TMS570LC4357: TMS570LC4357
Part Number: TMS570LC4357
Other Parts Discussed in Thread: HALCOGEN
Hi I am trying to use the GIO functionality for the SCI1, SCI3 and SCI4 modules, I have used Halcogen so configure the port and I am using the below to drive the ports in my code.
gioToggleBit(sciPORT3, PIN_SCI_TX); /* Toggle sciPORT3 "SCI3TX" in GIO Mode. */
gioToggleBit(sciPORT3, PIN_SCI_RX); /* Toggle sciPORT3 "SCI3RX" in GIO Mode. */
I have done the above for all SCI ports used. The TX lines work fine and toggle when asked to but none of the RX pins toggle, this seems constant across all SCI module used.
I have tried an alternative approach and used the enum's in HL_sci.h as indicated below but that does also not work.
gioSetBit(sciPORT4,PIN_SCI_RX, 1U);
wait a period then
gioSetBit(sciPORT4,PIN_SCI_RX, 0U);
below is part of the sciInit that's output from Halcogen for SCI4 as example of how its configured.
/** @b initialize @b SCI4 */
/** - bring SCI4 out of reset */
sciREG4->GCR0 = 0U;
sciREG4->GCR0 = 1U;
/** - Disable all interrupts */
sciREG4->CLEARINT = 0xFFFFFFFFU;
sciREG4->CLEARINTLVL = 0xFFFFFFFFU;
/** - global control 1 */
sciREG4->GCR1 = (uint32)((uint32)1U << 25U) /* enable transmit */
| (uint32)((uint32)1U << 24U) /* enable receive */
| (uint32)((uint32)1U << 5U) /* internal clock (device has no clock pin) */
| (uint32)((uint32)(2U-1U) << 4U) /* number of stop bits */
| (uint32)((uint32)0U << 3U) /* even parity, otherwise odd */
| (uint32)((uint32)0U << 2U) /* enable parity */
| (uint32)((uint32)1U << 1U); /* asynchronous timing mode */
/** - set baudrate */
sciREG4->BRS = 487U; /* baudrate */
/** - transmission length */
sciREG4->FORMAT = 8U - 1U; /* length */
/** - set SCI4 pins functional mode */
sciREG4->PIO0 = (uint32)((uint32)0U << 2U) /* tx pin */
| (uint32)((uint32)0U << 1U); /* rx pin */
/** - set SCI4 pins default output value */
sciREG4->PIO3 = (uint32)((uint32)0U << 2U) /* tx pin */
/** - set SCI4 pins output direction */
sciREG4->PIO1 = (uint32)((uint32)1U << 2U) /* tx pin */
| (uint32)((uint32)1U << 1U); /* rx pin */
/** - set SCI4 pins open drain enable */
sciREG4->PIO6 = (uint32)((uint32)0U << 2U) /* tx pin */
/** - set SCI4 pins pullup/pulldown enable */
sciREG4->PIO7 = (uint32)((uint32)0U << 2U) /* tx pin */
/** - set SCI4 pins pullup/pulldown select */
sciREG4->PIO8 = (uint32)((uint32)1U << 2U) /* tx pin */
/** - set interrupt level */
sciREG4->SETINTLVL = (uint32)((uint32)0U << 26U) /* Framing error */
| (uint32)((uint32)0U << 25U) /* Overrun error */
| (uint32)((uint32)0U << 24U) /* Parity error */
| (uint32)((uint32)0U << 9U) /* Receive */
| (uint32)((uint32)0U << 8U) /* Transmit */
| (uint32)((uint32)0U << 1U) /* Wakeup */
| (uint32)((uint32)0U << 0U); /* Break detect */
/** - set interrupt enable */
sciREG4->SETINT = (uint32)((uint32)0U << 26U) /* Framing error */
/** - initialize global transfer variables */
g_sciTransfer_t[3U].mode = (uint32)0U << 8U;
g_sciTransfer_t[3U].tx_length = 0U;
g_sciTransfer_t[3U].rx_length = 0U;
/** - Finaly start SCI4 */
sciREG4->GCR1 |= 0x80U;
  • Hi Andrew,
    Is the pinmux configured correctly?
  • Hi I have added the pinmux code, but I believe its correct and selected correctly in halcogen.
    /** @file HL_pinmux.h
    *   @brief PINMUX Driver Implementation File
    *   @date 11-Dec-2018
    *   @version 04.07.01
    * Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
    *  Redistribution and use in source and binary forms, with or without
    *  modification, are permitted provided that the following conditions
    *  are met:
    *    Redistributions of source code must retain the above copyright
    *    Redistributions in binary form must reproduce the above copyright
    *    documentation and/or other materials provided with the
    *    distribution.
    *    Neither the name of Texas Instruments Incorporated nor the names of
    *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #ifndef __PINMUX_H__
    #define __PINMUX_H__
    #include "HL_reg_pinmux.h"
    #ifdef __cplusplus
    extern "C" {
    #endif
    /* USER CODE BEGIN (0) */
    /* USER CODE END */
    #define PINMUX_BALL_N19_SHIFT    0U
    #define PINMUX_BALL_D4_SHIFT    8U
    #define PINMUX_BALL_D5_SHIFT    16U
    #define PINMUX_BALL_C4_SHIFT    24U
    #define PINMUX_BALL_C5_SHIFT    0U
    #define PINMUX_BALL_C6_SHIFT    8U
    #define PINMUX_BALL_C7_SHIFT    16U
    #define PINMUX_BALL_C8_SHIFT    24U
    #define PINMUX_BALL_C9_SHIFT    0U
    #define PINMUX_BALL_C10_SHIFT    8U
    #define PINMUX_BALL_C11_SHIFT    16U
    #define PINMUX_BALL_C12_SHIFT    24U
    #define PINMUX_BALL_C13_SHIFT    0U
    #define PINMUX_BALL_D14_SHIFT    8U
    #define PINMUX_BALL_C14_SHIFT    16U
    #define PINMUX_BALL_D15_SHIFT    24U
    #define PINMUX_BALL_C15_SHIFT    0U
    #define PINMUX_BALL_C16_SHIFT    8U
    #define PINMUX_BALL_C17_SHIFT    16U
    #define PINMUX_BALL_D16_SHIFT    24U
    #define PINMUX_BALL_K3_SHIFT    0U
    #define PINMUX_BALL_R4_SHIFT    8U
    #define PINMUX_BALL_N17_SHIFT    16U
    #define PINMUX_BALL_L17_SHIFT    24U
    #define PINMUX_BALL_K17_SHIFT    0U
    #define PINMUX_BALL_M17_SHIFT    8U
    #define PINMUX_BALL_R3_SHIFT    16U
    #define PINMUX_BALL_P3_SHIFT    24U
    #define PINMUX_BALL_D17_SHIFT    0U
    #define PINMUX_BALL_E9_SHIFT    8U
    #define PINMUX_BALL_E8_SHIFT    16U
    #define PINMUX_BALL_E7_SHIFT    24U
    #define PINMUX_BALL_E6_SHIFT    0U
    #define PINMUX_BALL_E13_SHIFT    8U
    #define PINMUX_BALL_E12_SHIFT    16U
    #define PINMUX_BALL_E11_SHIFT    24U
    #define PINMUX_BALL_E10_SHIFT    0U
    #define PINMUX_BALL_K15_SHIFT    8U
    #define PINMUX_BALL_L15_SHIFT    16U
    #define PINMUX_BALL_M15_SHIFT    24U
    #define PINMUX_BALL_N15_SHIFT    0U
    #define PINMUX_BALL_E5_SHIFT    8U
    #define PINMUX_BALL_F5_SHIFT    16U
    #define PINMUX_BALL_G5_SHIFT    24U
    #define PINMUX_BALL_K5_SHIFT    0U
    #define PINMUX_BALL_L5_SHIFT    8U
    #define PINMUX_BALL_M5_SHIFT    16U
    #define PINMUX_BALL_N5_SHIFT    24U
    #define PINMUX_BALL_P5_SHIFT    0U
    #define PINMUX_BALL_R5_SHIFT    8U
    #define PINMUX_BALL_R6_SHIFT    16U
    #define PINMUX_BALL_R7_SHIFT    24U
    #define PINMUX_BALL_R8_SHIFT    0U
    #define PINMUX_BALL_R9_SHIFT    8U
    #define PINMUX_BALL_R10_SHIFT    16U
    #define PINMUX_BALL_R11_SHIFT    24U
    #define PINMUX_BALL_B15_SHIFT    0U
    #define PINMUX_BALL_B8_SHIFT    8U
    #define PINMUX_BALL_B16_SHIFT    16U
    #define PINMUX_BALL_B9_SHIFT    24U
    #define PINMUX_BALL_C1_SHIFT    0U
    #define PINMUX_BALL_E1_SHIFT    8U
    #define PINMUX_BALL_B5_SHIFT    16U
    #define PINMUX_BALL_H3_SHIFT    24U
    #define PINMUX_BALL_M1_SHIFT    0U
    #define PINMUX_BALL_F2_SHIFT    8U
    #define PINMUX_BALL_W10_SHIFT    16U
    #define PINMUX_BALL_J2_SHIFT    24U
    #define PINMUX_BALL_F1_SHIFT    0U
    #define PINMUX_BALL_R2_SHIFT    8U
    #define PINMUX_BALL_F3_SHIFT    16U
    #define PINMUX_BALL_G3_SHIFT    24U
    #define PINMUX_BALL_J3_SHIFT    0U
    #define PINMUX_BALL_G19_SHIFT    8U
    #define PINMUX_BALL_V9_SHIFT    16U
    #define PINMUX_BALL_V10_SHIFT    24U
    #define PINMUX_BALL_V5_SHIFT    0U
    #define PINMUX_BALL_B2_SHIFT    8U
    #define PINMUX_BALL_C3_SHIFT    16U
    #define PINMUX_BALL_W9_SHIFT    24U
    #define PINMUX_BALL_W8_SHIFT    0U
    #define PINMUX_BALL_V8_SHIFT    8U
    #define PINMUX_BALL_H19_SHIFT    16U
    #define PINMUX_BALL_E19_SHIFT    24U
    #define PINMUX_BALL_B6_SHIFT    0U
    #define PINMUX_BALL_W6_SHIFT    8U
    #define PINMUX_BALL_T12_SHIFT    16U
    #define PINMUX_BALL_H18_SHIFT    24U
    #define PINMUX_BALL_J19_SHIFT    0U
    #define PINMUX_BALL_E16_SHIFT    8U
    #define PINMUX_BALL_H17_SHIFT    16U
    #define PINMUX_BALL_G17_SHIFT    24U
    #define PINMUX_BALL_J18_SHIFT    0U
    #define PINMUX_BALL_E17_SHIFT    8U
    #define PINMUX_BALL_H16_SHIFT    16U
    #define PINMUX_BALL_G16_SHIFT    24U
    #define PINMUX_BALL_K18_SHIFT    0U
    #define PINMUX_BALL_V2_SHIFT    8U
    #define PINMUX_BALL_W5_SHIFT    16U
    #define PINMUX_BALL_U1_SHIFT    24U
    #define PINMUX_BALL_B12_SHIFT    0U
    #define PINMUX_BALL_V6_SHIFT    8U
    #define PINMUX_BALL_W3_SHIFT    16U
    #define PINMUX_BALL_T1_SHIFT    24U
    #define PINMUX_BALL_E18_SHIFT    0U
    #define PINMUX_BALL_V7_SHIFT    8U
    #define PINMUX_BALL_D19_SHIFT    16U
    #define PINMUX_BALL_E3_SHIFT    24U
    #define PINMUX_BALL_B4_SHIFT    0U
    #define PINMUX_BALL_N2_SHIFT    8U
    #define PINMUX_BALL_N1_SHIFT    16U
    #define PINMUX_BALL_A4_SHIFT    24U
    #define PINMUX_BALL_A13_SHIFT    0U
    #define PINMUX_BALL_J1_SHIFT    8U
    #define PINMUX_BALL_B13_SHIFT    16U
    #define PINMUX_BALL_P2_SHIFT    24U
    #define PINMUX_BALL_H4_SHIFT    0U
    #define PINMUX_BALL_B3_SHIFT    8U
    #define PINMUX_BALL_J4_SHIFT    16U
    #define PINMUX_BALL_P1_SHIFT    24U
    #define PINMUX_BALL_A14_SHIFT    0U
    #define PINMUX_BALL_K19_SHIFT    8U
    #define PINMUX_BALL_B11_SHIFT    16U
    #define PINMUX_BALL_D8_SHIFT    24U
    #define PINMUX_BALL_D7_SHIFT    0U
    #define PINMUX_BALL_D3_SHIFT    8U
    #define PINMUX_BALL_D2_SHIFT    16U
    #define PINMUX_BALL_D1_SHIFT    24U
    #define PINMUX_BALL_P4_SHIFT    0U
    #define PINMUX_BALL_T5_SHIFT    8U
    #define PINMUX_BALL_T4_SHIFT    16U
    #define PINMUX_BALL_U7_SHIFT    24U
    #define PINMUX_BALL_E2_SHIFT    0U
    #define PINMUX_BALL_N3_SHIFT    8U
    #define PINMUX_GATE_EMIF_CLK_SHIFT              0U
    #define PINMUX_EMIF_OUTPUT_ENABLE_SHIFT			8U
    #define PINMUX_GIOA_DISABLE_HET1_SHIFT          8U
    #define PINMUX_GIOB_DISABLE_HET2_SHIFT          0U
    #define PINMUX_ALT_ADC_TRIGGER_SHIFT            0U
    #define PINMUX_ETHERNET_SHIFT                   24U
    #define PINMUX_ETPWM1_SHIFT                      0U
    #define PINMUX_ETPWM2_SHIFT                      8U
    #define PINMUX_ETPWM3_SHIFT                      16U
    #define PINMUX_ETPWM4_SHIFT                      24U
    #define PINMUX_ETPWM5_SHIFT                      0U
    #define PINMUX_ETPWM6_SHIFT                      8U
    #define PINMUX_ETPWM7_SHIFT                      16U
    #define PINMUX_ETPWM_TIME_BASE_SYNC_SHIFT        24U
    #define PINMUX_ETPWM_TBCLK_SYNC_SHIFT            0U
    #define PINMUX_TZ1_SHIFT                        16U
    #define PINMUX_TZ2_SHIFT                        24U
    #define PINMUX_TZ3_SHIFT                        0U
    #define PINMUX_EPWM1SYNCI_SHIFT                 8U
    #define PINMUX_ETPWM_SOC1A_SHIFT                0U
    #define PINMUX_ETPWM_SOC2A_SHIFT                8U
    #define PINMUX_ETPWM_SOC3A_SHIFT                16U
    #define PINMUX_ETPWM_SOC4A_SHIFT                24U
    #define PINMUX_ETPWM_SOC5A_SHIFT                0U
    #define PINMUX_ETPWM_SOC6A_SHIFT                8U
    #define PINMUX_ETPWM_SOC7A_SHIFT                16U
    #define PINMUX_EQEP1A_FILTER_SHIFT              16U
    #define PINMUX_EQEP1B_FILTER_SHIFT              24U
    #define PINMUX_EQEP1I_FILTER_SHIFT              0U
    #define PINMUX_EQEP1S_FILTER_SHIFT              8U
    #define PINMUX_EQEP2A_FILTER_SHIFT              16U
    #define PINMUX_EQEP2B_FILTER_SHIFT              24U
    #define PINMUX_EQEP2I_FILTER_SHIFT              0U
    #define PINMUX_EQEP2S_FILTER_SHIFT              8U
    #define PINMUX_ECAP1_FILTER_SHIFT              0U
    #define PINMUX_ECAP2_FILTER_SHIFT              8U
    #define PINMUX_ECAP3_FILTER_SHIFT              16U
    #define PINMUX_ECAP4_FILTER_SHIFT              24U
    #define PINMUX_ECAP5_FILTER_SHIFT              0U
    #define PINMUX_ECAP6_FILTER_SHIFT              8U
    #define PINMUX_GIOA0_DMA_SHIFT             	   0U
    #define PINMUX_GIOA1_DMA_SHIFT             	   8U
    #define PINMUX_GIOA2_DMA_SHIFT             	   16U
    #define PINMUX_GIOA3_DMA_SHIFT             	   24U
    #define PINMUX_GIOA4_DMA_SHIFT             	   0U
    #define PINMUX_GIOA5_DMA_SHIFT             	   8U
    #define PINMUX_GIOA6_DMA_SHIFT             	   16U
    #define PINMUX_GIOA7_DMA_SHIFT             	   24U
    #define PINMUX_GIOB0_DMA_SHIFT             	   0U
    #define PINMUX_GIOB1_DMA_SHIFT             	   8U
    #define PINMUX_GIOB2_DMA_SHIFT             	   16U
    #define PINMUX_GIOB3_DMA_SHIFT             	   24U
    #define PINMUX_GIOB4_DMA_SHIFT             	   0U
    #define PINMUX_GIOB5_DMA_SHIFT             	   8U
    #define PINMUX_GIOB6_DMA_SHIFT             	   16U
    #define PINMUX_GIOB7_DMA_SHIFT             	   24U
    #define PINMUX_TEMP1_ENABLE_SHIFT              16U
    #define PINMUX_TEMP2_ENABLE_SHIFT              24U
    #define PINMUX_TEMP3_ENABLE_SHIFT              0U
    #define PINMUX_BALL_N19_MASK             (~(uint32)((uint32)uint32)((uint32)0xFFU << PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_D4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D4_SHIFT))
    #define PINMUX_BALL_D5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D5_SHIFT))
    #define PINMUX_BALL_C4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C4_SHIFT))
    #define PINMUX_BALL_C5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C5_SHIFT))
    #define PINMUX_BALL_C6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C6_SHIFT))
    #define PINMUX_BALL_C7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C7_SHIFT))
    #define PINMUX_BALL_C8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C8_SHIFT))
    #define PINMUX_BALL_C9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C9_SHIFT))
    #define PINMUX_BALL_C10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C10_SHIFT))
    #define PINMUX_BALL_C11_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C11_SHIFT))
    #define PINMUX_BALL_C12_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C12_SHIFT))
    #define PINMUX_BALL_C13_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C13_SHIFT))
    #define PINMUX_BALL_D14_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D14_SHIFT))
    #define PINMUX_BALL_C14_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C14_SHIFT))
    #define PINMUX_BALL_D15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D15_SHIFT))
    #define PINMUX_BALL_C15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C15_SHIFT))
    #define PINMUX_BALL_C16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C16_SHIFT))
    #define PINMUX_BALL_C17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C17_SHIFT))
    #define PINMUX_BALL_D16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D16_SHIFT))
    #define PINMUX_BALL_K3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K3_SHIFT))
    #define PINMUX_BALL_R4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R4_SHIFT))
    #define PINMUX_BALL_N17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N17_SHIFT))
    #define PINMUX_BALL_L17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_L17_SHIFT))
    #define PINMUX_BALL_K17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K17_SHIFT))
    #define PINMUX_BALL_M17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_M17_SHIFT))
    #define PINMUX_BALL_R3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R3_SHIFT))
    #define PINMUX_BALL_P3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P3_SHIFT))
    #define PINMUX_BALL_D17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D17_SHIFT))
    #define PINMUX_BALL_E9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E9_SHIFT))
    #define PINMUX_BALL_E8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E8_SHIFT))
    #define PINMUX_BALL_E7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E7_SHIFT))
    #define PINMUX_BALL_E6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E6_SHIFT))
    #define PINMUX_BALL_E13_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E13_SHIFT))
    #define PINMUX_BALL_E12_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E12_SHIFT))
    #define PINMUX_BALL_E11_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E11_SHIFT))
    #define PINMUX_BALL_E10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E10_SHIFT))
    #define PINMUX_BALL_K15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K15_SHIFT))
    #define PINMUX_BALL_L15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_L15_SHIFT))
    #define PINMUX_BALL_M15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_M15_SHIFT))
    #define PINMUX_BALL_N15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N15_SHIFT))
    #define PINMUX_BALL_E5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E5_SHIFT))
    #define PINMUX_BALL_F5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_F5_SHIFT))
    #define PINMUX_BALL_G5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G5_SHIFT))
    #define PINMUX_BALL_K5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K5_SHIFT))
    #define PINMUX_BALL_L5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_M5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_N5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N5_SHIFT))
    #define PINMUX_BALL_P5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P5_SHIFT))
    #define PINMUX_BALL_R5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R9_SHIFT))
    #define PINMUX_BALL_R10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R10_SHIFT))
    #define PINMUX_BALL_R11_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R11_SHIFT))
    #define PINMUX_BALL_B15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B15_SHIFT))
    #define PINMUX_BALL_B8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B8_SHIFT))
    #define PINMUX_BALL_B16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B16_SHIFT))
    #define PINMUX_BALL_B9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B9_SHIFT))
    #define PINMUX_BALL_C1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C1_SHIFT))
    #define PINMUX_BALL_E1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E1_SHIFT))
    #define PINMUX_BALL_B5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B5_SHIFT))
    #define PINMUX_BALL_H3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H3_SHIFT))
    #define PINMUX_BALL_M1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_M1_SHIFT))
    #define PINMUX_BALL_F2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_F2_SHIFT))
    #define PINMUX_BALL_W10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W10_SHIFT))
    #define PINMUX_BALL_J2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J2_SHIFT))
    #define PINMUX_BALL_F1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_F1_SHIFT))
    #define PINMUX_BALL_R2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_F3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_G3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G3_SHIFT))
    #define PINMUX_BALL_J3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J3_SHIFT))
    #define PINMUX_BALL_G19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_V9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V9_SHIFT))
    #define PINMUX_BALL_V10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V10_SHIFT))
    #define PINMUX_BALL_V5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V5_SHIFT))
    #define PINMUX_BALL_B2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_C3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_W9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W8_SHIFT))
    #define PINMUX_BALL_V8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V8_SHIFT))
    #define PINMUX_BALL_H19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_E19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E19_SHIFT))
    #define PINMUX_BALL_B6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B6_SHIFT))
    #define PINMUX_BALL_W6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W6_SHIFT))
    #define PINMUX_BALL_T12_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_T12_SHIFT))
    #define PINMUX_BALL_H18_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_J19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_E16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E16_SHIFT))
    #define PINMUX_BALL_H17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H17_SHIFT))
    #define PINMUX_BALL_G17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_J18_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_E17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E17_SHIFT))
    #define PINMUX_BALL_H16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H16_SHIFT))
    #define PINMUX_BALL_G16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_K18_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K18_SHIFT))
    #define PINMUX_BALL_V2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_W5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W5_SHIFT))
    #define PINMUX_BALL_U1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_B12_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B12_SHIFT))
    #define PINMUX_BALL_V6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_W3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W3_SHIFT))
    #define PINMUX_BALL_T1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_E18_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E18_SHIFT))
    #define PINMUX_BALL_V7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_D19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_E3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_B4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_N2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_A4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_A4_SHIFT))
    #define PINMUX_BALL_A13_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_A13_SHIFT))
    #define PINMUX_BALL_J1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J1_SHIFT))
    #define PINMUX_BALL_B13_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B13_SHIFT))
    #define PINMUX_BALL_P2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P2_SHIFT))
    #define PINMUX_BALL_H4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H4_SHIFT))
    #define PINMUX_BALL_B3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B3_SHIFT))
    #define PINMUX_BALL_J4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J4_SHIFT))
