSymbol: C$$EXIT</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092377</millis> <sequence>102</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>Getting symbol package</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>103</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>Looking-up symbol</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>104</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>Symbol "C$$EXIT" exists</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>105</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>106</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression</class> <method>evaluate</method> <thread>1</thread> <message>ENTRY sExpression: PC == C$$EXIT</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>107</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression</class> <method>eval</method> <thread>1</thread> <message>Requesting evaluation of expression: "PC == C$$EXIT"</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>108</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>109</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>Target is connected</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>110</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>111</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isHalted</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092392</millis> <sequence>112</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isHalted</method> <thread>1</thread> <message>Target is halted</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092408</millis> <sequence>113</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isHalted</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092408</millis> <sequence>114</sequence> <logger>com.ti.debug.engine.scripting.CallStack</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.CallStack$CallStackListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092424</millis> <sequence>115</sequence> <logger>com.ti.debug.engine.scripting.CallStack</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.CallStack$CallStackListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>116</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression$ExprEvalListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>117</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression$ExprEvalListener</class> <method>onEvent</method> <thread>13</thread> <message>Evaluated expression: PC == C$$EXIT</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>118</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression$ExprEvalListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>119</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression</class> <method>evaluate</method> <thread>1</thread> <message>RETURN 0x0</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>120</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>ENTRY sSymbol: C$$EXITE</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>121</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>Getting symbol package</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>122</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>Looking-up symbol</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>123</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>RETURN false</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>124</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>ENTRY sSymbol: abort</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>125</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>Getting symbol package</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>126</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>Looking-up symbol</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>127</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>Symbol "abort" exists</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>128</sequence> <logger>com.ti.debug.engine.scripting.Symbol</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Symbol</class> <method>exists</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>129</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression</class> <method>evaluate</method> <thread>1</thread> <message>ENTRY sExpression: PC == abort</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>130</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression</class> <method>eval</method> <thread>1</thread> <message>Requesting evaluation of expression: "PC == abort"</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>131</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>132</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>Target is connected</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>133</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>134</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isHalted</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>135</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isHalted</method> <thread>1</thread> <message>Target is halted</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>136</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isHalted</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>137</sequence> <logger>com.ti.debug.engine.scripting.CallStack</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.CallStack$CallStackListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>138</sequence> <logger>com.ti.debug.engine.scripting.CallStack</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.CallStack$CallStackListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>139</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression$ExprEvalListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>140</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression$ExprEvalListener</class> <method>onEvent</method> <thread>13</thread> <message>Evaluated expression: PC == abort</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>141</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression$ExprEvalListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>142</sequence> <logger>com.ti.debug.engine.scripting.Expression</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Expression</class> <method>evaluate</method> <thread>1</thread> <message>RETURN 0x0</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>143</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>runAsynch</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>144</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>runAsynch</method> <thread>1</thread> <message>Requesting target run</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>145</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer$OnRunningListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>146</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.AbstractListener</class> <method>log</method> <thread>13</thread> <message>Target is now running</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>147</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer$OnRunningListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>148</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>runAsynch</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>149</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>setScriptTimeout</method> <thread>1</thread> <message>ENTRY nTimeout: -1</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>150</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>setScriptTimeout</method> <thread>1</thread> <message>Timeout is infinite</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>151</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>setScriptTimeout</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>152</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>153</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>1</thread> <message>Firing: onSessionTerminating()</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>154</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>1</thread> <message>Unregistering this session from the DebugServer</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>155</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>1</thread> <message>Firing: onSessionTerminated()</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>156</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>disposeAndUnload</method> <thread>1</thread> <message>Firing: onServerStopping()</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092439</millis> <sequence>157</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>disposeAndUnload</method> <thread>1</thread> <message>Stopping DebugServer</message> </record> <record> <date>2021-11-12T14:54:52</date> <millis>1636718092705</millis> <sequence>158</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer$Callback</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf timeout: infinite</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>159</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>13</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>160</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>13</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>161</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>13</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>162</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>13</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>163</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>13</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>164</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>13</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>165</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer$Callback</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>166</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>disposeAndUnload</method> <thread>1</thread> <message>Firing: onServerStopped()</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>167</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method>terminate</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>168</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>stop</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>169</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>stop</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>170</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message> END: 14:54:53 GMT+0300 (MSK)</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>171</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceEnd</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T14:54:53</date> <millis>1636718093877</millis> <sequence>172</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceEnd</method> <thread>1</thread> <message>Flushing and closing file stream</message> </record> </log>
Not a working version. demo_toolchain.out.
