Part Number: TDA3XEVM
Hi team,
Changing MAKEAPPNAME=apps in vision_sdk\build\Rules.make based on PROCESSOR_SDK_RADAR_03_08_00_00; MAKECONFIGF=tda3xx _evm_bios_radar, and compile with the following error:
After removing the compiled file with rm –rf binaries, gmake -s depend can run normally, but running gmake -s always reports an error, the resulting compiled kernel file is not complete, and similar errors often occur.
This compilation is slow, and it can be very time consuming when compile all the way to the end and report an error.
$ gmake -s
E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ipc_PATH does not exist! ()
# Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_algorithm
# Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_algorithm
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_algorithm
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_algorithm
# Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_algorithm
# Compiling tda3xx-evm:ipu1_0:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_dup: dupLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_dup
# Compiling tda3xx-evm:ipu1_1:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_dup: dupLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_dup
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_dup
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_dup
# Compiling tda3xx-evm:arp32_1:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_dup
# Compiling tda3xx-evm:ipu1_0:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_gate: gateLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_gate
# Compiling tda3xx-evm:ipu1_1:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_gate: gateLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_gate
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_gate
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_gate
# Compiling tda3xx-evm:arp32_1:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_gate
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_ipcIn
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_ipcIn
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_ipcIn
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_ipcIn
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_ipcIn
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_ipcOut
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_ipcOut
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_ipcOut
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_ipcOut
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_ipcOut
# Compiling tda3xx-evm:ipu1_0:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_merge
# Compiling tda3xx-evm:ipu1_1:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_merge
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_merge
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_merge
# Compiling tda3xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_merge
# Compiling tda3xx-evm:ipu1_0:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_null
# Compiling tda3xx-evm:ipu1_1:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_null
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_null
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_null
# Compiling tda3xx-evm:arp32_1:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:arp32_1:release:links_common_null
# Compiling tda3xx-evm:ipu1_0:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_network_tx
# Compiling tda3xx-evm:ipu1_1:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_network_tx
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_network_tx
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_network_tx
# Compiling tda3xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:arp32_1:release:links_common_network_tx
# Compiling tda3xx-evm:ipu1_0:release:links_common_network_rx: networkRxLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_network_rx: networkRxLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_network_rx
# Compiling tda3xx-evm:ipu1_1:release:links_common_network_rx: networkRxLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_network_rx: networkRxLink_drv.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_network_rx
# Compiling tda3xx-evm:ipu1_0:release:links_common_nullSrc: nullSrcLink_tsk.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_nullSrc
# Compiling tda3xx-evm:ipu1_1:release:links_common_nullSrc: nullSrcLink_tsk.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_nullSrc
# Compiling tda3xx-evm:ipu1_0:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_select: selectLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_select
# Compiling tda3xx-evm:ipu1_1:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_select: selectLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_select
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_select
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_select
# Compiling tda3xx-evm:arp32_1:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_select
# Compiling tda3xx-evm:ipu1_0:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_sync: syncLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_sync
# Compiling tda3xx-evm:ipu1_1:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_sync: syncLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_sync
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_sync
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_sync
# Compiling tda3xx-evm:arp32_1:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_sync
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_display: displayLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_display: displayLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_display
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_capture
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_drv.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_subframe_drv.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_displaywb_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_vip_capture
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_que.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_l3_emif_bw.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_boot_slaves.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_esm.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_ipu_ecc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_dcc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_execp_trace_local_m4.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_uart.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_cbuf_ocmc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_qspi.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_idle_m4.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_temperature.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_stat_collector.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_prcm_stats.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_emif_ecc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_l3fw.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/sci.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/cToolsHelper.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mcspi.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mem_ipu1_0.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_0.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_taskTimer.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/sci_config_tda3x.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_iss.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: ndk/ndk_nsp_hooks.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: network_api.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: file_api.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: file_api_dma.c
# Archiving tda3xx-evm:ipu1_0:release:utils_common
# Compiling tda3xx-evm:ipu1_1:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_que.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_iss.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_execp_trace_remote_m4.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_1.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_idle_m4.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_stat_collector.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: stat_collector_utils/sci.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: stat_collector_utils/cToolsHelper.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_qspi.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: ndk/ndk_nsp_hooks.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: network_api.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: file_api.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: file_api_dma.c
# Archiving tda3xx-evm:ipu1_1:release:utils_common
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_que.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_execp_trace_dsp.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_cfg_dsp1.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_idle_c66x.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: network_api.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_cache_c66x.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_l3fw.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_xmc_mpu.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_ecc_c66x.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_taskTimer.c