    #define PINMUX_BALL_P1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_A14_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_A14_SHIFT))
    #define PINMUX_BALL_K19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_B11_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B11_SHIFT))
    #define PINMUX_BALL_D8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D8_SHIFT))
    #define PINMUX_BALL_D7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D7_SHIFT))
    #define PINMUX_BALL_D3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D3_SHIFT))
    #define PINMUX_BALL_D2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D2_SHIFT))
    #define PINMUX_BALL_D1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D1_SHIFT))
    #define PINMUX_BALL_P4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P4_SHIFT))
    #define PINMUX_BALL_T5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_T5_SHIFT))
    #define PINMUX_BALL_T4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_T4_SHIFT))
    #define PINMUX_BALL_U7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_U7_SHIFT))
    #define PINMUX_BALL_E2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E2_SHIFT))
    #define PINMUX_BALL_N3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N3_SHIFT))
    #define PINMUX_GATE_EMIF_CLK_MASK               (~(uint32)((uint32)0xFFU << PINMUX_GATE_EMIF_CLK_SHIFT))
    #define PINMUX_EMIF_OUTPUT_ENABLE_MASK          (~(uint32)((uint32)0xFFU << PINMUX_EMIF_OUTPUT_ENABLE_SHIFT))
    #define PINMUX_GIOA_DISABLE_HET1_MASK           (~(uint32)((uint32)0xFFU << PINMUX_GIOA_DISABLE_HET1_SHIFT))
    #define PINMUX_GIOB_DISABLE_HET2_MASK           (~(uint32)((uint32)0xFFU << PINMUX_GIOB_DISABLE_HET2_SHIFT))
    #define PINMUX_ALT_ADC_TRIGGER_MASK             (~(uint32)((uint32)0xFFU << PINMUX_ALT_ADC_TRIGGER_SHIFT))
    #define PINMUX_ETHERNET_MASK                    (~(uint32)((uint32)0xFFU << PINMUX_ETHERNET_SHIFT))
    #define PINMUX_ETPWM1_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM1_SHIFT))
    #define PINMUX_ETPWM2_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM2_SHIFT))
    #define PINMUX_ETPWM3_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM3_SHIFT))
    #define PINMUX_ETPWM4_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM4_SHIFT))
    #define PINMUX_ETPWM5_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM5_SHIFT))
    #define PINMUX_ETPWM6_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM6_SHIFT))
    #define PINMUX_ETPWM7_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM7_SHIFT))
    #define PINMUX_ETPWM_TIME_BASE_SYNC_MASK        (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_TIME_BASE_SYNC_SHIFT))
    #define PINMUX_ETPWM_TBCLK_SYNC_MASK           (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_TBCLK_SYNC_SHIFT))
    #define PINMUX_TZ1_MASK                        (~(uint32)((uint32)0xFFU << PINMUX_TZ1_SHIFT))
    #define PINMUX_TZ2_MASK                        (~(uint32)((uint32)0xFFU << PINMUX_TZ2_SHIFT))
    #define PINMUX_TZ3_MASK                        (~(uint32)((uint32)0xFFU << PINMUX_TZ3_SHIFT))
    #define PINMUX_EPWM1SYNCI_MASK                 (~(uint32)((uint32)0xFFU << PINMUX_EPWM1SYNCI_SHIFT))
    #define PINMUX_ETPWM_SOC1A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC1A_SHIFT))
    #define PINMUX_ETPWM_SOC2A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC2A_SHIFT))
    #define PINMUX_ETPWM_SOC3A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC3A_SHIFT))
    #define PINMUX_ETPWM_SOC4A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC4A_SHIFT))
    #define PINMUX_ETPWM_SOC5A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC5A_SHIFT))
    #define PINMUX_ETPWM_SOC6A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC6A_SHIFT))
    #define PINMUX_ETPWM_SOC7A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC7A_SHIFT))
    #define PINMUX_EQEP1A_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP1A_FILTER_SHIFT))
    #define PINMUX_EQEP1B_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP1B_FILTER_SHIFT))
    #define PINMUX_EQEP1I_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP1I_FILTER_SHIFT))
    #define PINMUX_EQEP1S_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP1S_FILTER_SHIFT))
    #define PINMUX_EQEP2A_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP2A_FILTER_SHIFT))
    #define PINMUX_EQEP2B_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP2B_FILTER_SHIFT))
    #define PINMUX_EQEP2I_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP2I_FILTER_SHIFT))
    #define PINMUX_EQEP2S_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP2S_FILTER_SHIFT))
    #define PINMUX_ECAP1_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP1_FILTER_SHIFT))
    #define PINMUX_ECAP2_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP2_FILTER_SHIFT))
    #define PINMUX_ECAP3_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP3_FILTER_SHIFT))
    #define PINMUX_ECAP4_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP4_FILTER_SHIFT))
    #define PINMUX_ECAP5_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP5_FILTER_SHIFT))
    #define PINMUX_ECAP6_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP6_FILTER_SHIFT))
    #define PINMUX_GIOA0_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA0_DMA_SHIFT))
    #define PINMUX_GIOA1_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA1_DMA_SHIFT))
    #define PINMUX_GIOA2_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA2_DMA_SHIFT))
    #define PINMUX_GIOA3_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA3_DMA_SHIFT))
    #define PINMUX_GIOA4_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA4_DMA_SHIFT))
    #define PINMUX_GIOA5_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA5_DMA_SHIFT))
    #define PINMUX_GIOA6_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA6_DMA_SHIFT))
    #define PINMUX_GIOA7_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA7_DMA_SHIFT))
    #define PINMUX_GIOB0_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB0_DMA_SHIFT))
    #define PINMUX_GIOB1_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB1_DMA_SHIFT))
    #define PINMUX_GIOB2_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB2_DMA_SHIFT))
    #define PINMUX_GIOB3_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB3_DMA_SHIFT))
    #define PINMUX_GIOB4_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB4_DMA_SHIFT))
    #define PINMUX_GIOB5_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB5_DMA_SHIFT))
    #define PINMUX_GIOB6_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB6_DMA_SHIFT))
    #define PINMUX_GIOB7_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB7_DMA_SHIFT))
    #define PINMUX_TEMP1_ENABLE_MASK               (~(uint32)((uint32)0xFFU << PINMUX_TEMP1_ENABLE_SHIFT))
    #define PINMUX_TEMP2_ENABLE_MASK               (~(uint32)((uint32)0xFFU << PINMUX_TEMP2_ENABLE_SHIFT))
    #define PINMUX_TEMP3_ENABLE_MASK               (~(uint32)((uint32)0xFFU << PINMUX_TEMP3_ENABLE_SHIFT))
    #define PINMUX_BALL_N19_AD1EVT                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_N19_MII_RX_ER                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_N19_RMII_RX_ER                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_N19_nTZ1_1                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_D4_EMIF_ADDR_00                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D4_SHIFT))
    #define PINMUX_BALL_D4_N2HET2_01                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_D4_SHIFT))
    #define PINMUX_BALL_D5_EMIF_ADDR_01                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D5_SHIFT))
    #define PINMUX_BALL_D5_N2HET2_03                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_D5_SHIFT))
    #define PINMUX_BALL_C4_EMIF_ADDR_06                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C4_SHIFT))
    #define PINMUX_BALL_C4_RTP_DATA_13                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C4_SHIFT))
    #define PINMUX_BALL_C4_N2HET2_11                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_C4_SHIFT))
    #define PINMUX_BALL_C5_EMIF_ADDR_07                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C5_SHIFT))
    #define PINMUX_BALL_C5_RTP_DATA_12                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C5_SHIFT))
    #define PINMUX_BALL_C5_N2HET2_13                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_C5_SHIFT))
    #define PINMUX_BALL_C6_EMIF_ADDR_08                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C6_SHIFT))
    #define PINMUX_BALL_C6_RTP_DATA_11                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C6_SHIFT))
    #define PINMUX_BALL_C6_N2HET2_15                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_C6_SHIFT))
    #define PINMUX_BALL_C7_EMIF_ADDR_09                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C7_SHIFT))
    #define PINMUX_BALL_C7_RTP_DATA_10                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C7_SHIFT))
    #define PINMUX_BALL_C8_EMIF_ADDR_10                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C8_SHIFT))
    #define PINMUX_BALL_C8_RTP_DATA_09                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C8_SHIFT))
    #define PINMUX_BALL_C9_EMIF_ADDR_11                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C9_SHIFT))
    #define PINMUX_BALL_C9_RTP_DATA_08                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C9_SHIFT))
    #define PINMUX_BALL_C10_EMIF_ADDR_12                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C10_SHIFT))
    #define PINMUX_BALL_C10_RTP_DATA_06                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C10_SHIFT))
    #define PINMUX_BALL_C11_EMIF_ADDR_13                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C11_SHIFT))
    #define PINMUX_BALL_C11_RTP_DATA_05                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C11_SHIFT))
    #define PINMUX_BALL_C12_EMIF_ADDR_14                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C12_SHIFT))
    #define PINMUX_BALL_C12_RTP_DATA_04                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C12_SHIFT))
    #define PINMUX_BALL_C13_EMIF_ADDR_15                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C13_SHIFT))
    #define PINMUX_BALL_C13_RTP_DATA_03                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C13_SHIFT))
    #define PINMUX_BALL_D14_EMIF_ADDR_16                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D14_SHIFT))
    #define PINMUX_BALL_D14_RTP_DATA_02                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D14_SHIFT))
    #define PINMUX_BALL_C14_EMIF_ADDR_17                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C14_SHIFT))
    #define PINMUX_BALL_C14_RTP_DATA_01                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C14_SHIFT))
    #define PINMUX_BALL_D15_EMIF_ADDR_18                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D15_SHIFT))
    #define PINMUX_BALL_D15_RTP_DATA_00                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D15_SHIFT))
    #define PINMUX_BALL_C15_EMIF_ADDR_19                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C15_SHIFT))
    #define PINMUX_BALL_C15_RTP_nENA                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C15_SHIFT))
    #define PINMUX_BALL_C16_EMIF_ADDR_20                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C16_SHIFT))
    #define PINMUX_BALL_C16_RTP_nSYNC                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C16_SHIFT))
    #define PINMUX_BALL_C17_EMIF_ADDR_21                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C17_SHIFT))
    #define PINMUX_BALL_C17_RTP_CLK                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C17_SHIFT))
    #define PINMUX_BALL_D16_EMIF_BA_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D16_SHIFT))
    #define PINMUX_BALL_D16_8_25                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D16_SHIFT))
    #define PINMUX_BALL_D16_N2HET2_05                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_D16_SHIFT))
    #define PINMUX_BALL_K3_RESERVED                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K3_SHIFT))
    #define PINMUX_BALL_K3_EMIF_CLK                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K3_SHIFT))
    #define PINMUX_BALL_K3_ECLK2                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_K3_SHIFT))
    #define PINMUX_BALL_R4_EMIF_nCAS                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R4_SHIFT))
    #define PINMUX_BALL_R4_GIOB_3                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R4_SHIFT))
    #define PINMUX_BALL_N17_EMIF_nCS_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N17_SHIFT))
    #define PINMUX_BALL_N17_RTP_DATA_15                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N17_SHIFT))
    #define PINMUX_BALL_N17_N2HET2_07                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_N17_SHIFT))
    #define PINMUX_BALL_L17_EMIF_nCS_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_L17_SHIFT))
    #define PINMUX_BALL_L17_GIOB_4                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_L17_SHIFT))
    #define PINMUX_BALL_K17_EMIF_nCS_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K17_SHIFT))
    #define PINMUX_BALL_K17_RTP_DATA_14                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K17_SHIFT))
    #define PINMUX_BALL_K17_N2HET2_09                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_K17_SHIFT))
    #define PINMUX_BALL_M17_EMIF_nCS_4                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_M17_SHIFT))
    #define PINMUX_BALL_M17_RTP_DATA_07                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_M17_SHIFT))
    #define PINMUX_BALL_M17_GIOB_5                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_M17_SHIFT))
    #define PINMUX_BALL_R3_EMIF_nRAS                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R3_SHIFT))
    #define PINMUX_BALL_R3_GIOB_6                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R3_SHIFT))
    #define PINMUX_BALL_P3_EMIF_nWAIT                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P3_SHIFT))
    #define PINMUX_BALL_P3_GIOB_7                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_P3_SHIFT))
    #define PINMUX_BALL_D17_EMIF_nWE                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D17_SHIFT))
    #define PINMUX_BALL_D17_EMIF_RNW                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D17_SHIFT))
    #define PINMUX_BALL_E9_ETMDATA_08                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E9_SHIFT))
    #define PINMUX_BALL_E9_EMIF_ADDR_05                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E9_SHIFT))
    #define PINMUX_BALL_E8_ETMDATA_09                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E8_SHIFT))
    #define PINMUX_BALL_E8_EMIF_ADDR_04                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E8_SHIFT))
    #define PINMUX_BALL_E7_ETMDATA_10                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E7_SHIFT))
    #define PINMUX_BALL_E7_EMIF_ADDR_03                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E7_SHIFT))
    #define PINMUX_BALL_E6_ETMDATA_11                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E6_SHIFT))
    #define PINMUX_BALL_E6_EMIF_ADDR_02                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E6_SHIFT))
    #define PINMUX_BALL_E13_ETMDATA_12                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E13_SHIFT))
    #define PINMUX_BALL_E13_EMIF_BA_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E13_SHIFT))
    #define PINMUX_BALL_E12_ETMDATA_13                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E12_SHIFT))
    #define PINMUX_BALL_E12_EMIF_nOE                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E12_SHIFT))
    #define PINMUX_BALL_E11_ETMDATA_14                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E11_SHIFT))
    #define PINMUX_BALL_E11_EMIF_nDQM_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E11_SHIFT))
    #define PINMUX_BALL_E10_ETMDATA_15                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E10_SHIFT))
    #define PINMUX_BALL_E10_EMIF_nDQM_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E10_SHIFT))
    #define PINMUX_BALL_K15_ETMDATA_16                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K15_SHIFT))
    #define PINMUX_BALL_K15_EMIF_DATA_00                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K15_SHIFT))
    #define PINMUX_BALL_L15_ETMDATA_17                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_L15_SHIFT))
    #define PINMUX_BALL_L15_EMIF_DATA_01                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_L15_SHIFT))
    #define PINMUX_BALL_M15_ETMDATA_18                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_M15_SHIFT))
    #define PINMUX_BALL_M15_EMIF_DATA_02                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_M15_SHIFT))
    #define PINMUX_BALL_N15_ETMDATA_19                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N15_SHIFT))
    #define PINMUX_BALL_N15_EMIF_DATA_03                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N15_SHIFT))
    #define PINMUX_BALL_E5_ETMDATA_20                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E5_SHIFT))
    #define PINMUX_BALL_E5_EMIF_DATA_04                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E5_SHIFT))
    #define PINMUX_BALL_F5_ETMDATA_21                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_F5_SHIFT))
    #define PINMUX_BALL_F5_EMIF_DATA_05                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_F5_SHIFT))
    #define PINMUX_BALL_G5_ETMDATA_22                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G5_SHIFT))
    #define PINMUX_BALL_G5_EMIF_DATA_06                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_G5_SHIFT))
    #define PINMUX_BALL_K5_ETMDATA_23                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K5_SHIFT))
    #define PINMUX_BALL_K5_EMIF_DATA_07                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K5_SHIFT))
    #define PINMUX_BALL_L5_ETMDATA_24                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_L5_EMIF_DATA_08                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_L5_N2HET2_24                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_L5_MIBSPI5NCS_4                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_M5_ETMDATA_25                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_M5_EMIF_DATA_09                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_M5_N2HET2_25                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_M5_MIBSPI5NCS_5                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_N5_ETMDATA_26                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N5_SHIFT))
    #define PINMUX_BALL_N5_EMIF_DATA_10                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N5_SHIFT))
    #define PINMUX_BALL_N5_N2HET2_26                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_N5_SHIFT))
    #define PINMUX_BALL_P5_ETMDATA_27                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P5_SHIFT))
    #define PINMUX_BALL_P5_EMIF_DATA_11                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_P5_SHIFT))
    #define PINMUX_BALL_P5_N2HET2_27                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_P5_SHIFT))
    #define PINMUX_BALL_R5_ETMDATA_28                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R5_EMIF_DATA_12                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R5_N2HET2_28                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R5_GIOA_0                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R6_ETMDATA_29                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R6_EMIF_DATA_13                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R6_N2HET2_29                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R6_GIOA_1                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R7_ETMDATA_30                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R7_EMIF_DATA_14                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R7_N2HET2_30                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R7_GIOA_3                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R8_ETMDATA_31                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R8_EMIF_DATA_15                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R8_N2HET2_31                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R8_GIOA_4                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R9_ETMTRACECLKIN                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R9_SHIFT))
    #define PINMUX_BALL_R9_EXTCLKIN2                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R9_SHIFT))
    #define PINMUX_BALL_R9_GIOA_5                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R9_SHIFT))
    #define PINMUX_BALL_R10_ETMTRACECLKOUT                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R10_SHIFT))
    #define PINMUX_BALL_R10_GIOA_6                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R10_SHIFT))
    #define PINMUX_BALL_R11_ETMTRACECTL                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R11_SHIFT))
    #define PINMUX_BALL_R11_GIOA_7                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R11_SHIFT))
    #define PINMUX_BALL_B15_FRAYTX1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B15_SHIFT))