Loadti program log:
<?xml version="1.0" encoding="windows-1251" standalone="no"?> <?xml-stylesheet type="text/xsl" href="C:/ti/ccs1031/ccs/ccs_base/scripting/examples/loadti//DefaultStylesheet.xsl"?> <log> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866671</millis> <sequence>6</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceSetFileLevel</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866686</millis> <sequence>7</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message> ***** DSS Generic Loader ***** </message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866686</millis> <sequence>8</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>START: 15:24:26 GMT+0300 (MSK) </message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866686</millis> <sequence>9</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Configuring Debug Server for specified target...</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866686</millis> <sequence>10</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>getServer</method> <thread>1</thread> <message>ENTRY sServerName: DebugServer.1</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866686</millis> <sequence>11</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>getServer</method> <thread>1</thread> <message>Getting definition for: DebugServer.1</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866686</millis> <sequence>12</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>getServer</method> <thread>1</thread> <message>Constructing server</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866702</millis> <sequence>13</sequence> <logger>com.ti</logger> <level>FINER</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>getServer</method> <thread>1</thread> <message>RETURN com.ti.debug.engine.scripting.DebugServer@2e5c649</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866702</millis> <sequence>14</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>setConfig</method> <thread>1</thread> <message>ENTRY sConfigurationFile: C:\Users\User1\Desktop\Study\TMSProjects\GpioLedBlink\targetConfigs\TMS570LS3137.ccxml</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866702</millis> <sequence>15</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>setConfig</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866702</millis> <sequence>16</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Done</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866702</millis> <sequence>17</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>debuggerOpen</method> <thread>1</thread> <message>ENTRY sBoardName: * sCPUName: *</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866702</millis> <sequence>18</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866702</millis> <sequence>19</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Firing: onServerStarting()</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866702</millis> <sequence>20</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Connecting to XPCOM DebugServer</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866796</millis> <sequence>21</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Initializing DebugServer using specified configuration: "C:\Users\User1\Desktop\Study\TMSProjects\GpioLedBlink\targetConfigs\TMS570LS3137.ccxml"</message> </record> <record> <date>2021-11-12T15:24:26</date> <millis>1636719866796</millis> <sequence>22</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer$Callback</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf timeout: infinite</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867077</millis> <sequence>23</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>CPU Name: CortexR4</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867077</millis> <sequence>24</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>PartNum: TMS570LS3137</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867077</millis> <sequence>25</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Family: 470</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867077</millis> <sequence>26</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>SubFamily/MajorISA: d</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867077</millis> <sequence>27</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Revision/MinorISA: 0</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867077</millis> <sequence>28</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Platform: EMULATOR</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867077</millis> <sequence>29</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Processor ID: 1971336192</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>30</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method><init></method> <thread>14</thread> <message>DBName: ArmAdvancedFeatures</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>31</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>CPU Name: IcePick</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>32</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>PartNum: TMS570LS3137</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>33</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Family: 240</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>34</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>SubFamily/MajorISA: 2</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>35</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Revision/MinorISA: 0</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>36</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Platform: NONE</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>37</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Processor ID: 1006635013</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>38</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>CPU Name: Dap</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>39</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>PartNum: TMS570LS3137</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>40</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Family: 224</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>41</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>SubFamily/MajorISA: 1</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>42</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Revision/MinorISA: 0</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>43</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Platform: NONE</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>44</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugSession</class> <method><init></method> <thread>14</thread> <message>Processor ID: 939525125</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>45</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer$Callback</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN com.ti.ccstudio.scripting.environment.ScriptingEnvironment@6e8dacdf</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>46</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Firing: onServerStarted()</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>47</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>Searching for devices</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>48</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>49</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>Found debuggable device: Texas Instruments XDS100v2 USB Debug Probe/CortexR4</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>50</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>Found non-debuggable device: Texas Instruments XDS100v2 USB Debug Probe/IcePick</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>51</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>Found non-debuggable device: Texas Instruments XDS100v2 USB Debug Probe/Dap</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>52</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>listDevices</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>53</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>start</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>54</sequence> <logger>com.ti.debug.engine.scripting.DebugServer</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.DebugServer</class> <method>debuggerOpen</method> <thread>1</thread> <message>RETURN Texas Instruments XDS100v2 USB Debug Probe/CortexR4</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>55</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>setString</method> <thread>1</thread> <message>ENTRY ID: FileIODefaultDirectory Value: undefined</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>56</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>setString</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>57</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>TARGET: Texas Instruments XDS100v2 USB Debug Probe</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867093</millis> <sequence>58</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Connecting to target...