# Archiving tda3xx-evm:c66xdsp_1:release:utils_common
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_que.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_execp_trace_dsp.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_cfg_dsp2.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_idle_c66x.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: network_api.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_cache_c66x.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_l3fw.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_xmc_mpu.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_ecc_c66x.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_taskTimer.c
# Archiving tda3xx-evm:c66xdsp_2:release:utils_common
# Compiling tda3xx-evm:arp32_1:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_que.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_vip_interrupt.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_execp_trace_eve.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: network_api.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_idle_arp32.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_l3fw.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: eveprofiler/utils_eve_profile.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: eveprofiler/sctm.c
# Archiving tda3xx-evm:arp32_1:release:utils_common
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_common.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_system
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_common.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_system
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_common.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_system
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_common.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_system
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_common.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:arp32_1:release:links_common_system
# Compiling tda3xx-evm:c66xdsp_1:release:links_dsp_system: system_c6xdsp.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_dsp_system: systemLink_tsk_c6xdsp.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_dsp_system
# Compiling tda3xx-evm:c66xdsp_2:release:links_dsp_system: system_c6xdsp.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_dsp_system: systemLink_tsk_c6xdsp.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_dsp_system
# Compiling tda3xx-evm:arp32_1:release:links_eve_system: system_eve.c
# Compiling tda3xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve.c
# Compiling tda3xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_eve_system
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: system_bsp_init.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: system_ipu1_0.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: systemLink_tsk_ipu1.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_system
# Compiling tda3xx-evm:ipu1_1:release:links_ipu_system: system_ipu1_1.c
# Compiling tda3xx-evm:ipu1_1:release:links_ipu_system: systemLink_tsk_ipu1.c
# Archiving tda3xx-evm:ipu1_1:release:links_ipu_system
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/radarprocess/radarProcessLink_algPlugin.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarframecopy/radarFrameCopy.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font02.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font00.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: common/alg_ivision.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_capture_only/chains_radarcaptureonly.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_capture_only/chains_radarcaptureonly_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_objectdetect_display/chains_radarobjectdetectdisplay.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_objectdetect_display/chains_radarobjectdetectdisplay_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_objectdetect_null/chains_radarobjectdetectnull.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_objectdetect_null/chains_radarobjectdetectnull_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_capture_process/chains_radarcaptureprocess.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_capture_process/chains_radarcaptureprocess_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radardraw/radarDraw.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radardraw/radarDraw_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarfft2/radarFft2.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarpeakdetect/radarPkDetect.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarbeamform/radarBeamForm.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_main_bios_radar.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_main_bios_settings_radar.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_common.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_radar_main.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_common_radar.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_common_sample_ar12xx_config.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_radar_file_io.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_radar_util_read_params.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_common_ar12xx.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font01.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font03.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font04.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font05.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font06.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font07.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font08.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font09.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font14.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_1.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_small.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_echo.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_rd.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_qspi_wr.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr_proxy.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_sys_reset.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_save.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_device_comm.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_ipc.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/osal/chains_common_osal.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: common/sample.cpp
# Archiving tda3xx-evm:ipu1_0:release:app_alg_plugins
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/radarprocess/radarProcessLink_algPlugin.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarframecopy/radarFrameCopy.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font02.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font00.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: common/alg_ivision.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radardraw/radarDraw.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radardraw/radarDraw_priv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarfft2/radarFft2.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarpeakdetect/radarPkDetect.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarbeamform/radarBeamForm.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: common/sample.cpp
# Archiving tda3xx-evm:c66xdsp_1:release:app_alg_plugins
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: common/sample_vcop_array_add_uns_short_kernel.k
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/radarprocess/radarProcessLink_algPlugin.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarframecopy/radarFrameCopy.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font02.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font00.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: common/alg_ivision.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarfft2/radarFft_work.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarpeakdetect/radarPkDetect_work.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarbeamform/radarBeamForm_work.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: common/sample.cpp
# Archiving tda3xx-evm:arp32_1:release:app_alg_plugins
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/common/chains_main_bios_settings.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/common/chains_main_bios.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_cpu_load.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tidl_od_layout.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/link_stats_monitor/link_stats_monitor.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/devices/lcd.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/devices/hdmi_tx.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/devices/eth_cam.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/devcontrol/devControl_handler.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/usecases/common/chains_common.c
# Archiving tda3xx-evm:ipu1_0:release:app_libs
whoami: unknown option -- g
Try 'whoami --help' for more information.