    #define PINMUX_BALL_B15_GIOA_2                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B15_SHIFT))
    #define PINMUX_BALL_B8_FRAYTX2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B8_SHIFT))
    #define PINMUX_BALL_B8_GIOB_0                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B8_SHIFT))
    #define PINMUX_BALL_B16_FRAYTXEN1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B16_SHIFT))
    #define PINMUX_BALL_B16_GIOB_1                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B16_SHIFT))
    #define PINMUX_BALL_B9_FRAYTXEN2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B9_SHIFT))
    #define PINMUX_BALL_B9_GIOB_2                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B9_SHIFT))
    #define PINMUX_BALL_C1_GIOA_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C1_SHIFT))
    #define PINMUX_BALL_C1_N2HET2_00                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_C1_SHIFT))
    #define PINMUX_BALL_C1_eQEP2I                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_C1_SHIFT))
    #define PINMUX_BALL_E1_GIOA_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E1_SHIFT))
    #define PINMUX_BALL_E1_N2HET2_02                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_E1_SHIFT))
    #define PINMUX_BALL_B5_GIOA_5                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B5_SHIFT))
    #define PINMUX_BALL_B5_EXTCLKIN                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B5_SHIFT))
    #define PINMUX_BALL_B5_eTPWM1A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_B5_SHIFT))
    #define PINMUX_BALL_H3_GIOA_6                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H3_SHIFT))
    #define PINMUX_BALL_H3_N2HET2_04                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_H3_SHIFT))
    #define PINMUX_BALL_H3_eTPWM1B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_H3_SHIFT))
    #define PINMUX_BALL_M1_GIOA_7                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_M1_SHIFT))
    #define PINMUX_BALL_M1_N2HET2_06                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_M1_SHIFT))
    #define PINMUX_BALL_M1_eTPWM2A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_M1_SHIFT))
    #define PINMUX_BALL_F2_GIOB_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_F2_SHIFT))
    #define PINMUX_BALL_F2_DCAN4TX                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_F2_SHIFT))
    #define PINMUX_BALL_W10_GIOB_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W10_SHIFT))
    #define PINMUX_BALL_W10_DCAN4RX                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_W10_SHIFT))
    #define PINMUX_BALL_J2_GIOB_6                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J2_SHIFT))
    #define PINMUX_BALL_J2_nERROR1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J2_SHIFT))
    #define PINMUX_BALL_F1_GIOB_7                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_F1_SHIFT))
    #define PINMUX_BALL_F1_nERROR2                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_F1_SHIFT))
    #define PINMUX_BALL_F1_nTZ1_2                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_F1_SHIFT))
    #define PINMUX_BALL_R2_MIBSPI1NCS_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_R2_MIBSPI1SOMI_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_R2_MII_TXD_2                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_R2_ECAP6                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_F3_MIBSPI1NCS_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_F3_MII_COL                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_F3_N2HET1_17                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_F3_eQEP1S                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_G3_MIBSPI1NCS_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G3_SHIFT))
    #define PINMUX_BALL_G3_MDIO                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_G3_SHIFT))
    #define PINMUX_BALL_G3_N2HET1_19                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_G3_SHIFT))
    #define PINMUX_BALL_J3_MIBSPI1NCS_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J3_SHIFT))
    #define PINMUX_BALL_J3_N2HET1_21                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_J3_SHIFT))
    #define PINMUX_BALL_J3_nTZ1_3                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_J3_SHIFT))
    #define PINMUX_BALL_G19_MIBSPI1NENA                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_G19_MII_RXD_2                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_G19_N2HET1_23                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_G19_ECAP4                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_V9_MIBSPI3CLK                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V9_SHIFT))
    #define PINMUX_BALL_V9_EXT_SEL_01                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V9_SHIFT))
    #define PINMUX_BALL_V9_eQEP1A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V9_SHIFT))
    #define PINMUX_BALL_V10_MIBSPI3NCS_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V10_SHIFT))
    #define PINMUX_BALL_V10_AD2EVT                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V10_SHIFT))
    #define PINMUX_BALL_V10_eQEP1I                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V10_SHIFT))
    #define PINMUX_BALL_V5_MIBSPI3NCS_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V5_SHIFT))
    #define PINMUX_BALL_V5_MDCLK                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_V5_SHIFT))
    #define PINMUX_BALL_V5_N2HET1_25                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_V5_SHIFT))
    #define PINMUX_BALL_B2_MIBSPI3NCS_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_B2_I2C1_SDA                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_B2_N2HET1_27                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_B2_nTZ1_2                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_C3_MIBSPI3NCS_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_C3_I2C1_SCL                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_C3_N2HET1_29                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_C3_nTZ1_1                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_W9_MIBSPI3NENA                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W9_MIBSPI3NCS_5                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W9_N2HET1_31                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W9_eQEP1B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W8_MIBSPI3SIMO                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W8_SHIFT))
    #define PINMUX_BALL_W8_EXT_SEL_00                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W8_SHIFT))
    #define PINMUX_BALL_W8_ECAP3                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_W8_SHIFT))
    #define PINMUX_BALL_V8_MIBSPI3SOMI                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V8_SHIFT))
    #define PINMUX_BALL_V8_EXT_ENA                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V8_SHIFT))
    #define PINMUX_BALL_V8_ECAP2                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V8_SHIFT))
    #define PINMUX_BALL_H19_MIBSPI5CLK                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_H19_DMM_DATA_04                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_H19_MII_TXEN                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_H19_RMII_TXEN                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_E19_MIBSPI5NCS_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E19_SHIFT))
    #define PINMUX_BALL_E19_DMM_DATA_05                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E19_SHIFT))
    #define PINMUX_BALL_E19_eTPWM4A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_E19_SHIFT))
    #define PINMUX_BALL_B6_MIBSPI5NCS_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B6_SHIFT))
    #define PINMUX_BALL_B6_DMM_DATA_06                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B6_SHIFT))
    #define PINMUX_BALL_W6_MIBSPI5NCS_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W6_SHIFT))
    #define PINMUX_BALL_W6_DMM_DATA_02                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W6_SHIFT))
    #define PINMUX_BALL_T12_MIBSPI5NCS_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_T12_SHIFT))
    #define PINMUX_BALL_T12_DMM_DATA_03                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_T12_SHIFT))
    #define PINMUX_BALL_H18_MIBSPI5NENA                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_H18_DMM_DATA_07                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_H18_MII_RXD_3                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_H18_ECAP5                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_J19_MIBSPI5SIMO_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_J19_DMM_DATA_08                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_J19_MII_TXD_1                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_J19_RMII_TXD_1                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_E16_MIBSPI5SIMO_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E16_SHIFT))
    #define PINMUX_BALL_E16_DMM_DATA_09                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E16_SHIFT))
    #define PINMUX_BALL_E16_EXT_SEL_00                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_E16_SHIFT))
    #define PINMUX_BALL_H17_MIBSPI5SIMO_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H17_SHIFT))
    #define PINMUX_BALL_H17_DMM_DATA_10                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H17_SHIFT))
    #define PINMUX_BALL_H17_EXT_SEL_01                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_H17_SHIFT))
    #define PINMUX_BALL_G17_MIBSPI5SIMO_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_G17_DMM_DATA_11                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_G17_I2C2_SDA                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_G17_EXT_SEL_02                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_J18_MIBSPI5SOMI_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_J18_DMM_DATA_12                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_J18_MII_TXD_0                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_J18_RMII_TXD_0                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_E17_MIBSPI5SOMI_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E17_SHIFT))
    #define PINMUX_BALL_E17_DMM_DATA_13                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E17_SHIFT))
    #define PINMUX_BALL_E17_EXT_SEL_03                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_E17_SHIFT))
    #define PINMUX_BALL_H16_MIBSPI5SOMI_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H16_SHIFT))
    #define PINMUX_BALL_H16_DMM_DATA_14                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H16_SHIFT))
    #define PINMUX_BALL_H16_EXT_SEL_04                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_H16_SHIFT))
    #define PINMUX_BALL_G16_MIBSPI5SOMI_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_G16_DMM_DATA_15                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_G16_I2C2_SCL                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_G16_EXT_ENA                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_K18_N2HET1_00                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K18_SHIFT))
    #define PINMUX_BALL_K18_MIBSPI4CLK                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K18_SHIFT))
    #define PINMUX_BALL_K18_eTPWM2B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_K18_SHIFT))
    #define PINMUX_BALL_V2_N2HET1_01                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_V2_MIBSPI4NENA                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_V2_N2HET2_08                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_V2_eQEP2A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_W5_N2HET1_02                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W5_SHIFT))
    #define PINMUX_BALL_W5_MIBSPI4SIMO                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W5_SHIFT))
    #define PINMUX_BALL_W5_eTPWM3A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_W5_SHIFT))
    #define PINMUX_BALL_U1_N2HET1_03                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_U1_MIBSPI4NCS_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_U1_N2HET2_10                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_U1_eQEP2B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_B12_N2HET1_04                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B12_SHIFT))
    #define PINMUX_BALL_B12_MIBSPI4NCS_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B12_SHIFT))
    #define PINMUX_BALL_B12_eTPWM4B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_B12_SHIFT))
    #define PINMUX_BALL_V6_N2HET1_05                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_V6_MIBSPI4SOMI                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_V6_N2HET2_12                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_V6_eTPWM3B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_W3_N2HET1_06                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W3_SHIFT))
    #define PINMUX_BALL_W3_SCI3RX                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W3_SHIFT))
    #define PINMUX_BALL_W3_eTPWM5A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_W3_SHIFT))
    #define PINMUX_BALL_T1_N2HET1_07                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_T1_MIBSPI4NCS_2                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_T1_N2HET2_14                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_T1_eTPWM7B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_E18_N2HET1_08                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E18_SHIFT))
    #define PINMUX_BALL_E18_MIBSPI1SIMO_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E18_SHIFT))
    #define PINMUX_BALL_E18_MII_TXD_3                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_E18_SHIFT))
    #define PINMUX_BALL_V7_N2HET1_09                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_V7_MIBSPI4NCS_3                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_V7_N2HET2_16                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_V7_eTPWM7A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_D19_N2HET1_10                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_D19_MIBSPI4NCS_4                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_D19_MII_TX_CLK                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_D19_MII_TX_AVCLK4                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_D19_nTZ1_3                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_E3_N2HET1_11                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_E3_MIBSPI3NCS_4                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_E3_N2HET2_18                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_E3_ETPWM1SYNCO                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_B4_N2HET1_12                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_B4_MIBSPI4NCS_5                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_B4_MII_CRS                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_B4_RMII_CRS_DV                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_N2_N2HET1_13                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N2_SCI3TX                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N2_N2HET2_20                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N2_eTPWM5B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N1_N2HET1_15                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_N1_MIBSPI1NCS_4                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_N1_N2HET2_22                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_N1_ECAP1                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_A4_N2HET1_16                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_A4_SHIFT))
    #define PINMUX_BALL_A4_ETPWM1SYNCI                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_A4_SHIFT))
    #define PINMUX_BALL_A4_ETPWM1SYNCO                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_A4_SHIFT))
    #define PINMUX_BALL_A13_N2HET1_17                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_A13_SHIFT))
    #define PINMUX_BALL_A13_EMIF_nOE                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_A13_SHIFT))
    #define PINMUX_BALL_A13_SCI4RX                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_A13_SHIFT))
    #define PINMUX_BALL_J1_N2HET1_18                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J1_SHIFT))
    #define PINMUX_BALL_J1_EMIF_RNW                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J1_SHIFT))
    #define PINMUX_BALL_J1_eTPWM6A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_J1_SHIFT))
    #define PINMUX_BALL_B13_N2HET1_19                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B13_SHIFT))
    #define PINMUX_BALL_B13_EMIF_nDQM_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B13_SHIFT))
    #define PINMUX_BALL_B13_SCI4TX                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_B13_SHIFT))
    #define PINMUX_BALL_P2_N2HET1_20                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P2_SHIFT))
    #define PINMUX_BALL_P2_EMIF_nDQM_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_P2_SHIFT))
    #define PINMUX_BALL_P2_eTPWM6B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_P2_SHIFT))
    #define PINMUX_BALL_H4_N2HET1_21                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H4_SHIFT))
    #define PINMUX_BALL_H4_EMIF_nDQM_2                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H4_SHIFT))
    #define PINMUX_BALL_B3_N2HET1_22                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B3_SHIFT))
    #define PINMUX_BALL_B3_EMIF_nDQM_3                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B3_SHIFT))
    #define PINMUX_BALL_J4_N2HET1_23                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J4_SHIFT))
    #define PINMUX_BALL_J4_EMIF_BA_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J4_SHIFT))
    #define PINMUX_BALL_P1_N2HET1_24                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_P1_MIBSPI1NCS_5                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_P1_MII_RXD_0                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_P1_RMII_RXD_0                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_A14_N2HET1_26                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_A14_SHIFT))
    #define PINMUX_BALL_A14_MII_RXD_1                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_A14_SHIFT))
    #define PINMUX_BALL_A14_RMII_RXD_1                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_A14_SHIFT))
    #define PINMUX_BALL_K19_N2HET1_28                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_K19_MII_RXCLK                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_K19_RMII_REFCLK                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_K19_MII_RX_AVCLK4                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_B11_N2HET1_30                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B11_SHIFT))
    #define PINMUX_BALL_B11_MII_RX_DV                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_B11_SHIFT))
    #define PINMUX_BALL_B11_eQEP2S                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_B11_SHIFT))
    #define PINMUX_BALL_D8_N2HET2_01                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D8_SHIFT))
    #define PINMUX_BALL_D8_N2HET1_NDIS                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D8_SHIFT))
    #define PINMUX_BALL_D7_N2HET2_02                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D7_SHIFT))
    #define PINMUX_BALL_D7_N2HET2_NDIS                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D7_SHIFT))
    #define PINMUX_BALL_D3_N2HET2_12                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D3_SHIFT))
    #define PINMUX_BALL_D3_MIBSPI2NENA                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_D3_SHIFT))
    #define PINMUX_BALL_D3_MIBSPI2NCS_1                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_D3_SHIFT))
    #define PINMUX_BALL_D2_N2HET2_13                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D2_SHIFT))
    #define PINMUX_BALL_D2_MIBSPI2SOMI                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_D2_SHIFT))
    #define PINMUX_BALL_D1_N2HET2_14                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D1_SHIFT))
    #define PINMUX_BALL_D1_MIBSPI2SIMO                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_D1_SHIFT))
    #define PINMUX_BALL_P4_N2HET2_19                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P4_SHIFT))
    #define PINMUX_BALL_P4_LIN2RX                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_P4_SHIFT))
    #define PINMUX_BALL_T5_N2HET2_20                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_T5_SHIFT))
    #define PINMUX_BALL_T5_LIN2TX                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_T5_SHIFT))