</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867108</millis> <sequence>59</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>connect</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867108</millis> <sequence>60</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867108</millis> <sequence>61</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>Target is not connected</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867108</millis> <sequence>62</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>RETURN false</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867108</millis> <sequence>63</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>connect</method> <thread>1</thread> <message>Requesting target connect</message> </record> <record> <date>2021-11-12T15:24:27</date> <millis>1636719867108</millis> <sequence>64</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target$OnConnectedListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868670</millis> <sequence>65</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>INFO</level> <class>com.ti.debug.engine.scripting.DebugSession$DebuggerInfoListener</class> <method>onEvent</method> <thread>13</thread> <message>CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>66</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.AbstractListener</class> <method>log</method> <thread>13</thread> <message>Target is now connected</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>67</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target$OnConnectedListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>68</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>69</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>Target is connected</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>70</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>isConnected</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>71</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>connect</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>72</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Resetting target...</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>73</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>reset</method> <thread>1</thread> <message>ENTRY</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>74</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>reset</method> <thread>1</thread> <message>Requesting target reset</message> </record> <record> <date>2021-11-12T15:24:28</date> <millis>1636719868733</millis> <sequence>75</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target$OnResetListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870779</millis> <sequence>76</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target$OnResetListener</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870779</millis> <sequence>77</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>reset</method> <thread>1</thread> <message>Target reset</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870779</millis> <sequence>78</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>getBoolean</method> <thread>1</thread> <message>ENTRY ID: AutoRunToLabelOnReset</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870779</millis> <sequence>79</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>getBoolean</method> <thread>1</thread> <message>RETURN false</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870779</millis> <sequence>80</sequence> <logger>com.ti.debug.engine.scripting.Target</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Target</class> <method>reset</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870795</millis> <sequence>81</sequence> <logger>com.ti</logger> <level>INFO</level> <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class> <method>traceWrite</method> <thread>1</thread> <message>Loading C:\Users\User1\Desktop\Study\titargetpacket\demo_toolchain.out</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870795</millis> <sequence>82</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Memory</class> <method>loadProgram</method> <thread>1</thread> <message>ENTRY sFileName: C:\Users\User1\Desktop\Study\titargetpacket\demo_toolchain.out</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870795</millis> <sequence>83</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Memory</class> <method>load</method> <thread>1</thread> <message>Requesting program load</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870795</millis> <sequence>84</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer$OnCompleteWithErrorInfo</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record> <record> <date>2021-11-12T15:24:30</date> <millis>1636719870920</millis> <sequence>85</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>INFO</level> <class>com.ti.debug.engine.scripting.DebugSession$DebuggerInfoListener</class> <method>onEvent</method> <thread>13</thread> <message>CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset </message> </record> <record> <date>2021-11-12T15:24:49</date> <millis>1636719889509</millis> <sequence>86</sequence> <logger>com.ti.debug.engine.scripting.DebugSession</logger> <level>INFO</level> <class>com.ti.debug.engine.scripting.DebugSession$DebuggerInfoListener</class> <method>onEvent</method> <thread>13</thread> <message>CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset </message> </record> <record> <date>2021-11-12T15:24:49</date> <millis>1636719889775</millis> <sequence>87</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer$OnCompleteWithErrorInfo</class> <method>waitUntil</method> <thread>1</thread> <message>RETURN</message> </record> <record> <date>2021-11-12T15:24:49</date> <millis>1636719889775</millis> <sequence>88</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Memory</class> <method>load</method> <thread>1</thread> <message>Program load successful</message> </record> <record> <date>2021-11-12T15:24:49</date> <millis>1636719889775</millis> <sequence>89</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>getBoolean</method> <thread>1</thread> <message>ENTRY ID: AutoRunToLabelOnRestart</message> </record> <record> <date>2021-11-12T15:24:49</date> <millis>1636719889775</millis> <sequence>90</sequence> <logger>com.ti.debug.engine.scripting.Options</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.Options</class> <method>getBoolean</method> <thread>1</thread> <message>RETURN true</message> </record> <record> <date>2021-11-12T15:24:49</date> <millis>1636719889775</millis> <sequence>91</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer</class> <method>waitForHaltIfPropertySet</method> <thread>1</thread> <message>Waiting for halt</message> </record> <record> <date>2021-11-12T15:24:49</date> <millis>1636719889775</millis> <sequence>92</sequence> <logger>com.ti.debug.engine.scripting.Memory</logger> <level>FINER</level> <class>com.ti.debug.engine.scripting.APIContainer$OnHaltListener</class> <method>waitUntil</method> <thread>1</thread> <message>ENTRY timeout: infinite</message> </record>
Thanks!!