C:/Users/WANGKU~1/AppData/Local/Temp/2/make25472-1.sh: line 1: findstr: command not found
# Invoking configuro...
processed file: E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\binaries\apps\tda3xx_evm_bios_radar\maketemp_configuro_cmd_arp32_1.bat
E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\links_fw\src\rtos\bios_app_common\tda3xx\eve1>E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/xs xdc.tools.configuro --generationOnly -o E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro -t ti.targets.arp32.elf.ARP32_far -p ti.platforms.evmTDA3XX:EVE_1 -r release -c E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/cg_tools/windows/arp32_1.0.7 -b E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/build/rtos/tda3xx/config_arp32.bld --cfgArgs "{mode: \"\", coreName:\"EVE-1\", platformMem: \"DDR_MEM_128M\"}" MAIN_APP_eve1.cfg
making package.mak (because of package.bld) ...
# !!! Current build platform is [tda3xx-evm] !!!
# !!! Core is [arp32_1] !!!
generating interfaces for package vision_sdk_configuro (because package/package.xdc.inc is older than package.xdc) ...
configuring MAIN_APP_eve1.xearp32F from package/cfg/MAIN_APP_eve1_pearp32F.cfg ...
Loading Eve1.cfg for tda3xx-evm
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
cd E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src
E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/gmake.exe -f E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/makefile.libs GEN_SRC_DIR=E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src
making E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios/sysbios.aearp32F ...
gmake[1]: Entering directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
clearp32F E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/BIOS.c ...
asmearp32F E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/arp32/Hwi_switch_asm.sarp32 ...
asmearp32F E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/arp32/Hwi_disp_always.sarp32 ...
asmearp32F E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/arp32/TaskSupport_asm.sarp32 ...
arearp32F BIOS.obj arp32_Hwi_switch_asm.obj arp32_Hwi_disp_always.obj arp32_TaskSupport_asm.obj ...
gmake[1]: Leaving directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
Build of libraries done.
# Configuro done!
# Making tda3xx-evm:arp32_1:release:vision_sdk_lib...
# Compiling tda3xx-evm:arp32_1:release:vision_sdk: src/main_common_eve1.c
# Compiling tda3xx-evm:arp32_1:release:vision_sdk: src/tlb_config_eve1.c
# Compiling tda3xx-evm:arp32_1:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/main_app/tda3xx/eve1/src/main_eve1.c
# Compiling tda3xx-evm:arp32_1:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/app_init/app_init_eve.c
# Compiling generated MAIN_APP_eve1_pearp32F.oearp32F
# Linking into E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_arp32_1_release.xearp32F...
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda3xx/cfg/link_eve.cmd", line 12: warning:
no matching section
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda3xx/cfg/link_eve.cmd", line 13: warning:
no matching section
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda3xx/cfg/link_eve.cmd", line 18: warning:
no matching section
# E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_arp32_1_release.xearp32F created.
C:/Users/WANGKU~1/AppData/Local/Temp/2/make17268-1.sh: line 1: findstr: command not found
processed file: E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\binaries\apps\tda3xx_evm_bios_radar\maketemp_configuro_cmd_c66xdsp_1.bat
E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\links_fw\src\rtos\bios_app_common\tda3xx\dsp1>E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/xs xdc.tools.configuro --generationOnly -o E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro -t ti.targets.elf.C66 -p ti.platforms.evmTDA3XX:DSP_1 -r release -c E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/cg_tools/windows/ti-cgt-c6000_8.2.4 -b E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/build/rtos/tda3xx/config_c66.bld --cfgArgs "{mode: \"\", coreName:\"DSP-1\", platformMem: \"DDR_MEM_128M\"}" MAIN_APP_c6xdsp1.cfg
# !!! Core is [c66xdsp_1] !!!
configuring MAIN_APP_c6xdsp1.xe66 from package/cfg/MAIN_APP_c6xdsp1_pe66.cfg ...
Loading Dsp1.cfg for tda3xx-evm
warning: ti.sysbios.family.c66.Cache: "E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c66/Cache.xs", line 340: ti.sysbios.family.c66.Cache : Cache settings were changed in user configuration. User configuration options will override platform settings. Check your memory map to make sure that Cache does not conflict with your L1/L2 memory placement. To avoid conflicts between L1/L2 memory and cache, we recommended specifying cache sizes along with memory sizes in a platform package.
cd E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src
E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/gmake.exe -f E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/makefile.libs GEN_SRC_DIR=E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src
making E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios/sysbios.ae66 ...
gmake[1]: Entering directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
cle66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/BIOS.c ...
remark #24038-D: --optimize_with_debug is deprecated and will be removed in a
subsequent release. The behavior is enabled by default.