    #define PINMUX_BALL_T4_MII_RXCLK                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_T4_SHIFT))
    #define PINMUX_BALL_T4_MII_RX_AVCLK4                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_T4_SHIFT))
    #define PINMUX_BALL_U7_MII_TX_CLK                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_U7_SHIFT))
    #define PINMUX_BALL_U7_MII_TX_AVCLK4                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_U7_SHIFT))
    #define PINMUX_BALL_E2_N2HET2_03                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E2_SHIFT))
    #define PINMUX_BALL_E2_MIBSPI2CLK                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_E2_SHIFT))
    #define PINMUX_BALL_N3_N2HET2_07                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N3_SHIFT))
    #define PINMUX_BALL_N3_MIBSPI2NCS_0                               ((uint32)((uint32)0x10U <<  PINMUX_BALL_N3_SHIFT))
    #define PINMUX_GATE_EMIF_CLK_ON                                 ((uint32)((uint32)0x2U <<  PINMUX_GATE_EMIF_CLK_SHIFT))
    #define PINMUX_EMIF_OUTPUT_ENABLE_ON                            ((uint32)((uint32)0x2U <<  PINMUX_EMIF_OUTPUT_ENABLE_SHIFT))
    #define PINMUX_GIOA_DISABLE_HET1_ON                             ((uint32)((uint32)0x2U <<  PINMUX_GIOA_DISABLE_HET1_SHIFT))
    #define PINMUX_GIOB_DISABLE_HET2_ON                             ((uint32)((uint32)0x2U <<  PINMUX_GIOB_DISABLE_HET2_SHIFT))
    #define PINMUX_GATE_EMIF_CLK_OFF                                ((uint32)((uint32)0x1U <<  PINMUX_GATE_EMIF_CLK_SHIFT))
    #define PINMUX_EMIF_OUTPUT_ENABLE_OFF                           ((uint32)((uint32)0x1U <<  PINMUX_EMIF_OUTPUT_ENABLE_SHIFT))
    #define PINMUX_GIOA_DISABLE_HET1_OFF                            ((uint32)((uint32)0x1U <<  PINMUX_GIOA_DISABLE_HET1_SHIFT))
    #define PINMUX_GIOB_DISABLE_HET2_OFF                            ((uint32)((uint32)0x1U <<  PINMUX_GIOB_DISABLE_HET2_SHIFT))
    #define PINMUX_ALT_ADC_TRIGGER_1                                ((uint32)((uint32)0x1U <<  PINMUX_ALT_ADC_TRIGGER_SHIFT))
    #define PINMUX_ALT_ADC_TRIGGER_2                                ((uint32)((uint32)0x2U <<  PINMUX_ALT_ADC_TRIGGER_SHIFT))
    #define PINMUX_ETHERNET_MII                                     ((uint32)((uint32)0x0U <<  PINMUX_ETHERNET_SHIFT))
    #define PINMUX_ETHERNET_RMII                                    ((uint32)((uint32)0x1U <<  PINMUX_ETHERNET_SHIFT))
    #define PINMUX_ETPWM1_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM1_SHIFT))
    #define PINMUX_ETPWM1_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM1_SHIFT))
    #define PINMUX_ETPWM1_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM1_SHIFT))
    #define PINMUX_ETPWM2_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM2_SHIFT))
    #define PINMUX_ETPWM2_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM2_SHIFT))
    #define PINMUX_ETPWM2_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM2_SHIFT))
    #define PINMUX_ETPWM3_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM3_SHIFT))
    #define PINMUX_ETPWM3_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM3_SHIFT))
    #define PINMUX_ETPWM3_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM3_SHIFT))
    #define PINMUX_ETPWM4_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM4_SHIFT))
    #define PINMUX_ETPWM4_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM4_SHIFT))
    #define PINMUX_ETPWM4_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM4_SHIFT))
    #define PINMUX_ETPWM5_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM5_SHIFT))
    #define PINMUX_ETPWM5_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM5_SHIFT))
    #define PINMUX_ETPWM5_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM5_SHIFT))
    #define PINMUX_ETPWM6_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM6_SHIFT))
    #define PINMUX_ETPWM6_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM6_SHIFT))
    #define PINMUX_ETPWM6_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM6_SHIFT))
    #define PINMUX_ETPWM7_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM7_SHIFT))
    #define PINMUX_ETPWM7_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM7_SHIFT))
    #define PINMUX_ETPWM7_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM7_SHIFT))
    #define PINMUX_ETPWM_TIME_BASE_SYNC_ON                            ((uint32)((uint32)0x2U <<  PINMUX_ETPWM_TIME_BASE_SYNC_SHIFT))
    #define PINMUX_ETPWM_TBCLK_SYNC_ON                                ((uint32)((uint32)0x2U <<  PINMUX_ETPWM_TBCLK_SYNC_SHIFT))
    #define PINMUX_ETPWM_TIME_BASE_SYNC_OFF                           ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_TIME_BASE_SYNC_SHIFT))
    #define PINMUX_ETPWM_TBCLK_SYNC_OFF                               ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_TBCLK_SYNC_SHIFT))
    #define PINMUX_TZ1_ASYNC                                          ((uint32)((uint32)0x1U <<  PINMUX_TZ1_SHIFT))
    #define PINMUX_TZ1_SYNC                                           ((uint32)((uint32)0x2U <<  PINMUX_TZ1_SHIFT))
    #define PINMUX_TZ1_FILTERED                                       ((uint32)((uint32)0x4U <<  PINMUX_TZ1_SHIFT))
    #define PINMUX_TZ2_ASYNC                                          ((uint32)((uint32)0x1U <<  PINMUX_TZ2_SHIFT))
    #define PINMUX_TZ2_SYNC                                           ((uint32)((uint32)0x2U <<  PINMUX_TZ2_SHIFT))
    #define PINMUX_TZ2_FILTERED                                       ((uint32)((uint32)0x4U <<  PINMUX_TZ2_SHIFT))
    #define PINMUX_TZ3_ASYNC                                          ((uint32)((uint32)0x1U <<  PINMUX_TZ3_SHIFT))
    #define PINMUX_TZ3_SYNC                                           ((uint32)((uint32)0x2U <<  PINMUX_TZ3_SHIFT))
    #define PINMUX_TZ3_FILTERED                                       ((uint32)((uint32)0x4U <<  PINMUX_TZ3_SHIFT))
    #define PINMUX_EPWM1SYNCI_ASYNC                                   ((uint32)((uint32)0x1U <<  PINMUX_EPWM1SYNCI_SHIFT))
    #define PINMUX_EPWM1SYNCI_SYNC                                    ((uint32)((uint32)0x2U <<  PINMUX_EPWM1SYNCI_SHIFT))
    #define PINMUX_EPWM1SYNCI_FILTERED                                ((uint32)((uint32)0x4U <<  PINMUX_EPWM1SYNCI_SHIFT))
    #define PINMUX_ETPWM_SOC1A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC1A_SHIFT))
    #define PINMUX_ETPWM_SOC1A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC1A_SHIFT))
    #define PINMUX_ETPWM_SOC2A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC2A_SHIFT))
    #define PINMUX_ETPWM_SOC2A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC2A_SHIFT))
    #define PINMUX_ETPWM_SOC3A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC3A_SHIFT))
    #define PINMUX_ETPWM_SOC3A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC3A_SHIFT))
    #define PINMUX_ETPWM_SOC4A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC4A_SHIFT))
    #define PINMUX_ETPWM_SOC4A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC4A_SHIFT))
    #define PINMUX_ETPWM_SOC5A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC5A_SHIFT))
    #define PINMUX_ETPWM_SOC5A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC5A_SHIFT))
    #define PINMUX_ETPWM_SOC6A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC6A_SHIFT))
    #define PINMUX_ETPWM_SOC6A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC6A_SHIFT))
    #define PINMUX_ETPWM_SOC7A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC7A_SHIFT))
    #define PINMUX_ETPWM_SOC7A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC7A_SHIFT))
    #define PINMUX_EQEP1A_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP1A_FILTER_SHIFT))
    #define PINMUX_EQEP1A_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP1A_FILTER_SHIFT))
    #define PINMUX_EQEP1B_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP1B_FILTER_SHIFT))
    #define PINMUX_EQEP1B_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP1B_FILTER_SHIFT))
    #define PINMUX_EQEP1I_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP1I_FILTER_SHIFT))
    #define PINMUX_EQEP1I_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP1I_FILTER_SHIFT))
    #define PINMUX_EQEP1S_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP1S_FILTER_SHIFT))
    #define PINMUX_EQEP1S_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP1S_FILTER_SHIFT))
    #define PINMUX_EQEP2A_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP2A_FILTER_SHIFT))
    #define PINMUX_EQEP2A_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP2A_FILTER_SHIFT))
    #define PINMUX_EQEP2B_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP2B_FILTER_SHIFT))
    #define PINMUX_EQEP2B_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP2B_FILTER_SHIFT))
    #define PINMUX_EQEP2I_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP2I_FILTER_SHIFT))
    #define PINMUX_EQEP2I_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP2I_FILTER_SHIFT))
    #define PINMUX_EQEP2S_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP2S_FILTER_SHIFT))
    #define PINMUX_EQEP2S_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP2S_FILTER_SHIFT))
    #define PINMUX_ECAP1_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP1_FILTER_SHIFT))
    #define PINMUX_ECAP1_FILTER_OFF                            	 	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP1_FILTER_SHIFT))
    #define PINMUX_ECAP2_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP2_FILTER_SHIFT))
    #define PINMUX_ECAP2_FILTER_OFF                            	 	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP2_FILTER_SHIFT))
    #define PINMUX_ECAP3_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP3_FILTER_SHIFT))
    #define PINMUX_ECAP3_FILTER_OFF                            	 	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP3_FILTER_SHIFT))
    #define PINMUX_ECAP4_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP4_FILTER_SHIFT))
    #define PINMUX_ECAP4_FILTER_OFF                            	  	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP4_FILTER_SHIFT))
    #define PINMUX_ECAP5_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP5_FILTER_SHIFT))
    #define PINMUX_ECAP5_FILTER_OFF                            	 	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP5_FILTER_SHIFT))
    #define PINMUX_ECAP6_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP6_FILTER_SHIFT))
    #define PINMUX_ECAP6_FILTER_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ECAP6_FILTER_SHIFT))
    #define PINMUX_GIOA0_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA0_DMA_SHIFT))
    #define PINMUX_GIOA0_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA0_DMA_SHIFT))
    #define PINMUX_GIOA1_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA1_DMA_SHIFT))
    #define PINMUX_GIOA1_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA1_DMA_SHIFT))
    #define PINMUX_GIOA2_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA2_DMA_SHIFT))
    #define PINMUX_GIOA2_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA2_DMA_SHIFT))
    #define PINMUX_GIOA3_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA3_DMA_SHIFT))
    #define PINMUX_GIOA3_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA3_DMA_SHIFT))
    #define PINMUX_GIOA4_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA4_DMA_SHIFT))
    #define PINMUX_GIOA4_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA4_DMA_SHIFT))
    #define PINMUX_GIOA5_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA5_DMA_SHIFT))
    #define PINMUX_GIOA5_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA5_DMA_SHIFT))
    #define PINMUX_GIOA6_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA6_DMA_SHIFT))
    #define PINMUX_GIOA6_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA6_DMA_SHIFT))
    #define PINMUX_GIOA7_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA7_DMA_SHIFT))
    #define PINMUX_GIOA7_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA7_DMA_SHIFT))
    #define PINMUX_GIOB0_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB0_DMA_SHIFT))
    #define PINMUX_GIOB0_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB0_DMA_SHIFT))
    #define PINMUX_GIOB1_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB1_DMA_SHIFT))
    #define PINMUX_GIOB1_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB1_DMA_SHIFT))
    #define PINMUX_GIOB2_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB2_DMA_SHIFT))
    #define PINMUX_GIOB2_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB2_DMA_SHIFT))
    #define PINMUX_GIOB3_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB3_DMA_SHIFT))
    #define PINMUX_GIOB3_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB3_DMA_SHIFT))
    #define PINMUX_GIOB4_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB4_DMA_SHIFT))
    #define PINMUX_GIOB4_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB4_DMA_SHIFT))
    #define PINMUX_GIOB5_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB5_DMA_SHIFT))
    #define PINMUX_GIOB5_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB5_DMA_SHIFT))
    #define PINMUX_GIOB6_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB6_DMA_SHIFT))
    #define PINMUX_GIOB6_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB6_DMA_SHIFT))
    #define PINMUX_GIOB7_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB7_DMA_SHIFT))
    #define PINMUX_GIOB7_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB7_DMA_SHIFT))
    #define PINMUX_TEMP1_ENABLE_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_TEMP1_ENABLE_SHIFT))
    #define PINMUX_TEMP1_ENABLE_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_TEMP1_ENABLE_SHIFT))
    #define PINMUX_TEMP2_ENABLE_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_TEMP2_ENABLE_SHIFT))
    #define PINMUX_TEMP2_ENABLE_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_TEMP2_ENABLE_SHIFT))
    #define PINMUX_TEMP3_ENABLE_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_TEMP3_ENABLE_SHIFT))
    #define PINMUX_TEMP3_ENABLE_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_TEMP3_ENABLE_SHIFT))
    #define SIGNAL_AD2EVT_SHIFT		0U
    #define SIGNAL_GIOA_0_SHIFT		24U
    #define SIGNAL_GIOA_1_SHIFT		0U
    #define SIGNAL_GIOA_2_SHIFT		8U
    #define SIGNAL_GIOA_3_SHIFT		16U
    #define SIGNAL_GIOA_4_SHIFT		24U
    #define SIGNAL_GIOA_5_SHIFT		0U
    #define SIGNAL_GIOA_6_SHIFT		8U
    #define SIGNAL_GIOA_7_SHIFT		16U
    #define SIGNAL_GIOB_0_SHIFT		24U
    #define SIGNAL_GIOB_1_SHIFT		0U
    #define SIGNAL_GIOB_2_SHIFT		8U
    #define SIGNAL_GIOB_3_SHIFT		16U
    #define SIGNAL_GIOB_4_SHIFT		24U
    #define SIGNAL_GIOB_5_SHIFT		0U
    #define SIGNAL_GIOB_6_SHIFT		8U
    #define SIGNAL_GIOB_7_SHIFT		16U
    #define SIGNAL_MDIO_SHIFT		24U
    #define SIGNAL_MIBSPI1NCS_4_SHIFT		0U
    #define SIGNAL_MIBSPI1NCS_5_SHIFT		8U
    #define SIGNAL_MII_COL_SHIFT		16U
    #define SIGNAL_MII_CRS_SHIFT		24U
    #define SIGNAL_MII_RX_DV_SHIFT		0U
    #define SIGNAL_MII_RX_ER_SHIFT		8U
    #define SIGNAL_MII_RXCLK_SHIFT		16U
    #define SIGNAL_MII_RXD_0_SHIFT		24U
    #define SIGNAL_MII_RXD_1_SHIFT		0U
    #define SIGNAL_MII_RXD_2_SHIFT		8U
    #define SIGNAL_MII_RXD_3_SHIFT		16U
    #define SIGNAL_MII_TX_CLK_SHIFT		24U
    #define SIGNAL_N2HET1_17_SHIFT		0U
    #define SIGNAL_N2HET1_19_SHIFT		8U
    #define SIGNAL_N2HET1_21_SHIFT		16U
    #define SIGNAL_N2HET1_23_SHIFT		24U
    #define SIGNAL_N2HET1_25_SHIFT		0U
    #define SIGNAL_N2HET1_27_SHIFT		8U
    #define SIGNAL_N2HET1_29_SHIFT		16U
    #define SIGNAL_N2HET1_31_SHIFT		24U
    #define SIGNAL_N2HET2_00_SHIFT		0U
    #define SIGNAL_N2HET2_01_SHIFT		8U
    #define SIGNAL_N2HET2_02_SHIFT		16U
    #define SIGNAL_N2HET2_03_SHIFT		24U
    #define SIGNAL_N2HET2_04_SHIFT		0U
    #define SIGNAL_N2HET2_05_SHIFT		8U
    #define SIGNAL_N2HET2_06_SHIFT		16U
    #define SIGNAL_N2HET2_07_SHIFT		24U
    #define SIGNAL_N2HET2_08_SHIFT		0U
    #define SIGNAL_N2HET2_09_SHIFT		8U
    #define SIGNAL_N2HET2_10_SHIFT		16U
    #define SIGNAL_N2HET2_11_SHIFT		24U
    #define SIGNAL_N2HET2_12_SHIFT		0U
    #define SIGNAL_N2HET2_13_SHIFT		8U
    #define SIGNAL_N2HET2_14_SHIFT		16U
    #define SIGNAL_N2HET2_15_SHIFT		24U
    #define SIGNAL_N2HET2_16_SHIFT		0U
    #define SIGNAL_N2HET2_18_SHIFT		8U
    #define SIGNAL_N2HET2_20_SHIFT		16U
    #define SIGNAL_N2HET2_22_SHIFT		24U
    #define SIGNAL_nTZ1_1_SHIFT		0U
    #define SIGNAL_nTZ1_2_SHIFT		8U
    #define SIGNAL_nTZ1_3_SHIFT		16U
    #define SIGNAL_AD2EVT_T10		((uint32)((uint32)0x1U << SIGNAL_AD2EVT_SHIFT))
    #define SIGNAL_AD2EVT_V10		((uint32)((uint32)0x2U << SIGNAL_AD2EVT_SHIFT))
    #define SIGNAL_GIOA_0_A5		((uint32)((uint32)0x1U << SIGNAL_GIOA_0_SHIFT))
    #define SIGNAL_GIOA_0_R5		((uint32)((uint32)0x2U << SIGNAL_GIOA_0_SHIFT))
    #define SIGNAL_GIOA_1_C2		((uint32)((uint32)0x1U << SIGNAL_GIOA_1_SHIFT))
    #define SIGNAL_GIOA_1_R6		((uint32)((uint32)0x2U << SIGNAL_GIOA_1_SHIFT))
    #define SIGNAL_GIOA_2_C1		((uint32)((uint32)0x1U << SIGNAL_GIOA_2_SHIFT))
    #define SIGNAL_GIOA_2_B15		((uint32)((uint32)0x2U << SIGNAL_GIOA_2_SHIFT))
    #define SIGNAL_GIOA_3_E1		((uint32)((uint32)0x1U << SIGNAL_GIOA_3_SHIFT))
    #define SIGNAL_GIOA_3_R7		((uint32)((uint32)0x2U << SIGNAL_GIOA_3_SHIFT))
    #define SIGNAL_GIOA_4_A6		((uint32)((uint32)0x1U << SIGNAL_GIOA_4_SHIFT))
    #define SIGNAL_GIOA_4_R8		((uint32)((uint32)0x2U << SIGNAL_GIOA_4_SHIFT))
    #define SIGNAL_GIOA_5_B5		((uint32)((uint32)0x1U << SIGNAL_GIOA_5_SHIFT))
    #define SIGNAL_GIOA_5_R9		((uint32)((uint32)0x2U << SIGNAL_GIOA_5_SHIFT))
    #define SIGNAL_GIOA_6_H3		((uint32)((uint32)0x1U << SIGNAL_GIOA_6_SHIFT))
    #define SIGNAL_GIOA_6_R10		((uint32)((uint32)0x2U << SIGNAL_GIOA_6_SHIFT))
    #define SIGNAL_GIOA_7_M1		((uint32)((uint32)0x1U << SIGNAL_GIOA_7_SHIFT))
    #define SIGNAL_GIOA_7_R11		((uint32)((uint32)0x2U << SIGNAL_GIOA_7_SHIFT))
    #define SIGNAL_GIOB_0_M2		((uint32)((uint32)0x1U << SIGNAL_GIOB_0_SHIFT))
    #define SIGNAL_GIOB_0_B8		((uint32)((uint32)0x2U << SIGNAL_GIOB_0_SHIFT))
    #define SIGNAL_GIOB_1_K2		((uint32)((uint32)0x1U << SIGNAL_GIOB_1_SHIFT))
    #define SIGNAL_GIOB_1_B16		((uint32)((uint32)0x2U << SIGNAL_GIOB_1_SHIFT))
    #define SIGNAL_GIOB_2_F2		((uint32)((uint32)0x1U << SIGNAL_GIOB_2_SHIFT))
    #define SIGNAL_GIOB_2_B9		((uint32)((uint32)0x2U << SIGNAL_GIOB_2_SHIFT))
    #define SIGNAL_GIOB_3_W10		((uint32)((uint32)0x1U << SIGNAL_GIOB_3_SHIFT))
    #define SIGNAL_GIOB_3_R4		((uint32)((uint32)0x2U << SIGNAL_GIOB_3_SHIFT))
    #define SIGNAL_GIOB_4_G1		((uint32)((uint32)0x1U << SIGNAL_GIOB_4_SHIFT))
    #define SIGNAL_GIOB_4_L17		((uint32)((uint32)0x2U << SIGNAL_GIOB_4_SHIFT))
    #define SIGNAL_GIOB_5_G2		((uint32)((uint32)0x1U << SIGNAL_GIOB_5_SHIFT))
    #define SIGNAL_GIOB_5_M17		((uint32)((uint32)0x2U << SIGNAL_GIOB_5_SHIFT))
    #define SIGNAL_GIOB_6_J2		((uint32)((uint32)0x1U << SIGNAL_GIOB_6_SHIFT))
    #define SIGNAL_GIOB_6_R3		((uint32)((uint32)0x2U << SIGNAL_GIOB_6_SHIFT))
    #define SIGNAL_GIOB_7_F1		((uint32)((uint32)0x1U << SIGNAL_GIOB_7_SHIFT))
    #define SIGNAL_GIOB_7_P3		((uint32)((uint32)0x2U << SIGNAL_GIOB_7_SHIFT))
    #define SIGNAL_MDIO_F4		((uint32)((uint32)0x1U << SIGNAL_MDIO_SHIFT))
    #define SIGNAL_MDIO_G3		((uint32)((uint32)0x2U << SIGNAL_MDIO_SHIFT))
    #define SIGNAL_MIBSPI1NCS_4_U10		((uint32)((uint32)0x1U << SIGNAL_MIBSPI1NCS_4_SHIFT))
    #define SIGNAL_MIBSPI1NCS_4_N1		((uint32)((uint32)0x2U << SIGNAL_MIBSPI1NCS_4_SHIFT))
    #define SIGNAL_MIBSPI1NCS_5_U9		((uint32)((uint32)0x1U << SIGNAL_MIBSPI1NCS_5_SHIFT))
    #define SIGNAL_MIBSPI1NCS_5_P1		((uint32)((uint32)0x2U << SIGNAL_MIBSPI1NCS_5_SHIFT))
    #define SIGNAL_MII_COL_W4		((uint32)((uint32)0x1U << SIGNAL_MII_COL_SHIFT))
    #define SIGNAL_MII_COL_F3		((uint32)((uint32)0x2U << SIGNAL_MII_COL_SHIFT))
    #define SIGNAL_MII_CRS_V4		((uint32)((uint32)0x1U << SIGNAL_MII_CRS_SHIFT))
    #define SIGNAL_MII_CRS_B4		((uint32)((uint32)0x2U << SIGNAL_MII_CRS_SHIFT))
    #define SIGNAL_MII_RX_DV_U6		((uint32)((uint32)0x1U << SIGNAL_MII_RX_DV_SHIFT))
    #define SIGNAL_MII_RX_DV_B11		((uint32)((uint32)0x2U << SIGNAL_MII_RX_DV_SHIFT))
    #define SIGNAL_MII_RX_ER_U5		((uint32)((uint32)0x1U << SIGNAL_MII_RX_ER_SHIFT))
    #define SIGNAL_MII_RX_ER_N19		((uint32)((uint32)0x2U << SIGNAL_MII_RX_ER_SHIFT))
    #define SIGNAL_MII_RXCLK_T4		((uint32)((uint32)0x1U << SIGNAL_MII_RXCLK_SHIFT))
    #define SIGNAL_MII_RXCLK_K19		((uint32)((uint32)0x2U << SIGNAL_MII_RXCLK_SHIFT))
    #define SIGNAL_MII_RXD_0_U4		((uint32)((uint32)0x1U << SIGNAL_MII_RXD_0_SHIFT))
    #define SIGNAL_MII_RXD_0_P1		((uint32)((uint32)0x2U << SIGNAL_MII_RXD_0_SHIFT))
    #define SIGNAL_MII_RXD_1_T3		((uint32)((uint32)0x1U << SIGNAL_MII_RXD_1_SHIFT))
    #define SIGNAL_MII_RXD_1_A14		((uint32)((uint32)0x2U << SIGNAL_MII_RXD_1_SHIFT))
    #define SIGNAL_MII_RXD_2_U3		((uint32)((uint32)0x1U << SIGNAL_MII_RXD_2_SHIFT))
    #define SIGNAL_MII_RXD_2_G19		((uint32)((uint32)0x2U << SIGNAL_MII_RXD_2_SHIFT))
    #define SIGNAL_MII_RXD_3_V3		((uint32)((uint32)0x1U << SIGNAL_MII_RXD_3_SHIFT))
    #define SIGNAL_MII_RXD_3_H18		((uint32)((uint32)0x2U << SIGNAL_MII_RXD_3_SHIFT))
    #define SIGNAL_MII_TX_CLK_U7		((uint32)((uint32)0x1U << SIGNAL_MII_TX_CLK_SHIFT))
    #define SIGNAL_MII_TX_CLK_D19		((uint32)((uint32)0x2U << SIGNAL_MII_TX_CLK_SHIFT))
    #define SIGNAL_N2HET1_17_A13		((uint32)((uint32)0x1U << SIGNAL_N2HET1_17_SHIFT))
    #define SIGNAL_N2HET1_17_F3		((uint32)((uint32)0x2U << SIGNAL_N2HET1_17_SHIFT))
    #define SIGNAL_N2HET1_19_B13		((uint32)((uint32)0x1U << SIGNAL_N2HET1_19_SHIFT))
    #define SIGNAL_N2HET1_19_G3		((uint32)((uint32)0x2U << SIGNAL_N2HET1_19_SHIFT))
    #define SIGNAL_N2HET1_21_H4		((uint32)((uint32)0x1U << SIGNAL_N2HET1_21_SHIFT))
    #define SIGNAL_N2HET1_21_J3		((uint32)((uint32)0x2U << SIGNAL_N2HET1_21_SHIFT))
    #define SIGNAL_N2HET1_23_J4		((uint32)((uint32)0x1U << SIGNAL_N2HET1_23_SHIFT))
    #define SIGNAL_N2HET1_23_G19		((uint32)((uint32)0x2U << SIGNAL_N2HET1_23_SHIFT))
    #define SIGNAL_N2HET1_25_M3		((uint32)((uint32)0x1U << SIGNAL_N2HET1_25_SHIFT))
    #define SIGNAL_N2HET1_25_V5		((uint32)((uint32)0x2U << SIGNAL_N2HET1_25_SHIFT))
    #define SIGNAL_N2HET1_27_A9		((uint32)((uint32)0x1U << SIGNAL_N2HET1_27_SHIFT))
    #define SIGNAL_N2HET1_27_B2		((uint32)((uint32)0x2U << SIGNAL_N2HET1_27_SHIFT))
    #define SIGNAL_N2HET1_29_A3		((uint32)((uint32)0x1U << SIGNAL_N2HET1_29_SHIFT))
    #define SIGNAL_N2HET1_29_C3		((uint32)((uint32)0x2U << SIGNAL_N2HET1_29_SHIFT))
    #define SIGNAL_N2HET1_31_J17		((uint32)((uint32)0x1U << SIGNAL_N2HET1_31_SHIFT))
    #define SIGNAL_N2HET1_31_W9		((uint32)((uint32)0x2U << SIGNAL_N2HET1_31_SHIFT))
    #define SIGNAL_N2HET2_00_D6		((uint32)((uint32)0x1U << SIGNAL_N2HET2_00_SHIFT))
    #define SIGNAL_N2HET2_00_C1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_00_SHIFT))
    #define SIGNAL_N2HET2_01_D8		((uint32)((uint32)0x1U << SIGNAL_N2HET2_01_SHIFT))
    #define SIGNAL_N2HET2_01_D4		((uint32)((uint32)0x2U << SIGNAL_N2HET2_01_SHIFT))
    #define SIGNAL_N2HET2_02_D7		((uint32)((uint32)0x1U << SIGNAL_N2HET2_02_SHIFT))
    #define SIGNAL_N2HET2_02_E1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_02_SHIFT))
    #define SIGNAL_N2HET2_03_E2		((uint32)((uint32)0x1U << SIGNAL_N2HET2_03_SHIFT))
    #define SIGNAL_N2HET2_03_D5		((uint32)((uint32)0x2U << SIGNAL_N2HET2_03_SHIFT))
    #define SIGNAL_N2HET2_04_D13		((uint32)((uint32)0x1U << SIGNAL_N2HET2_04_SHIFT))
    #define SIGNAL_N2HET2_04_H3		((uint32)((uint32)0x2U << SIGNAL_N2HET2_04_SHIFT))
    #define SIGNAL_N2HET2_05_D12		((uint32)((uint32)0x1U << SIGNAL_N2HET2_05_SHIFT))
    #define SIGNAL_N2HET2_05_D16		((uint32)((uint32)0x2U << SIGNAL_N2HET2_05_SHIFT))
    #define SIGNAL_N2HET2_06_D11		((uint32)((uint32)0x1U << SIGNAL_N2HET2_06_SHIFT))
    #define SIGNAL_N2HET2_06_M1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_06_SHIFT))
    #define SIGNAL_N2HET2_07_N3		((uint32)((uint32)0x1U << SIGNAL_N2HET2_07_SHIFT))
    #define SIGNAL_N2HET2_07_N17		((uint32)((uint32)0x2U << SIGNAL_N2HET2_07_SHIFT))
    #define SIGNAL_N2HET2_08_K16		((uint32)((uint32)0x1U << SIGNAL_N2HET2_08_SHIFT))
    #define SIGNAL_N2HET2_08_V2		((uint32)((uint32)0x2U << SIGNAL_N2HET2_08_SHIFT))
    #define SIGNAL_N2HET2_09_L16		((uint32)((uint32)0x1U << SIGNAL_N2HET2_09_SHIFT))
    #define SIGNAL_N2HET2_09_K17		((uint32)((uint32)0x2U << SIGNAL_N2HET2_09_SHIFT))
    #define SIGNAL_N2HET2_10_M16		((uint32)((uint32)0x1U << SIGNAL_N2HET2_10_SHIFT))
    #define SIGNAL_N2HET2_10_U1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_10_SHIFT))
    #define SIGNAL_N2HET2_11_N16		((uint32)((uint32)0x1U << SIGNAL_N2HET2_11_SHIFT))
    #define SIGNAL_N2HET2_11_C4		((uint32)((uint32)0x2U << SIGNAL_N2HET2_11_SHIFT))
    #define SIGNAL_N2HET2_12_D3		((uint32)((uint32)0x1U << SIGNAL_N2HET2_12_SHIFT))
    #define SIGNAL_N2HET2_12_V6		((uint32)((uint32)0x2U << SIGNAL_N2HET2_12_SHIFT))
    #define SIGNAL_N2HET2_13_D2		((uint32)((uint32)0x1U << SIGNAL_N2HET2_13_SHIFT))
    #define SIGNAL_N2HET2_13_C5		((uint32)((uint32)0x2U << SIGNAL_N2HET2_13_SHIFT))
    #define SIGNAL_N2HET2_14_D1		((uint32)((uint32)0x1U << SIGNAL_N2HET2_14_SHIFT))
    #define SIGNAL_N2HET2_14_T1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_14_SHIFT))
    #define SIGNAL_N2HET2_15_K4		((uint32)((uint32)0x1U << SIGNAL_N2HET2_15_SHIFT))
    #define SIGNAL_N2HET2_15_C6		((uint32)((uint32)0x2U << SIGNAL_N2HET2_15_SHIFT))
    #define SIGNAL_N2HET2_16_L4		((uint32)((uint32)0x1U << SIGNAL_N2HET2_16_SHIFT))
    #define SIGNAL_N2HET2_16_V7		((uint32)((uint32)0x2U << SIGNAL_N2HET2_16_SHIFT))
    #define SIGNAL_N2HET2_18_N4		((uint32)((uint32)0x1U << SIGNAL_N2HET2_18_SHIFT))
    #define SIGNAL_N2HET2_18_E3		((uint32)((uint32)0x2U << SIGNAL_N2HET2_18_SHIFT))
    #define SIGNAL_N2HET2_20_T5		((uint32)((uint32)0x1U << SIGNAL_N2HET2_20_SHIFT))
    #define SIGNAL_N2HET2_20_N2		((uint32)((uint32)0x2U << SIGNAL_N2HET2_20_SHIFT))
    #define SIGNAL_N2HET2_22_T7		((uint32)((uint32)0x1U << SIGNAL_N2HET2_22_SHIFT))
    #define SIGNAL_N2HET2_22_N1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_22_SHIFT))
    #define SIGNAL_nTZ1_1_N19		((uint32)((uint32)0x1U << SIGNAL_nTZ1_1_SHIFT))
    #define SIGNAL_nTZ1_1_C3		((uint32)((uint32)0x2U << SIGNAL_nTZ1_1_SHIFT))
    #define SIGNAL_nTZ1_2_F1		((uint32)((uint32)0x1U << SIGNAL_nTZ1_2_SHIFT))
    #define SIGNAL_nTZ1_2_B2		((uint32)((uint32)0x2U << SIGNAL_nTZ1_2_SHIFT))
    #define SIGNAL_nTZ1_3_J3		((uint32)((uint32)0x1U << SIGNAL_nTZ1_3_SHIFT))
    #define SIGNAL_nTZ1_3_D19		((uint32)((uint32)0x2U << SIGNAL_nTZ1_3_SHIFT))
    /** @fn void muxInit(void)
    *   @brief Initializes the PINMUX Driver
    *   This function initializes the PINMUX module and configures the selected
    *   pinmux settings as per the user selection in the GUI
    void muxInit(void);
    /* USER CODE BEGIN (1) */
    /* USER CODE END */
    #ifdef __cplusplus
    #endif /*extern "C" */
    #endif
  • Hi I have added the pinmux code, but I believe its correct and selected correctly in halcogen.
    /** @file HL_pinmux.h
    *   @brief PINMUX Driver Implementation File
    *   @date 11-Dec-2018
    *   @version 04.07.01
    * Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
    *  Redistribution and use in source and binary forms, with or without
    *  modification, are permitted provided that the following conditions
    *  are met:
    *    Redistributions of source code must retain the above copyright
    *    Redistributions in binary form must reproduce the above copyright
    *    documentation and/or other materials provided with the
    *    distribution.
    *    Neither the name of Texas Instruments Incorporated nor the names of
    *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #ifndef __PINMUX_H__
    #define __PINMUX_H__
    #include "HL_reg_pinmux.h"
    #ifdef __cplusplus
    extern "C" {
    #endif
    /* USER CODE BEGIN (0) */
    /* USER CODE END */
    #define PINMUX_BALL_N19_SHIFT    0U
    #define PINMUX_BALL_D4_SHIFT    8U
    #define PINMUX_BALL_D5_SHIFT    16U
    #define PINMUX_BALL_C4_SHIFT    24U
    #define PINMUX_BALL_C5_SHIFT    0U
    #define PINMUX_BALL_C6_SHIFT    8U
    #define PINMUX_BALL_C7_SHIFT    16U
    #define PINMUX_BALL_C8_SHIFT    24U
    #define PINMUX_BALL_C9_SHIFT    0U
    #define PINMUX_BALL_C10_SHIFT    8U
    #define PINMUX_BALL_C11_SHIFT    16U
    #define PINMUX_BALL_C12_SHIFT    24U
    #define PINMUX_BALL_C13_SHIFT    0U
    #define PINMUX_BALL_D14_SHIFT    8U
    #define PINMUX_BALL_C14_SHIFT    16U
    #define PINMUX_BALL_D15_SHIFT    24U
    #define PINMUX_BALL_C15_SHIFT    0U
    #define PINMUX_BALL_C16_SHIFT    8U
    #define PINMUX_BALL_C17_SHIFT    16U
    #define PINMUX_BALL_D16_SHIFT    24U
    #define PINMUX_BALL_K3_SHIFT    0U
    #define PINMUX_BALL_R4_SHIFT    8U
    #define PINMUX_BALL_N17_SHIFT    16U
    #define PINMUX_BALL_L17_SHIFT    24U
    #define PINMUX_BALL_K17_SHIFT    0U
    #define PINMUX_BALL_M17_SHIFT    8U
    #define PINMUX_BALL_R3_SHIFT    16U
    #define PINMUX_BALL_P3_SHIFT    24U
    #define PINMUX_BALL_D17_SHIFT    0U
    #define PINMUX_BALL_E9_SHIFT    8U
    #define PINMUX_BALL_E8_SHIFT    16U
    #define PINMUX_BALL_E7_SHIFT    24U
    #define PINMUX_BALL_E6_SHIFT    0U
    #define PINMUX_BALL_E13_SHIFT    8U
    #define PINMUX_BALL_E12_SHIFT    16U
    #define PINMUX_BALL_E11_SHIFT    24U
    #define PINMUX_BALL_E10_SHIFT    0U
    #define PINMUX_BALL_K15_SHIFT    8U
    #define PINMUX_BALL_L15_SHIFT    16U
    #define PINMUX_BALL_M15_SHIFT    24U
    #define PINMUX_BALL_N15_SHIFT    0U
    #define PINMUX_BALL_E5_SHIFT    8U
    #define PINMUX_BALL_F5_SHIFT    16U
    #define PINMUX_BALL_G5_SHIFT    24U
    #define PINMUX_BALL_K5_SHIFT    0U
    #define PINMUX_BALL_L5_SHIFT    8U
    #define PINMUX_BALL_M5_SHIFT    16U
    #define PINMUX_BALL_N5_SHIFT    24U
    #define PINMUX_BALL_P5_SHIFT    0U
    #define PINMUX_BALL_R5_SHIFT    8U
    #define PINMUX_BALL_R6_SHIFT    16U
    #define PINMUX_BALL_R7_SHIFT    24U
    #define PINMUX_BALL_R8_SHIFT    0U
    #define PINMUX_BALL_R9_SHIFT    8U
    #define PINMUX_BALL_R10_SHIFT    16U
    #define PINMUX_BALL_R11_SHIFT    24U
    #define PINMUX_BALL_B15_SHIFT    0U
    #define PINMUX_BALL_B8_SHIFT    8U
    #define PINMUX_BALL_B16_SHIFT    16U
    #define PINMUX_BALL_B9_SHIFT    24U
    #define PINMUX_BALL_C1_SHIFT    0U
    #define PINMUX_BALL_E1_SHIFT    8U
    #define PINMUX_BALL_B5_SHIFT    16U
    #define PINMUX_BALL_H3_SHIFT    24U
    #define PINMUX_BALL_M1_SHIFT    0U
    #define PINMUX_BALL_F2_SHIFT    8U
    #define PINMUX_BALL_W10_SHIFT    16U
    #define PINMUX_BALL_J2_SHIFT    24U
    #define PINMUX_BALL_F1_SHIFT    0U
    #define PINMUX_BALL_R2_SHIFT    8U
    #define PINMUX_BALL_F3_SHIFT    16U
    #define PINMUX_BALL_G3_SHIFT    24U
    #define PINMUX_BALL_J3_SHIFT    0U
    #define PINMUX_BALL_G19_SHIFT    8U
    #define PINMUX_BALL_V9_SHIFT    16U
    #define PINMUX_BALL_V10_SHIFT    24U
    #define PINMUX_BALL_V5_SHIFT    0U
    #define PINMUX_BALL_B2_SHIFT    8U
    #define PINMUX_BALL_C3_SHIFT    16U
    #define PINMUX_BALL_W9_SHIFT    24U
    #define PINMUX_BALL_W8_SHIFT    0U
    #define PINMUX_BALL_V8_SHIFT    8U
    #define PINMUX_BALL_H19_SHIFT    16U
    #define PINMUX_BALL_E19_SHIFT    24U
    #define PINMUX_BALL_B6_SHIFT    0U
    #define PINMUX_BALL_W6_SHIFT    8U
    #define PINMUX_BALL_T12_SHIFT    16U
    #define PINMUX_BALL_H18_SHIFT    24U
    #define PINMUX_BALL_J19_SHIFT    0U
    #define PINMUX_BALL_E16_SHIFT    8U
    #define PINMUX_BALL_H17_SHIFT    16U
    #define PINMUX_BALL_G17_SHIFT    24U
    #define PINMUX_BALL_J18_SHIFT    0U
    #define PINMUX_BALL_E17_SHIFT    8U
    #define PINMUX_BALL_H16_SHIFT    16U
    #define PINMUX_BALL_G16_SHIFT    24U
    #define PINMUX_BALL_K18_SHIFT    0U
    #define PINMUX_BALL_V2_SHIFT    8U
    #define PINMUX_BALL_W5_SHIFT    16U
    #define PINMUX_BALL_U1_SHIFT    24U
    #define PINMUX_BALL_B12_SHIFT    0U
    #define PINMUX_BALL_V6_SHIFT    8U
    #define PINMUX_BALL_W3_SHIFT    16U
    #define PINMUX_BALL_T1_SHIFT    24U
    #define PINMUX_BALL_E18_SHIFT    0U
    #define PINMUX_BALL_V7_SHIFT    8U
    #define PINMUX_BALL_D19_SHIFT    16U
    #define PINMUX_BALL_E3_SHIFT    24U
    #define PINMUX_BALL_B4_SHIFT    0U
    #define PINMUX_BALL_N2_SHIFT    8U
    #define PINMUX_BALL_N1_SHIFT    16U
    #define PINMUX_BALL_A4_SHIFT    24U
    #define PINMUX_BALL_A13_SHIFT    0U
    #define PINMUX_BALL_J1_SHIFT    8U
    #define PINMUX_BALL_B13_SHIFT    16U
    #define PINMUX_BALL_P2_SHIFT    24U
    #define PINMUX_BALL_H4_SHIFT    0U
    #define PINMUX_BALL_B3_SHIFT    8U
    #define PINMUX_BALL_J4_SHIFT    16U
    #define PINMUX_BALL_P1_SHIFT    24U
    #define PINMUX_BALL_A14_SHIFT    0U
    #define PINMUX_BALL_K19_SHIFT    8U
    #define PINMUX_BALL_B11_SHIFT    16U
    #define PINMUX_BALL_D8_SHIFT    24U
    #define PINMUX_BALL_D7_SHIFT    0U
    #define PINMUX_BALL_D3_SHIFT    8U
    #define PINMUX_BALL_D2_SHIFT    16U
    #define PINMUX_BALL_D1_SHIFT    24U
    #define PINMUX_BALL_P4_SHIFT    0U
    #define PINMUX_BALL_T5_SHIFT    8U
    #define PINMUX_BALL_T4_SHIFT    16U
    #define PINMUX_BALL_U7_SHIFT    24U
    #define PINMUX_BALL_E2_SHIFT    0U
    #define PINMUX_BALL_N3_SHIFT    8U
    #define PINMUX_GATE_EMIF_CLK_SHIFT              0U
    #define PINMUX_EMIF_OUTPUT_ENABLE_SHIFT			8U
    #define PINMUX_GIOA_DISABLE_HET1_SHIFT          8U
    #define PINMUX_GIOB_DISABLE_HET2_SHIFT          0U
    #define PINMUX_ALT_ADC_TRIGGER_SHIFT            0U
    #define PINMUX_ETHERNET_SHIFT                   24U
    #define PINMUX_ETPWM1_SHIFT                      0U
    #define PINMUX_ETPWM2_SHIFT                      8U
    #define PINMUX_ETPWM3_SHIFT                      16U
    #define PINMUX_ETPWM4_SHIFT                      24U
    #define PINMUX_ETPWM5_SHIFT                      0U
    #define PINMUX_ETPWM6_SHIFT                      8U
    #define PINMUX_ETPWM7_SHIFT                      16U
    #define PINMUX_ETPWM_TIME_BASE_SYNC_SHIFT        24U
    #define PINMUX_ETPWM_TBCLK_SYNC_SHIFT            0U
    #define PINMUX_TZ1_SHIFT                        16U
    #define PINMUX_TZ2_SHIFT                        24U
    #define PINMUX_TZ3_SHIFT                        0U
    #define PINMUX_EPWM1SYNCI_SHIFT                 8U
    #define PINMUX_ETPWM_SOC1A_SHIFT                0U
    #define PINMUX_ETPWM_SOC2A_SHIFT                8U
    #define PINMUX_ETPWM_SOC3A_SHIFT                16U
    #define PINMUX_ETPWM_SOC4A_SHIFT                24U
    #define PINMUX_ETPWM_SOC5A_SHIFT                0U
    #define PINMUX_ETPWM_SOC6A_SHIFT                8U
    #define PINMUX_ETPWM_SOC7A_SHIFT                16U
    #define PINMUX_EQEP1A_FILTER_SHIFT              16U
    #define PINMUX_EQEP1B_FILTER_SHIFT              24U
    #define PINMUX_EQEP1I_FILTER_SHIFT              0U
    #define PINMUX_EQEP1S_FILTER_SHIFT              8U
    #define PINMUX_EQEP2A_FILTER_SHIFT              16U
    #define PINMUX_EQEP2B_FILTER_SHIFT              24U
    #define PINMUX_EQEP2I_FILTER_SHIFT              0U
    #define PINMUX_EQEP2S_FILTER_SHIFT              8U
    #define PINMUX_ECAP1_FILTER_SHIFT              0U
    #define PINMUX_ECAP2_FILTER_SHIFT              8U
    #define PINMUX_ECAP3_FILTER_SHIFT              16U
    #define PINMUX_ECAP4_FILTER_SHIFT              24U
    #define PINMUX_ECAP5_FILTER_SHIFT              0U
    #define PINMUX_ECAP6_FILTER_SHIFT              8U
    #define PINMUX_GIOA0_DMA_SHIFT             	   0U
    #define PINMUX_GIOA1_DMA_SHIFT             	   8U
    #define PINMUX_GIOA2_DMA_SHIFT             	   16U
    #define PINMUX_GIOA3_DMA_SHIFT             	   24U
    #define PINMUX_GIOA4_DMA_SHIFT             	   0U
    #define PINMUX_GIOA5_DMA_SHIFT             	   8U
    #define PINMUX_GIOA6_DMA_SHIFT             	   16U
    #define PINMUX_GIOA7_DMA_SHIFT             	   24U
    #define PINMUX_GIOB0_DMA_SHIFT             	   0U
    #define PINMUX_GIOB1_DMA_SHIFT             	   8U
    #define PINMUX_GIOB2_DMA_SHIFT             	   16U
    #define PINMUX_GIOB3_DMA_SHIFT             	   24U
    #define PINMUX_GIOB4_DMA_SHIFT             	   0U
    #define PINMUX_GIOB5_DMA_SHIFT             	   8U
    #define PINMUX_GIOB6_DMA_SHIFT             	   16U
    #define PINMUX_GIOB7_DMA_SHIFT             	   24U
    #define PINMUX_TEMP1_ENABLE_SHIFT              16U
    #define PINMUX_TEMP2_ENABLE_SHIFT              24U
    #define PINMUX_TEMP3_ENABLE_SHIFT              0U
    #define PINMUX_BALL_N19_MASK             (~(uint32)((uint32)uint32)((uint32)0xFFU << PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_D4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D4_SHIFT))
    #define PINMUX_BALL_D5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D5_SHIFT))
    #define PINMUX_BALL_C4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C4_SHIFT))
    #define PINMUX_BALL_C5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C5_SHIFT))
    #define PINMUX_BALL_C6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C6_SHIFT))
    #define PINMUX_BALL_C7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C7_SHIFT))
    #define PINMUX_BALL_C8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C8_SHIFT))
    #define PINMUX_BALL_C9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C9_SHIFT))
    #define PINMUX_BALL_C10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C10_SHIFT))
    #define PINMUX_BALL_C11_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C11_SHIFT))
    #define PINMUX_BALL_C12_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C12_SHIFT))
    #define PINMUX_BALL_C13_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C13_SHIFT))
    #define PINMUX_BALL_D14_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D14_SHIFT))
    #define PINMUX_BALL_C14_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C14_SHIFT))
    #define PINMUX_BALL_D15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D15_SHIFT))
    #define PINMUX_BALL_C15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C15_SHIFT))
    #define PINMUX_BALL_C16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C16_SHIFT))
    #define PINMUX_BALL_C17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C17_SHIFT))
    #define PINMUX_BALL_D16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D16_SHIFT))
    #define PINMUX_BALL_K3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K3_SHIFT))
    #define PINMUX_BALL_R4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R4_SHIFT))
    #define PINMUX_BALL_N17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N17_SHIFT))
    #define PINMUX_BALL_L17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_L17_SHIFT))
    #define PINMUX_BALL_K17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K17_SHIFT))
    #define PINMUX_BALL_M17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_M17_SHIFT))
    #define PINMUX_BALL_R3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R3_SHIFT))
    #define PINMUX_BALL_P3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P3_SHIFT))
    #define PINMUX_BALL_D17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D17_SHIFT))
    #define PINMUX_BALL_E9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E9_SHIFT))
    #define PINMUX_BALL_E8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E8_SHIFT))
    #define PINMUX_BALL_E7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E7_SHIFT))
    #define PINMUX_BALL_E6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E6_SHIFT))
    #define PINMUX_BALL_E13_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E13_SHIFT))
    #define PINMUX_BALL_E12_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E12_SHIFT))
    #define PINMUX_BALL_E11_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E11_SHIFT))
    #define PINMUX_BALL_E10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E10_SHIFT))
    #define PINMUX_BALL_K15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K15_SHIFT))
    #define PINMUX_BALL_L15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_L15_SHIFT))
    #define PINMUX_BALL_M15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_M15_SHIFT))
    #define PINMUX_BALL_N15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N15_SHIFT))
    #define PINMUX_BALL_E5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E5_SHIFT))
    #define PINMUX_BALL_F5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_F5_SHIFT))
    #define PINMUX_BALL_G5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G5_SHIFT))
    #define PINMUX_BALL_K5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K5_SHIFT))
    #define PINMUX_BALL_L5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_M5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_N5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N5_SHIFT))
    #define PINMUX_BALL_P5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P5_SHIFT))
    #define PINMUX_BALL_R5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R9_SHIFT))
    #define PINMUX_BALL_R10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R10_SHIFT))
    #define PINMUX_BALL_R11_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R11_SHIFT))
    #define PINMUX_BALL_B15_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B15_SHIFT))
    #define PINMUX_BALL_B8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B8_SHIFT))
    #define PINMUX_BALL_B16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B16_SHIFT))
    #define PINMUX_BALL_B9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B9_SHIFT))
    #define PINMUX_BALL_C1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C1_SHIFT))
    #define PINMUX_BALL_E1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E1_SHIFT))
    #define PINMUX_BALL_B5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B5_SHIFT))
    #define PINMUX_BALL_H3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H3_SHIFT))
    #define PINMUX_BALL_M1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_M1_SHIFT))
    #define PINMUX_BALL_F2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_F2_SHIFT))
    #define PINMUX_BALL_W10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W10_SHIFT))
    #define PINMUX_BALL_J2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J2_SHIFT))
    #define PINMUX_BALL_F1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_F1_SHIFT))
    #define PINMUX_BALL_R2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_F3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_G3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G3_SHIFT))
    #define PINMUX_BALL_J3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J3_SHIFT))
    #define PINMUX_BALL_G19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_V9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V9_SHIFT))
    #define PINMUX_BALL_V10_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V10_SHIFT))
    #define PINMUX_BALL_V5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V5_SHIFT))
    #define PINMUX_BALL_B2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_C3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_W9_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W8_SHIFT))
    #define PINMUX_BALL_V8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V8_SHIFT))
    #define PINMUX_BALL_H19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_E19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E19_SHIFT))
    #define PINMUX_BALL_B6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B6_SHIFT))
    #define PINMUX_BALL_W6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W6_SHIFT))
    #define PINMUX_BALL_T12_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_T12_SHIFT))
    #define PINMUX_BALL_H18_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_J19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_E16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E16_SHIFT))
    #define PINMUX_BALL_H17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H17_SHIFT))
    #define PINMUX_BALL_G17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_J18_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_E17_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E17_SHIFT))
    #define PINMUX_BALL_H16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H16_SHIFT))
    #define PINMUX_BALL_G16_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_K18_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K18_SHIFT))