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/timers/dmtimer/Timer_asm.s64P ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
are66 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj dmtimer_Timer_asm.obj ti_tls_get_tp.obj c62_TaskSupport_asm.obj ...
gmake[1]: Leaving directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
# Configuro done!
# Making tda3xx-evm:c66xdsp_1:release:vision_sdk_lib...
# Compiling tda3xx-evm:c66xdsp_1:release:vision_sdk: src/main_common_c6xdsp1.c
# Compiling tda3xx-evm:c66xdsp_1:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/main_app/tda3xx/dsp1/src/main_c6xdsp1.c
# Compiling tda3xx-evm:c66xdsp_1:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/app_init/app_init_dsp.c
# Compiling generated MAIN_APP_c6xdsp1_pe66.oe66
# Linking into E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_1_release.xe66...
# E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_1_release.xe66 created.
C:/Users/WANGKU~1/AppData/Local/Temp/2/make15448-1.sh: line 1: findstr: command not found
processed file: E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\binaries\apps\tda3xx_evm_bios_radar\maketemp_configuro_cmd_c66xdsp_2.bat
E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\links_fw\src\rtos\bios_app_common\tda3xx\dsp2>E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/xs xdc.tools.configuro --generationOnly -o E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro -t ti.targets.elf.C66 -p ti.platforms.evmTDA3XX:DSP_2 -r release -c E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/cg_tools/windows/ti-cgt-c6000_8.2.4 -b E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/build/rtos/tda3xx/config_c66.bld --cfgArgs "{mode: \"\", coreName:\"DSP-2\", platformMem: \"DDR_MEM_128M\"}" MAIN_APP_c6xdsp2.cfg
# !!! Core is [c66xdsp_2] !!!
configuring MAIN_APP_c6xdsp2.xe66 from package/cfg/MAIN_APP_c6xdsp2_pe66.cfg ...
Loading Dsp2.cfg for tda3xx-evm
cd E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src
E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/gmake.exe -f E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/makefile.libs GEN_SRC_DIR=E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src
making E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios/sysbios.ae66 ...
gmake[1]: Entering directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios'
gmake[1]: Leaving directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios'
# Configuro done!
# Making tda3xx-evm:c66xdsp_2:release:vision_sdk_lib...
# Compiling tda3xx-evm:c66xdsp_2:release:vision_sdk: src/main_common_c6xdsp2.c
# Compiling tda3xx-evm:c66xdsp_2:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/main_app/tda3xx/dsp2/src/main_c6xdsp2.c
# Compiling tda3xx-evm:c66xdsp_2:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/app_init/app_init_dsp.c
# Compiling generated MAIN_APP_c6xdsp2_pe66.oe66
# Linking into E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_2_release.xe66...
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 170: error:
program will not fit into available memory. run placement with alignment
fails for section ".far" size 0x193800 . Available memory ranges:
DSP2_DATA_MEM size: 0x40000 unused: 0x0 max hole: 0x0
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 153: error:
program will not fit into available memory. placement with alignment fails
for section ".text" size 0x48da4 . Available memory ranges:
DSP2_CODE_MEM size: 0x40000 unused: 0x0 max hole: 0x0
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 156: error:
fails for section "GROUP_1" size 0x5c . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 171: error:
for section ".args" size 0x64 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 189: error:
for section ".text:_c_int00" size 0xa0 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 172: error:
fails for section ".cio" size 0x127 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 168: error:
for section ".switch" size 0x155 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 181: error:
for section ".vecs" size 0x200 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 167: error:
fails for section ".fardata" size 0x242ff . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 165: error:
for section ".const" size 0xc0368 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 183: error:
fails for section ".bss:taskStackSection" size 0x122000 . Available memory
ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 162: error:
for section ".cinit" size 0x43c0 . Available memory ranges:
error: errors encountered during linking;
_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_2_release.xe66" not
built
gmake[7]: *** [E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_2_release.xe66] Error 1
gmake[6]: *** [c66xdsp_2] Error 2
gmake[5]: *** [apps_dsp2] Error 2
gmake[4]: *** [apps] Error 2
gmake[3]: *** [apps] Error 2
gmake[2]: *** [apps_exe] Error 2
gmake[1]: *** [apps] Error 2
gmake: *** [vision_sdk] Error 2
Could you help check this case? Thanks.
Cherry