    #define PINMUX_BALL_V2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_W5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W5_SHIFT))
    #define PINMUX_BALL_U1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_B12_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B12_SHIFT))
    #define PINMUX_BALL_V6_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_W3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_W3_SHIFT))
    #define PINMUX_BALL_T1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_E18_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E18_SHIFT))
    #define PINMUX_BALL_V7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_D19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_E3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_B4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_N2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_A4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_A4_SHIFT))
    #define PINMUX_BALL_A13_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_A13_SHIFT))
    #define PINMUX_BALL_J1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J1_SHIFT))
    #define PINMUX_BALL_B13_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B13_SHIFT))
    #define PINMUX_BALL_P2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P2_SHIFT))
    #define PINMUX_BALL_H4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_H4_SHIFT))
    #define PINMUX_BALL_B3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B3_SHIFT))
    #define PINMUX_BALL_J4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_J4_SHIFT))
    #define PINMUX_BALL_P1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_A14_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_A14_SHIFT))
    #define PINMUX_BALL_K19_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_B11_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_B11_SHIFT))
    #define PINMUX_BALL_D8_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D8_SHIFT))
    #define PINMUX_BALL_D7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D7_SHIFT))
    #define PINMUX_BALL_D3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D3_SHIFT))
    #define PINMUX_BALL_D2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D2_SHIFT))
    #define PINMUX_BALL_D1_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_D1_SHIFT))
    #define PINMUX_BALL_P4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_P4_SHIFT))
    #define PINMUX_BALL_T5_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_T5_SHIFT))
    #define PINMUX_BALL_T4_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_T4_SHIFT))
    #define PINMUX_BALL_U7_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_U7_SHIFT))
    #define PINMUX_BALL_E2_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_E2_SHIFT))
    #define PINMUX_BALL_N3_MASK             (~(uint32)((uint32)0xFFU << PINMUX_BALL_N3_SHIFT))
    #define PINMUX_GATE_EMIF_CLK_MASK               (~(uint32)((uint32)0xFFU << PINMUX_GATE_EMIF_CLK_SHIFT))
    #define PINMUX_EMIF_OUTPUT_ENABLE_MASK          (~(uint32)((uint32)0xFFU << PINMUX_EMIF_OUTPUT_ENABLE_SHIFT))
    #define PINMUX_GIOA_DISABLE_HET1_MASK           (~(uint32)((uint32)0xFFU << PINMUX_GIOA_DISABLE_HET1_SHIFT))
    #define PINMUX_GIOB_DISABLE_HET2_MASK           (~(uint32)((uint32)0xFFU << PINMUX_GIOB_DISABLE_HET2_SHIFT))
    #define PINMUX_ALT_ADC_TRIGGER_MASK             (~(uint32)((uint32)0xFFU << PINMUX_ALT_ADC_TRIGGER_SHIFT))
    #define PINMUX_ETHERNET_MASK                    (~(uint32)((uint32)0xFFU << PINMUX_ETHERNET_SHIFT))
    #define PINMUX_ETPWM1_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM1_SHIFT))
    #define PINMUX_ETPWM2_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM2_SHIFT))
    #define PINMUX_ETPWM3_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM3_SHIFT))
    #define PINMUX_ETPWM4_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM4_SHIFT))
    #define PINMUX_ETPWM5_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM5_SHIFT))
    #define PINMUX_ETPWM6_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM6_SHIFT))
    #define PINMUX_ETPWM7_MASK                      (~(uint32)((uint32)0xFFU << PINMUX_ETPWM7_SHIFT))
    #define PINMUX_ETPWM_TIME_BASE_SYNC_MASK        (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_TIME_BASE_SYNC_SHIFT))
    #define PINMUX_ETPWM_TBCLK_SYNC_MASK           (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_TBCLK_SYNC_SHIFT))
    #define PINMUX_TZ1_MASK                        (~(uint32)((uint32)0xFFU << PINMUX_TZ1_SHIFT))
    #define PINMUX_TZ2_MASK                        (~(uint32)((uint32)0xFFU << PINMUX_TZ2_SHIFT))
    #define PINMUX_TZ3_MASK                        (~(uint32)((uint32)0xFFU << PINMUX_TZ3_SHIFT))
    #define PINMUX_EPWM1SYNCI_MASK                 (~(uint32)((uint32)0xFFU << PINMUX_EPWM1SYNCI_SHIFT))
    #define PINMUX_ETPWM_SOC1A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC1A_SHIFT))
    #define PINMUX_ETPWM_SOC2A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC2A_SHIFT))
    #define PINMUX_ETPWM_SOC3A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC3A_SHIFT))
    #define PINMUX_ETPWM_SOC4A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC4A_SHIFT))
    #define PINMUX_ETPWM_SOC5A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC5A_SHIFT))
    #define PINMUX_ETPWM_SOC6A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC6A_SHIFT))
    #define PINMUX_ETPWM_SOC7A_MASK                (~(uint32)((uint32)0xFFU << PINMUX_ETPWM_SOC7A_SHIFT))
    #define PINMUX_EQEP1A_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP1A_FILTER_SHIFT))
    #define PINMUX_EQEP1B_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP1B_FILTER_SHIFT))
    #define PINMUX_EQEP1I_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP1I_FILTER_SHIFT))
    #define PINMUX_EQEP1S_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP1S_FILTER_SHIFT))
    #define PINMUX_EQEP2A_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP2A_FILTER_SHIFT))
    #define PINMUX_EQEP2B_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP2B_FILTER_SHIFT))
    #define PINMUX_EQEP2I_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP2I_FILTER_SHIFT))
    #define PINMUX_EQEP2S_FILTER_MASK              (~(uint32)((uint32)0xFFU << PINMUX_EQEP2S_FILTER_SHIFT))
    #define PINMUX_ECAP1_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP1_FILTER_SHIFT))
    #define PINMUX_ECAP2_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP2_FILTER_SHIFT))
    #define PINMUX_ECAP3_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP3_FILTER_SHIFT))
    #define PINMUX_ECAP4_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP4_FILTER_SHIFT))
    #define PINMUX_ECAP5_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP5_FILTER_SHIFT))
    #define PINMUX_ECAP6_FILTER_MASK               (~(uint32)((uint32)0xFFU << PINMUX_ECAP6_FILTER_SHIFT))
    #define PINMUX_GIOA0_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA0_DMA_SHIFT))
    #define PINMUX_GIOA1_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA1_DMA_SHIFT))
    #define PINMUX_GIOA2_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA2_DMA_SHIFT))
    #define PINMUX_GIOA3_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA3_DMA_SHIFT))
    #define PINMUX_GIOA4_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA4_DMA_SHIFT))
    #define PINMUX_GIOA5_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA5_DMA_SHIFT))
    #define PINMUX_GIOA6_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA6_DMA_SHIFT))
    #define PINMUX_GIOA7_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOA7_DMA_SHIFT))
    #define PINMUX_GIOB0_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB0_DMA_SHIFT))
    #define PINMUX_GIOB1_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB1_DMA_SHIFT))
    #define PINMUX_GIOB2_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB2_DMA_SHIFT))
    #define PINMUX_GIOB3_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB3_DMA_SHIFT))
    #define PINMUX_GIOB4_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB4_DMA_SHIFT))
    #define PINMUX_GIOB5_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB5_DMA_SHIFT))
    #define PINMUX_GIOB6_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB6_DMA_SHIFT))
    #define PINMUX_GIOB7_DMA_MASK                  (~(uint32)((uint32)0xFFU << PINMUX_GIOB7_DMA_SHIFT))
    #define PINMUX_TEMP1_ENABLE_MASK               (~(uint32)((uint32)0xFFU << PINMUX_TEMP1_ENABLE_SHIFT))
    #define PINMUX_TEMP2_ENABLE_MASK               (~(uint32)((uint32)0xFFU << PINMUX_TEMP2_ENABLE_SHIFT))
    #define PINMUX_TEMP3_ENABLE_MASK               (~(uint32)((uint32)0xFFU << PINMUX_TEMP3_ENABLE_SHIFT))
    #define PINMUX_BALL_N19_AD1EVT                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_N19_MII_RX_ER                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_N19_RMII_RX_ER                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_N19_nTZ1_1                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_N19_SHIFT))
    #define PINMUX_BALL_D4_EMIF_ADDR_00                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D4_SHIFT))
    #define PINMUX_BALL_D4_N2HET2_01                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_D4_SHIFT))
    #define PINMUX_BALL_D5_EMIF_ADDR_01                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D5_SHIFT))
    #define PINMUX_BALL_D5_N2HET2_03                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_D5_SHIFT))
    #define PINMUX_BALL_C4_EMIF_ADDR_06                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C4_SHIFT))
    #define PINMUX_BALL_C4_RTP_DATA_13                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C4_SHIFT))
    #define PINMUX_BALL_C4_N2HET2_11                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_C4_SHIFT))
    #define PINMUX_BALL_C5_EMIF_ADDR_07                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C5_SHIFT))
    #define PINMUX_BALL_C5_RTP_DATA_12                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C5_SHIFT))
    #define PINMUX_BALL_C5_N2HET2_13                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_C5_SHIFT))
    #define PINMUX_BALL_C6_EMIF_ADDR_08                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C6_SHIFT))
    #define PINMUX_BALL_C6_RTP_DATA_11                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C6_SHIFT))
    #define PINMUX_BALL_C6_N2HET2_15                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_C6_SHIFT))
    #define PINMUX_BALL_C7_EMIF_ADDR_09                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C7_SHIFT))
    #define PINMUX_BALL_C7_RTP_DATA_10                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C7_SHIFT))
    #define PINMUX_BALL_C8_EMIF_ADDR_10                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C8_SHIFT))
    #define PINMUX_BALL_C8_RTP_DATA_09                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C8_SHIFT))
    #define PINMUX_BALL_C9_EMIF_ADDR_11                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C9_SHIFT))
    #define PINMUX_BALL_C9_RTP_DATA_08                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C9_SHIFT))
    #define PINMUX_BALL_C10_EMIF_ADDR_12                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C10_SHIFT))
    #define PINMUX_BALL_C10_RTP_DATA_06                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C10_SHIFT))
    #define PINMUX_BALL_C11_EMIF_ADDR_13                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C11_SHIFT))
    #define PINMUX_BALL_C11_RTP_DATA_05                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C11_SHIFT))
    #define PINMUX_BALL_C12_EMIF_ADDR_14                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C12_SHIFT))
    #define PINMUX_BALL_C12_RTP_DATA_04                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C12_SHIFT))
    #define PINMUX_BALL_C13_EMIF_ADDR_15                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C13_SHIFT))
    #define PINMUX_BALL_C13_RTP_DATA_03                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C13_SHIFT))
    #define PINMUX_BALL_D14_EMIF_ADDR_16                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D14_SHIFT))
    #define PINMUX_BALL_D14_RTP_DATA_02                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D14_SHIFT))
    #define PINMUX_BALL_C14_EMIF_ADDR_17                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C14_SHIFT))
    #define PINMUX_BALL_C14_RTP_DATA_01                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C14_SHIFT))
    #define PINMUX_BALL_D15_EMIF_ADDR_18                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D15_SHIFT))
    #define PINMUX_BALL_D15_RTP_DATA_00                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D15_SHIFT))
    #define PINMUX_BALL_C15_EMIF_ADDR_19                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C15_SHIFT))
    #define PINMUX_BALL_C15_RTP_nENA                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C15_SHIFT))
    #define PINMUX_BALL_C16_EMIF_ADDR_20                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C16_SHIFT))
    #define PINMUX_BALL_C16_RTP_nSYNC                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C16_SHIFT))
    #define PINMUX_BALL_C17_EMIF_ADDR_21                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C17_SHIFT))
    #define PINMUX_BALL_C17_RTP_CLK                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C17_SHIFT))
    #define PINMUX_BALL_D16_EMIF_BA_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D16_SHIFT))
    #define PINMUX_BALL_D16_8_25                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D16_SHIFT))
    #define PINMUX_BALL_D16_N2HET2_05                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_D16_SHIFT))
    #define PINMUX_BALL_K3_RESERVED                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K3_SHIFT))
    #define PINMUX_BALL_K3_EMIF_CLK                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K3_SHIFT))
    #define PINMUX_BALL_K3_ECLK2                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_K3_SHIFT))
    #define PINMUX_BALL_R4_EMIF_nCAS                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R4_SHIFT))
    #define PINMUX_BALL_R4_GIOB_3                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R4_SHIFT))
    #define PINMUX_BALL_N17_EMIF_nCS_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N17_SHIFT))
    #define PINMUX_BALL_N17_RTP_DATA_15                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N17_SHIFT))
    #define PINMUX_BALL_N17_N2HET2_07                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_N17_SHIFT))
    #define PINMUX_BALL_L17_EMIF_nCS_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_L17_SHIFT))
    #define PINMUX_BALL_L17_GIOB_4                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_L17_SHIFT))
    #define PINMUX_BALL_K17_EMIF_nCS_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K17_SHIFT))
    #define PINMUX_BALL_K17_RTP_DATA_14                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K17_SHIFT))
    #define PINMUX_BALL_K17_N2HET2_09                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_K17_SHIFT))
    #define PINMUX_BALL_M17_EMIF_nCS_4                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_M17_SHIFT))
    #define PINMUX_BALL_M17_RTP_DATA_07                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_M17_SHIFT))
    #define PINMUX_BALL_M17_GIOB_5                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_M17_SHIFT))
    #define PINMUX_BALL_R3_EMIF_nRAS                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R3_SHIFT))
    #define PINMUX_BALL_R3_GIOB_6                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R3_SHIFT))
    #define PINMUX_BALL_P3_EMIF_nWAIT                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P3_SHIFT))
    #define PINMUX_BALL_P3_GIOB_7                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_P3_SHIFT))
    #define PINMUX_BALL_D17_EMIF_nWE                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D17_SHIFT))
    #define PINMUX_BALL_D17_EMIF_RNW                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D17_SHIFT))
    #define PINMUX_BALL_E9_ETMDATA_08                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E9_SHIFT))
    #define PINMUX_BALL_E9_EMIF_ADDR_05                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E9_SHIFT))
    #define PINMUX_BALL_E8_ETMDATA_09                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E8_SHIFT))
    #define PINMUX_BALL_E8_EMIF_ADDR_04                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E8_SHIFT))
    #define PINMUX_BALL_E7_ETMDATA_10                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E7_SHIFT))
    #define PINMUX_BALL_E7_EMIF_ADDR_03                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E7_SHIFT))
    #define PINMUX_BALL_E6_ETMDATA_11                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E6_SHIFT))
    #define PINMUX_BALL_E6_EMIF_ADDR_02                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E6_SHIFT))
    #define PINMUX_BALL_E13_ETMDATA_12                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E13_SHIFT))
    #define PINMUX_BALL_E13_EMIF_BA_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E13_SHIFT))
    #define PINMUX_BALL_E12_ETMDATA_13                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E12_SHIFT))
    #define PINMUX_BALL_E12_EMIF_nOE                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E12_SHIFT))
    #define PINMUX_BALL_E11_ETMDATA_14                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E11_SHIFT))
    #define PINMUX_BALL_E11_EMIF_nDQM_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E11_SHIFT))
    #define PINMUX_BALL_E10_ETMDATA_15                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E10_SHIFT))
    #define PINMUX_BALL_E10_EMIF_nDQM_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E10_SHIFT))
    #define PINMUX_BALL_K15_ETMDATA_16                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K15_SHIFT))
    #define PINMUX_BALL_K15_EMIF_DATA_00                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K15_SHIFT))
    #define PINMUX_BALL_L15_ETMDATA_17                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_L15_SHIFT))
    #define PINMUX_BALL_L15_EMIF_DATA_01                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_L15_SHIFT))
    #define PINMUX_BALL_M15_ETMDATA_18                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_M15_SHIFT))
    #define PINMUX_BALL_M15_EMIF_DATA_02                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_M15_SHIFT))
    #define PINMUX_BALL_N15_ETMDATA_19                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N15_SHIFT))
    #define PINMUX_BALL_N15_EMIF_DATA_03                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N15_SHIFT))
    #define PINMUX_BALL_E5_ETMDATA_20                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E5_SHIFT))
    #define PINMUX_BALL_E5_EMIF_DATA_04                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E5_SHIFT))
    #define PINMUX_BALL_F5_ETMDATA_21                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_F5_SHIFT))
    #define PINMUX_BALL_F5_EMIF_DATA_05                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_F5_SHIFT))
    #define PINMUX_BALL_G5_ETMDATA_22                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G5_SHIFT))
    #define PINMUX_BALL_G5_EMIF_DATA_06                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_G5_SHIFT))
    #define PINMUX_BALL_K5_ETMDATA_23                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K5_SHIFT))
    #define PINMUX_BALL_K5_EMIF_DATA_07                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K5_SHIFT))
    #define PINMUX_BALL_L5_ETMDATA_24                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_L5_EMIF_DATA_08                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_L5_N2HET2_24                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_L5_MIBSPI5NCS_4                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_L5_SHIFT))
    #define PINMUX_BALL_M5_ETMDATA_25                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_M5_EMIF_DATA_09                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_M5_N2HET2_25                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_M5_MIBSPI5NCS_5                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_M5_SHIFT))
    #define PINMUX_BALL_N5_ETMDATA_26                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N5_SHIFT))
    #define PINMUX_BALL_N5_EMIF_DATA_10                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N5_SHIFT))
    #define PINMUX_BALL_N5_N2HET2_26                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_N5_SHIFT))
    #define PINMUX_BALL_P5_ETMDATA_27                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P5_SHIFT))
    #define PINMUX_BALL_P5_EMIF_DATA_11                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_P5_SHIFT))
    #define PINMUX_BALL_P5_N2HET2_27                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_P5_SHIFT))
    #define PINMUX_BALL_R5_ETMDATA_28                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R5_EMIF_DATA_12                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R5_N2HET2_28                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R5_GIOA_0                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R5_SHIFT))
    #define PINMUX_BALL_R6_ETMDATA_29                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R6_EMIF_DATA_13                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R6_N2HET2_29                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R6_GIOA_1                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R6_SHIFT))
    #define PINMUX_BALL_R7_ETMDATA_30                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R7_EMIF_DATA_14                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R7_N2HET2_30                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R7_GIOA_3                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R7_SHIFT))
    #define PINMUX_BALL_R8_ETMDATA_31                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R8_EMIF_DATA_15                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R8_N2HET2_31                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R8_GIOA_4                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R8_SHIFT))
    #define PINMUX_BALL_R9_ETMTRACECLKIN                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R9_SHIFT))
    #define PINMUX_BALL_R9_EXTCLKIN2                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R9_SHIFT))
    #define PINMUX_BALL_R9_GIOA_5                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R9_SHIFT))
    #define PINMUX_BALL_R10_ETMTRACECLKOUT                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R10_SHIFT))
    #define PINMUX_BALL_R10_GIOA_6                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R10_SHIFT))
    #define PINMUX_BALL_R11_ETMTRACECTL                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R11_SHIFT))
    #define PINMUX_BALL_R11_GIOA_7                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_R11_SHIFT))
    #define PINMUX_BALL_B15_FRAYTX1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B15_SHIFT))
    #define PINMUX_BALL_B15_GIOA_2                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B15_SHIFT))
    #define PINMUX_BALL_B8_FRAYTX2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B8_SHIFT))
    #define PINMUX_BALL_B8_GIOB_0                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B8_SHIFT))
    #define PINMUX_BALL_B16_FRAYTXEN1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B16_SHIFT))
    #define PINMUX_BALL_B16_GIOB_1                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B16_SHIFT))
    #define PINMUX_BALL_B9_FRAYTXEN2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B9_SHIFT))
    #define PINMUX_BALL_B9_GIOB_2                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B9_SHIFT))
    #define PINMUX_BALL_C1_GIOA_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C1_SHIFT))
    #define PINMUX_BALL_C1_N2HET2_00                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_C1_SHIFT))
    #define PINMUX_BALL_C1_eQEP2I                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_C1_SHIFT))
    #define PINMUX_BALL_E1_GIOA_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E1_SHIFT))
    #define PINMUX_BALL_E1_N2HET2_02                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_E1_SHIFT))
    #define PINMUX_BALL_B5_GIOA_5                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B5_SHIFT))
    #define PINMUX_BALL_B5_EXTCLKIN                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B5_SHIFT))
    #define PINMUX_BALL_B5_eTPWM1A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_B5_SHIFT))
    #define PINMUX_BALL_H3_GIOA_6                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H3_SHIFT))
    #define PINMUX_BALL_H3_N2HET2_04                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_H3_SHIFT))
    #define PINMUX_BALL_H3_eTPWM1B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_H3_SHIFT))
    #define PINMUX_BALL_M1_GIOA_7                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_M1_SHIFT))
    #define PINMUX_BALL_M1_N2HET2_06                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_M1_SHIFT))
    #define PINMUX_BALL_M1_eTPWM2A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_M1_SHIFT))
    #define PINMUX_BALL_F2_GIOB_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_F2_SHIFT))
    #define PINMUX_BALL_F2_DCAN4TX                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_F2_SHIFT))
    #define PINMUX_BALL_W10_GIOB_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W10_SHIFT))
    #define PINMUX_BALL_W10_DCAN4RX                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_W10_SHIFT))
    #define PINMUX_BALL_J2_GIOB_6                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J2_SHIFT))
    #define PINMUX_BALL_J2_nERROR1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J2_SHIFT))
    #define PINMUX_BALL_F1_GIOB_7                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_F1_SHIFT))
    #define PINMUX_BALL_F1_nERROR2                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_F1_SHIFT))
    #define PINMUX_BALL_F1_nTZ1_2                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_F1_SHIFT))
    #define PINMUX_BALL_R2_MIBSPI1NCS_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_R2_MIBSPI1SOMI_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_R2_MII_TXD_2                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_R2_ECAP6                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_R2_SHIFT))
    #define PINMUX_BALL_F3_MIBSPI1NCS_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_F3_MII_COL                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_F3_N2HET1_17                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_F3_eQEP1S                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_F3_SHIFT))
    #define PINMUX_BALL_G3_MIBSPI1NCS_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G3_SHIFT))
    #define PINMUX_BALL_G3_MDIO                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_G3_SHIFT))
    #define PINMUX_BALL_G3_N2HET1_19                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_G3_SHIFT))
    #define PINMUX_BALL_J3_MIBSPI1NCS_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J3_SHIFT))
    #define PINMUX_BALL_J3_N2HET1_21                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_J3_SHIFT))
    #define PINMUX_BALL_J3_nTZ1_3                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_J3_SHIFT))
    #define PINMUX_BALL_G19_MIBSPI1NENA                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_G19_MII_RXD_2                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_G19_N2HET1_23                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_G19_ECAP4                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_G19_SHIFT))
    #define PINMUX_BALL_V9_MIBSPI3CLK                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V9_SHIFT))
    #define PINMUX_BALL_V9_EXT_SEL_01                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V9_SHIFT))
    #define PINMUX_BALL_V9_eQEP1A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V9_SHIFT))
    #define PINMUX_BALL_V10_MIBSPI3NCS_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V10_SHIFT))
    #define PINMUX_BALL_V10_AD2EVT                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V10_SHIFT))
    #define PINMUX_BALL_V10_eQEP1I                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V10_SHIFT))
    #define PINMUX_BALL_V5_MIBSPI3NCS_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V5_SHIFT))
    #define PINMUX_BALL_V5_MDCLK                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_V5_SHIFT))
    #define PINMUX_BALL_V5_N2HET1_25                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_V5_SHIFT))
    #define PINMUX_BALL_B2_MIBSPI3NCS_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_B2_I2C1_SDA                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_B2_N2HET1_27                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_B2_nTZ1_2                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_B2_SHIFT))
    #define PINMUX_BALL_C3_MIBSPI3NCS_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_C3_I2C1_SCL                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_C3_N2HET1_29                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_C3_nTZ1_1                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_C3_SHIFT))
    #define PINMUX_BALL_W9_MIBSPI3NENA                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W9_MIBSPI3NCS_5                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W9_N2HET1_31                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W9_eQEP1B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_W9_SHIFT))
    #define PINMUX_BALL_W8_MIBSPI3SIMO                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W8_SHIFT))
    #define PINMUX_BALL_W8_EXT_SEL_00                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W8_SHIFT))
    #define PINMUX_BALL_W8_ECAP3                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_W8_SHIFT))
    #define PINMUX_BALL_V8_MIBSPI3SOMI                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V8_SHIFT))
    #define PINMUX_BALL_V8_EXT_ENA                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V8_SHIFT))
    #define PINMUX_BALL_V8_ECAP2                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V8_SHIFT))
    #define PINMUX_BALL_H19_MIBSPI5CLK                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_H19_DMM_DATA_04                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_H19_MII_TXEN                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_H19_RMII_TXEN                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_H19_SHIFT))
    #define PINMUX_BALL_E19_MIBSPI5NCS_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E19_SHIFT))
    #define PINMUX_BALL_E19_DMM_DATA_05                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E19_SHIFT))
    #define PINMUX_BALL_E19_eTPWM4A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_E19_SHIFT))
    #define PINMUX_BALL_B6_MIBSPI5NCS_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B6_SHIFT))
    #define PINMUX_BALL_B6_DMM_DATA_06                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B6_SHIFT))
    #define PINMUX_BALL_W6_MIBSPI5NCS_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W6_SHIFT))
    #define PINMUX_BALL_W6_DMM_DATA_02                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W6_SHIFT))
    #define PINMUX_BALL_T12_MIBSPI5NCS_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_T12_SHIFT))
    #define PINMUX_BALL_T12_DMM_DATA_03                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_T12_SHIFT))
    #define PINMUX_BALL_H18_MIBSPI5NENA                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_H18_DMM_DATA_07                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_H18_MII_RXD_3                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_H18_ECAP5                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_H18_SHIFT))
    #define PINMUX_BALL_J19_MIBSPI5SIMO_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_J19_DMM_DATA_08                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_J19_MII_TXD_1                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_J19_RMII_TXD_1                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_J19_SHIFT))
    #define PINMUX_BALL_E16_MIBSPI5SIMO_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E16_SHIFT))
    #define PINMUX_BALL_E16_DMM_DATA_09                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E16_SHIFT))
    #define PINMUX_BALL_E16_EXT_SEL_00                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_E16_SHIFT))
    #define PINMUX_BALL_H17_MIBSPI5SIMO_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H17_SHIFT))
    #define PINMUX_BALL_H17_DMM_DATA_10                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H17_SHIFT))
    #define PINMUX_BALL_H17_EXT_SEL_01                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_H17_SHIFT))
    #define PINMUX_BALL_G17_MIBSPI5SIMO_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_G17_DMM_DATA_11                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_G17_I2C2_SDA                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_G17_EXT_SEL_02                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_G17_SHIFT))
    #define PINMUX_BALL_J18_MIBSPI5SOMI_0                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_J18_DMM_DATA_12                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_J18_MII_TXD_0                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_J18_RMII_TXD_0                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_J18_SHIFT))
    #define PINMUX_BALL_E17_MIBSPI5SOMI_1                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E17_SHIFT))
    #define PINMUX_BALL_E17_DMM_DATA_13                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E17_SHIFT))
    #define PINMUX_BALL_E17_EXT_SEL_03                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_E17_SHIFT))
    #define PINMUX_BALL_H16_MIBSPI5SOMI_2                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H16_SHIFT))
    #define PINMUX_BALL_H16_DMM_DATA_14                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H16_SHIFT))
    #define PINMUX_BALL_H16_EXT_SEL_04                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_H16_SHIFT))
    #define PINMUX_BALL_G16_MIBSPI5SOMI_3                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_G16_DMM_DATA_15                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_G16_I2C2_SCL                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_G16_EXT_ENA                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_G16_SHIFT))
    #define PINMUX_BALL_K18_N2HET1_00                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K18_SHIFT))
    #define PINMUX_BALL_K18_MIBSPI4CLK                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_K18_SHIFT))
    #define PINMUX_BALL_K18_eTPWM2B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_K18_SHIFT))
    #define PINMUX_BALL_V2_N2HET1_01                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_V2_MIBSPI4NENA                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_V2_N2HET2_08                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_V2_eQEP2A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V2_SHIFT))
    #define PINMUX_BALL_W5_N2HET1_02                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W5_SHIFT))
    #define PINMUX_BALL_W5_MIBSPI4SIMO                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W5_SHIFT))
    #define PINMUX_BALL_W5_eTPWM3A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_W5_SHIFT))
    #define PINMUX_BALL_U1_N2HET1_03                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_U1_MIBSPI4NCS_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_U1_N2HET2_10                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_U1_eQEP2B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_U1_SHIFT))
    #define PINMUX_BALL_B12_N2HET1_04                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B12_SHIFT))
    #define PINMUX_BALL_B12_MIBSPI4NCS_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B12_SHIFT))
    #define PINMUX_BALL_B12_eTPWM4B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_B12_SHIFT))
    #define PINMUX_BALL_V6_N2HET1_05                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_V6_MIBSPI4SOMI                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_V6_N2HET2_12                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_V6_eTPWM3B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V6_SHIFT))
    #define PINMUX_BALL_W3_N2HET1_06                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_W3_SHIFT))
    #define PINMUX_BALL_W3_SCI3RX                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_W3_SHIFT))
    #define PINMUX_BALL_W3_eTPWM5A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_W3_SHIFT))
    #define PINMUX_BALL_T1_N2HET1_07                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_T1_MIBSPI4NCS_2                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_T1_N2HET2_14                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_T1_eTPWM7B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_T1_SHIFT))
    #define PINMUX_BALL_E18_N2HET1_08                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E18_SHIFT))
    #define PINMUX_BALL_E18_MIBSPI1SIMO_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E18_SHIFT))
    #define PINMUX_BALL_E18_MII_TXD_3                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_E18_SHIFT))
    #define PINMUX_BALL_V7_N2HET1_09                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_V7_MIBSPI4NCS_3                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_V7_N2HET2_16                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_V7_eTPWM7A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_V7_SHIFT))
    #define PINMUX_BALL_D19_N2HET1_10                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_D19_MIBSPI4NCS_4                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_D19_MII_TX_CLK                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_D19_MII_TX_AVCLK4                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_D19_nTZ1_3                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_D19_SHIFT))
    #define PINMUX_BALL_E3_N2HET1_11                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_E3_MIBSPI3NCS_4                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_E3_N2HET2_18                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_E3_ETPWM1SYNCO                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_E3_SHIFT))
    #define PINMUX_BALL_B4_N2HET1_12                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_B4_MIBSPI4NCS_5                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_B4_MII_CRS                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_B4_RMII_CRS_DV                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_B4_SHIFT))
    #define PINMUX_BALL_N2_N2HET1_13                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N2_SCI3TX                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N2_N2HET2_20                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N2_eTPWM5B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_N2_SHIFT))
    #define PINMUX_BALL_N1_N2HET1_15                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_N1_MIBSPI1NCS_4                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_N1_N2HET2_22                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_N1_ECAP1                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_N1_SHIFT))
    #define PINMUX_BALL_A4_N2HET1_16                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_A4_SHIFT))
    #define PINMUX_BALL_A4_ETPWM1SYNCI                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_A4_SHIFT))
    #define PINMUX_BALL_A4_ETPWM1SYNCO                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_A4_SHIFT))
    #define PINMUX_BALL_A13_N2HET1_17                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_A13_SHIFT))
    #define PINMUX_BALL_A13_EMIF_nOE                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_A13_SHIFT))
    #define PINMUX_BALL_A13_SCI4RX                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_A13_SHIFT))
    #define PINMUX_BALL_J1_N2HET1_18                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J1_SHIFT))
    #define PINMUX_BALL_J1_EMIF_RNW                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J1_SHIFT))
    #define PINMUX_BALL_J1_eTPWM6A                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_J1_SHIFT))
    #define PINMUX_BALL_B13_N2HET1_19                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B13_SHIFT))
    #define PINMUX_BALL_B13_EMIF_nDQM_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B13_SHIFT))
    #define PINMUX_BALL_B13_SCI4TX                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_B13_SHIFT))
    #define PINMUX_BALL_P2_N2HET1_20                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P2_SHIFT))
    #define PINMUX_BALL_P2_EMIF_nDQM_1                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_P2_SHIFT))
    #define PINMUX_BALL_P2_eTPWM6B                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_P2_SHIFT))
    #define PINMUX_BALL_H4_N2HET1_21                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_H4_SHIFT))
    #define PINMUX_BALL_H4_EMIF_nDQM_2                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_H4_SHIFT))
    #define PINMUX_BALL_B3_N2HET1_22                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B3_SHIFT))
    #define PINMUX_BALL_B3_EMIF_nDQM_3                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_B3_SHIFT))
    #define PINMUX_BALL_J4_N2HET1_23                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_J4_SHIFT))
    #define PINMUX_BALL_J4_EMIF_BA_0                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_J4_SHIFT))
    #define PINMUX_BALL_P1_N2HET1_24                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_P1_MIBSPI1NCS_5                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_P1_MII_RXD_0                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_P1_RMII_RXD_0                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_P1_SHIFT))
    #define PINMUX_BALL_A14_N2HET1_26                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_A14_SHIFT))
    #define PINMUX_BALL_A14_MII_RXD_1                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_A14_SHIFT))
    #define PINMUX_BALL_A14_RMII_RXD_1                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_A14_SHIFT))
    #define PINMUX_BALL_K19_N2HET1_28                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_K19_MII_RXCLK                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_K19_RMII_REFCLK                                  ((uint32)((uint32)0x8U <<  PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_K19_MII_RX_AVCLK4                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_K19_SHIFT))
    #define PINMUX_BALL_B11_N2HET1_30                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_B11_SHIFT))
    #define PINMUX_BALL_B11_MII_RX_DV                                  ((uint32)((uint32)0x4U <<  PINMUX_BALL_B11_SHIFT))
    #define PINMUX_BALL_B11_eQEP2S                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_B11_SHIFT))
    #define PINMUX_BALL_D8_N2HET2_01                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D8_SHIFT))
    #define PINMUX_BALL_D8_N2HET1_NDIS                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D8_SHIFT))
    #define PINMUX_BALL_D7_N2HET2_02                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D7_SHIFT))
    #define PINMUX_BALL_D7_N2HET2_NDIS                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_D7_SHIFT))
    #define PINMUX_BALL_D3_N2HET2_12                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D3_SHIFT))
    #define PINMUX_BALL_D3_MIBSPI2NENA                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_D3_SHIFT))
    #define PINMUX_BALL_D3_MIBSPI2NCS_1                                  ((uint32)((uint32)0x20U <<  PINMUX_BALL_D3_SHIFT))
    #define PINMUX_BALL_D2_N2HET2_13                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D2_SHIFT))
    #define PINMUX_BALL_D2_MIBSPI2SOMI                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_D2_SHIFT))
    #define PINMUX_BALL_D1_N2HET2_14                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_D1_SHIFT))
    #define PINMUX_BALL_D1_MIBSPI2SIMO                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_D1_SHIFT))
    #define PINMUX_BALL_P4_N2HET2_19                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_P4_SHIFT))
    #define PINMUX_BALL_P4_LIN2RX                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_P4_SHIFT))
    #define PINMUX_BALL_T5_N2HET2_20                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_T5_SHIFT))
    #define PINMUX_BALL_T5_LIN2TX                                  ((uint32)((uint32)0x2U <<  PINMUX_BALL_T5_SHIFT))
    #define PINMUX_BALL_T4_MII_RXCLK                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_T4_SHIFT))
    #define PINMUX_BALL_T4_MII_RX_AVCLK4                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_T4_SHIFT))
    #define PINMUX_BALL_U7_MII_TX_CLK                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_U7_SHIFT))
    #define PINMUX_BALL_U7_MII_TX_AVCLK4                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_U7_SHIFT))
    #define PINMUX_BALL_E2_N2HET2_03                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_E2_SHIFT))
    #define PINMUX_BALL_E2_MIBSPI2CLK                                  ((uint32)((uint32)0x10U <<  PINMUX_BALL_E2_SHIFT))
    #define PINMUX_BALL_N3_N2HET2_07                                  ((uint32)((uint32)0x1U <<  PINMUX_BALL_N3_SHIFT))
    #define PINMUX_BALL_N3_MIBSPI2NCS_0                               ((uint32)((uint32)0x10U <<  PINMUX_BALL_N3_SHIFT))
    #define PINMUX_GATE_EMIF_CLK_ON                                 ((uint32)((uint32)0x2U <<  PINMUX_GATE_EMIF_CLK_SHIFT))
    #define PINMUX_EMIF_OUTPUT_ENABLE_ON                            ((uint32)((uint32)0x2U <<  PINMUX_EMIF_OUTPUT_ENABLE_SHIFT))
    #define PINMUX_GIOA_DISABLE_HET1_ON                             ((uint32)((uint32)0x2U <<  PINMUX_GIOA_DISABLE_HET1_SHIFT))
    #define PINMUX_GIOB_DISABLE_HET2_ON                             ((uint32)((uint32)0x2U <<  PINMUX_GIOB_DISABLE_HET2_SHIFT))
    #define PINMUX_GATE_EMIF_CLK_OFF                                ((uint32)((uint32)0x1U <<  PINMUX_GATE_EMIF_CLK_SHIFT))
    #define PINMUX_EMIF_OUTPUT_ENABLE_OFF                           ((uint32)((uint32)0x1U <<  PINMUX_EMIF_OUTPUT_ENABLE_SHIFT))
    #define PINMUX_GIOA_DISABLE_HET1_OFF                            ((uint32)((uint32)0x1U <<  PINMUX_GIOA_DISABLE_HET1_SHIFT))
    #define PINMUX_GIOB_DISABLE_HET2_OFF                            ((uint32)((uint32)0x1U <<  PINMUX_GIOB_DISABLE_HET2_SHIFT))
    #define PINMUX_ALT_ADC_TRIGGER_1                                ((uint32)((uint32)0x1U <<  PINMUX_ALT_ADC_TRIGGER_SHIFT))
    #define PINMUX_ALT_ADC_TRIGGER_2                                ((uint32)((uint32)0x2U <<  PINMUX_ALT_ADC_TRIGGER_SHIFT))
    #define PINMUX_ETHERNET_MII                                     ((uint32)((uint32)0x0U <<  PINMUX_ETHERNET_SHIFT))
    #define PINMUX_ETHERNET_RMII                                    ((uint32)((uint32)0x1U <<  PINMUX_ETHERNET_SHIFT))
    #define PINMUX_ETPWM1_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM1_SHIFT))
    #define PINMUX_ETPWM1_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM1_SHIFT))
    #define PINMUX_ETPWM1_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM1_SHIFT))
    #define PINMUX_ETPWM2_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM2_SHIFT))
    #define PINMUX_ETPWM2_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM2_SHIFT))
    #define PINMUX_ETPWM2_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM2_SHIFT))
    #define PINMUX_ETPWM3_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM3_SHIFT))
    #define PINMUX_ETPWM3_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM3_SHIFT))
    #define PINMUX_ETPWM3_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM3_SHIFT))
    #define PINMUX_ETPWM4_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM4_SHIFT))
    #define PINMUX_ETPWM4_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM4_SHIFT))
    #define PINMUX_ETPWM4_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM4_SHIFT))
    #define PINMUX_ETPWM5_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM5_SHIFT))
    #define PINMUX_ETPWM5_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM5_SHIFT))
    #define PINMUX_ETPWM5_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM5_SHIFT))
    #define PINMUX_ETPWM6_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM6_SHIFT))
    #define PINMUX_ETPWM6_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM6_SHIFT))
    #define PINMUX_ETPWM6_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM6_SHIFT))
    #define PINMUX_ETPWM7_EQEPERR12                                   ((uint32)((uint32)0x1U <<  PINMUX_ETPWM7_SHIFT))
    #define PINMUX_ETPWM7_EQEPERR1                                    ((uint32)((uint32)0x2U <<  PINMUX_ETPWM7_SHIFT))
    #define PINMUX_ETPWM7_EQEPERR2                                    ((uint32)((uint32)0x4U <<  PINMUX_ETPWM7_SHIFT))
    #define PINMUX_ETPWM_TIME_BASE_SYNC_ON                            ((uint32)((uint32)0x2U <<  PINMUX_ETPWM_TIME_BASE_SYNC_SHIFT))
    #define PINMUX_ETPWM_TBCLK_SYNC_ON                                ((uint32)((uint32)0x2U <<  PINMUX_ETPWM_TBCLK_SYNC_SHIFT))
    #define PINMUX_ETPWM_TIME_BASE_SYNC_OFF                           ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_TIME_BASE_SYNC_SHIFT))
    #define PINMUX_ETPWM_TBCLK_SYNC_OFF                               ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_TBCLK_SYNC_SHIFT))
    #define PINMUX_TZ1_ASYNC                                          ((uint32)((uint32)0x1U <<  PINMUX_TZ1_SHIFT))
    #define PINMUX_TZ1_SYNC                                           ((uint32)((uint32)0x2U <<  PINMUX_TZ1_SHIFT))
    #define PINMUX_TZ1_FILTERED                                       ((uint32)((uint32)0x4U <<  PINMUX_TZ1_SHIFT))
    #define PINMUX_TZ2_ASYNC                                          ((uint32)((uint32)0x1U <<  PINMUX_TZ2_SHIFT))
    #define PINMUX_TZ2_SYNC                                           ((uint32)((uint32)0x2U <<  PINMUX_TZ2_SHIFT))
    #define PINMUX_TZ2_FILTERED                                       ((uint32)((uint32)0x4U <<  PINMUX_TZ2_SHIFT))
    #define PINMUX_TZ3_ASYNC                                          ((uint32)((uint32)0x1U <<  PINMUX_TZ3_SHIFT))
    #define PINMUX_TZ3_SYNC                                           ((uint32)((uint32)0x2U <<  PINMUX_TZ3_SHIFT))
    #define PINMUX_TZ3_FILTERED                                       ((uint32)((uint32)0x4U <<  PINMUX_TZ3_SHIFT))
    #define PINMUX_EPWM1SYNCI_ASYNC                                   ((uint32)((uint32)0x1U <<  PINMUX_EPWM1SYNCI_SHIFT))
    #define PINMUX_EPWM1SYNCI_SYNC                                    ((uint32)((uint32)0x2U <<  PINMUX_EPWM1SYNCI_SHIFT))
    #define PINMUX_EPWM1SYNCI_FILTERED                                ((uint32)((uint32)0x4U <<  PINMUX_EPWM1SYNCI_SHIFT))
    #define PINMUX_ETPWM_SOC1A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC1A_SHIFT))
    #define PINMUX_ETPWM_SOC1A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC1A_SHIFT))
    #define PINMUX_ETPWM_SOC2A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC2A_SHIFT))
    #define PINMUX_ETPWM_SOC2A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC2A_SHIFT))
    #define PINMUX_ETPWM_SOC3A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC3A_SHIFT))
    #define PINMUX_ETPWM_SOC3A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC3A_SHIFT))
    #define PINMUX_ETPWM_SOC4A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC4A_SHIFT))
    #define PINMUX_ETPWM_SOC4A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC4A_SHIFT))
    #define PINMUX_ETPWM_SOC5A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC5A_SHIFT))
    #define PINMUX_ETPWM_SOC5A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC5A_SHIFT))
    #define PINMUX_ETPWM_SOC6A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC6A_SHIFT))
    #define PINMUX_ETPWM_SOC6A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC6A_SHIFT))
    #define PINMUX_ETPWM_SOC7A_ON                            		  ((uint32)((uint32)0x1U <<  PINMUX_ETPWM_SOC7A_SHIFT))
    #define PINMUX_ETPWM_SOC7A_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ETPWM_SOC7A_SHIFT))
    #define PINMUX_EQEP1A_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP1A_FILTER_SHIFT))
    #define PINMUX_EQEP1A_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP1A_FILTER_SHIFT))
    #define PINMUX_EQEP1B_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP1B_FILTER_SHIFT))
    #define PINMUX_EQEP1B_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP1B_FILTER_SHIFT))
    #define PINMUX_EQEP1I_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP1I_FILTER_SHIFT))
    #define PINMUX_EQEP1I_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP1I_FILTER_SHIFT))
    #define PINMUX_EQEP1S_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP1S_FILTER_SHIFT))
    #define PINMUX_EQEP1S_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP1S_FILTER_SHIFT))
    #define PINMUX_EQEP2A_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP2A_FILTER_SHIFT))
    #define PINMUX_EQEP2A_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP2A_FILTER_SHIFT))
    #define PINMUX_EQEP2B_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP2B_FILTER_SHIFT))
    #define PINMUX_EQEP2B_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP2B_FILTER_SHIFT))
    #define PINMUX_EQEP2I_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP2I_FILTER_SHIFT))
    #define PINMUX_EQEP2I_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP2I_FILTER_SHIFT))
    #define PINMUX_EQEP2S_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_EQEP2S_FILTER_SHIFT))
    #define PINMUX_EQEP2S_FILTER_OFF                            	  ((uint32)((uint32)0x0U <<  PINMUX_EQEP2S_FILTER_SHIFT))
    #define PINMUX_ECAP1_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP1_FILTER_SHIFT))
    #define PINMUX_ECAP1_FILTER_OFF                            	 	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP1_FILTER_SHIFT))
    #define PINMUX_ECAP2_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP2_FILTER_SHIFT))
    #define PINMUX_ECAP2_FILTER_OFF                            	 	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP2_FILTER_SHIFT))
    #define PINMUX_ECAP3_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP3_FILTER_SHIFT))
    #define PINMUX_ECAP3_FILTER_OFF                            	 	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP3_FILTER_SHIFT))
    #define PINMUX_ECAP4_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP4_FILTER_SHIFT))
    #define PINMUX_ECAP4_FILTER_OFF                            	  	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP4_FILTER_SHIFT))
    #define PINMUX_ECAP5_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP5_FILTER_SHIFT))
    #define PINMUX_ECAP5_FILTER_OFF                            	 	  ((uint32)((uint32)0x0U <<  PINMUX_ECAP5_FILTER_SHIFT))
    #define PINMUX_ECAP6_FILTER_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_ECAP6_FILTER_SHIFT))
    #define PINMUX_ECAP6_FILTER_OFF                            		  ((uint32)((uint32)0x0U <<  PINMUX_ECAP6_FILTER_SHIFT))
    #define PINMUX_GIOA0_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA0_DMA_SHIFT))
    #define PINMUX_GIOA0_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA0_DMA_SHIFT))
    #define PINMUX_GIOA1_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA1_DMA_SHIFT))
    #define PINMUX_GIOA1_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA1_DMA_SHIFT))
    #define PINMUX_GIOA2_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA2_DMA_SHIFT))
    #define PINMUX_GIOA2_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA2_DMA_SHIFT))
    #define PINMUX_GIOA3_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA3_DMA_SHIFT))
    #define PINMUX_GIOA3_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA3_DMA_SHIFT))
    #define PINMUX_GIOA4_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA4_DMA_SHIFT))
    #define PINMUX_GIOA4_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA4_DMA_SHIFT))
    #define PINMUX_GIOA5_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA5_DMA_SHIFT))
    #define PINMUX_GIOA5_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA5_DMA_SHIFT))
    #define PINMUX_GIOA6_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA6_DMA_SHIFT))
    #define PINMUX_GIOA6_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA6_DMA_SHIFT))
    #define PINMUX_GIOA7_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOA7_DMA_SHIFT))
    #define PINMUX_GIOA7_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOA7_DMA_SHIFT))
    #define PINMUX_GIOB0_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB0_DMA_SHIFT))
    #define PINMUX_GIOB0_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB0_DMA_SHIFT))
    #define PINMUX_GIOB1_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB1_DMA_SHIFT))
    #define PINMUX_GIOB1_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB1_DMA_SHIFT))
    #define PINMUX_GIOB2_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB2_DMA_SHIFT))
    #define PINMUX_GIOB2_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB2_DMA_SHIFT))
    #define PINMUX_GIOB3_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB3_DMA_SHIFT))
    #define PINMUX_GIOB3_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB3_DMA_SHIFT))
    #define PINMUX_GIOB4_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB4_DMA_SHIFT))
    #define PINMUX_GIOB4_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB4_DMA_SHIFT))
    #define PINMUX_GIOB5_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB5_DMA_SHIFT))
    #define PINMUX_GIOB5_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB5_DMA_SHIFT))
    #define PINMUX_GIOB6_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB6_DMA_SHIFT))
    #define PINMUX_GIOB6_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB6_DMA_SHIFT))
    #define PINMUX_GIOB7_DMA_ON	                            		  ((uint32)((uint32)0x0U <<  PINMUX_GIOB7_DMA_SHIFT))
    #define PINMUX_GIOB7_DMA_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_GIOB7_DMA_SHIFT))
    #define PINMUX_TEMP1_ENABLE_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_TEMP1_ENABLE_SHIFT))
    #define PINMUX_TEMP1_ENABLE_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_TEMP1_ENABLE_SHIFT))
    #define PINMUX_TEMP2_ENABLE_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_TEMP2_ENABLE_SHIFT))
    #define PINMUX_TEMP2_ENABLE_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_TEMP2_ENABLE_SHIFT))
    #define PINMUX_TEMP3_ENABLE_ON                            		  ((uint32)((uint32)0x2U <<  PINMUX_TEMP3_ENABLE_SHIFT))
    #define PINMUX_TEMP3_ENABLE_OFF                            		  ((uint32)((uint32)0x1U <<  PINMUX_TEMP3_ENABLE_SHIFT))
    #define SIGNAL_AD2EVT_SHIFT		0U
    #define SIGNAL_GIOA_0_SHIFT		24U
    #define SIGNAL_GIOA_1_SHIFT		0U
    #define SIGNAL_GIOA_2_SHIFT		8U
    #define SIGNAL_GIOA_3_SHIFT		16U
    #define SIGNAL_GIOA_4_SHIFT		24U
    #define SIGNAL_GIOA_5_SHIFT		0U
    #define SIGNAL_GIOA_6_SHIFT		8U
    #define SIGNAL_GIOA_7_SHIFT		16U
    #define SIGNAL_GIOB_0_SHIFT		24U
    #define SIGNAL_GIOB_1_SHIFT		0U
    #define SIGNAL_GIOB_2_SHIFT		8U
    #define SIGNAL_GIOB_3_SHIFT		16U
    #define SIGNAL_GIOB_4_SHIFT		24U
    #define SIGNAL_GIOB_5_SHIFT		0U
    #define SIGNAL_GIOB_6_SHIFT		8U
    #define SIGNAL_GIOB_7_SHIFT		16U
    #define SIGNAL_MDIO_SHIFT		24U
    #define SIGNAL_MIBSPI1NCS_4_SHIFT		0U
    #define SIGNAL_MIBSPI1NCS_5_SHIFT		8U
    #define SIGNAL_MII_COL_SHIFT		16U
    #define SIGNAL_MII_CRS_SHIFT		24U
    #define SIGNAL_MII_RX_DV_SHIFT		0U
    #define SIGNAL_MII_RX_ER_SHIFT		8U
    #define SIGNAL_MII_RXCLK_SHIFT		16U
    #define SIGNAL_MII_RXD_0_SHIFT		24U
    #define SIGNAL_MII_RXD_1_SHIFT		0U
    #define SIGNAL_MII_RXD_2_SHIFT		8U
    #define SIGNAL_MII_RXD_3_SHIFT		16U
    #define SIGNAL_MII_TX_CLK_SHIFT		24U
    #define SIGNAL_N2HET1_17_SHIFT		0U
    #define SIGNAL_N2HET1_19_SHIFT		8U
    #define SIGNAL_N2HET1_21_SHIFT		16U
    #define SIGNAL_N2HET1_23_SHIFT		24U
    #define SIGNAL_N2HET1_25_SHIFT		0U
    #define SIGNAL_N2HET1_27_SHIFT		8U
    #define SIGNAL_N2HET1_29_SHIFT		16U
    #define SIGNAL_N2HET1_31_SHIFT		24U
    #define SIGNAL_N2HET2_00_SHIFT		0U
    #define SIGNAL_N2HET2_01_SHIFT		8U
    #define SIGNAL_N2HET2_02_SHIFT		16U
    #define SIGNAL_N2HET2_03_SHIFT		24U
    #define SIGNAL_N2HET2_04_SHIFT		0U
    #define SIGNAL_N2HET2_05_SHIFT		8U
    #define SIGNAL_N2HET2_06_SHIFT		16U
    #define SIGNAL_N2HET2_07_SHIFT		24U
    #define SIGNAL_N2HET2_08_SHIFT		0U
    #define SIGNAL_N2HET2_09_SHIFT		8U
    #define SIGNAL_N2HET2_10_SHIFT		16U
    #define SIGNAL_N2HET2_11_SHIFT		24U
    #define SIGNAL_N2HET2_12_SHIFT		0U
    #define SIGNAL_N2HET2_13_SHIFT		8U
    #define SIGNAL_N2HET2_14_SHIFT		16U
    #define SIGNAL_N2HET2_15_SHIFT		24U
    #define SIGNAL_N2HET2_16_SHIFT		0U
    #define SIGNAL_N2HET2_18_SHIFT		8U
    #define SIGNAL_N2HET2_20_SHIFT		16U
    #define SIGNAL_N2HET2_22_SHIFT		24U
    #define SIGNAL_nTZ1_1_SHIFT		0U
    #define SIGNAL_nTZ1_2_SHIFT		8U
    #define SIGNAL_nTZ1_3_SHIFT		16U
    #define SIGNAL_AD2EVT_T10		((uint32)((uint32)0x1U << SIGNAL_AD2EVT_SHIFT))
    #define SIGNAL_AD2EVT_V10		((uint32)((uint32)0x2U << SIGNAL_AD2EVT_SHIFT))
    #define SIGNAL_GIOA_0_A5		((uint32)((uint32)0x1U << SIGNAL_GIOA_0_SHIFT))
    #define SIGNAL_GIOA_0_R5		((uint32)((uint32)0x2U << SIGNAL_GIOA_0_SHIFT))
    #define SIGNAL_GIOA_1_C2		((uint32)((uint32)0x1U << SIGNAL_GIOA_1_SHIFT))
    #define SIGNAL_GIOA_1_R6		((uint32)((uint32)0x2U << SIGNAL_GIOA_1_SHIFT))
    #define SIGNAL_GIOA_2_C1		((uint32)((uint32)0x1U << SIGNAL_GIOA_2_SHIFT))
    #define SIGNAL_GIOA_2_B15		((uint32)((uint32)0x2U << SIGNAL_GIOA_2_SHIFT))
    #define SIGNAL_GIOA_3_E1		((uint32)((uint32)0x1U << SIGNAL_GIOA_3_SHIFT))
    #define SIGNAL_GIOA_3_R7		((uint32)((uint32)0x2U << SIGNAL_GIOA_3_SHIFT))
    #define SIGNAL_GIOA_4_A6		((uint32)((uint32)0x1U << SIGNAL_GIOA_4_SHIFT))
    #define SIGNAL_GIOA_4_R8		((uint32)((uint32)0x2U << SIGNAL_GIOA_4_SHIFT))
    #define SIGNAL_GIOA_5_B5		((uint32)((uint32)0x1U << SIGNAL_GIOA_5_SHIFT))
    #define SIGNAL_GIOA_5_R9		((uint32)((uint32)0x2U << SIGNAL_GIOA_5_SHIFT))
    #define SIGNAL_GIOA_6_H3		((uint32)((uint32)0x1U << SIGNAL_GIOA_6_SHIFT))
    #define SIGNAL_GIOA_6_R10		((uint32)((uint32)0x2U << SIGNAL_GIOA_6_SHIFT))
    #define SIGNAL_GIOA_7_M1		((uint32)((uint32)0x1U << SIGNAL_GIOA_7_SHIFT))
    #define SIGNAL_GIOA_7_R11		((uint32)((uint32)0x2U << SIGNAL_GIOA_7_SHIFT))
    #define SIGNAL_GIOB_0_M2		((uint32)((uint32)0x1U << SIGNAL_GIOB_0_SHIFT))
    #define SIGNAL_GIOB_0_B8		((uint32)((uint32)0x2U << SIGNAL_GIOB_0_SHIFT))
    #define SIGNAL_GIOB_1_K2		((uint32)((uint32)0x1U << SIGNAL_GIOB_1_SHIFT))
    #define SIGNAL_GIOB_1_B16		((uint32)((uint32)0x2U << SIGNAL_GIOB_1_SHIFT))
    #define SIGNAL_GIOB_2_F2		((uint32)((uint32)0x1U << SIGNAL_GIOB_2_SHIFT))
    #define SIGNAL_GIOB_2_B9		((uint32)((uint32)0x2U << SIGNAL_GIOB_2_SHIFT))
    #define SIGNAL_GIOB_3_W10		((uint32)((uint32)0x1U << SIGNAL_GIOB_3_SHIFT))
    #define SIGNAL_GIOB_3_R4		((uint32)((uint32)0x2U << SIGNAL_GIOB_3_SHIFT))
    #define SIGNAL_GIOB_4_G1		((uint32)((uint32)0x1U << SIGNAL_GIOB_4_SHIFT))
    #define SIGNAL_GIOB_4_L17		((uint32)((uint32)0x2U << SIGNAL_GIOB_4_SHIFT))
    #define SIGNAL_GIOB_5_G2		((uint32)((uint32)0x1U << SIGNAL_GIOB_5_SHIFT))
    #define SIGNAL_GIOB_5_M17		((uint32)((uint32)0x2U << SIGNAL_GIOB_5_SHIFT))
    #define SIGNAL_GIOB_6_J2		((uint32)((uint32)0x1U << SIGNAL_GIOB_6_SHIFT))
    #define SIGNAL_GIOB_6_R3		((uint32)((uint32)0x2U << SIGNAL_GIOB_6_SHIFT))
    #define SIGNAL_GIOB_7_F1		((uint32)((uint32)0x1U << SIGNAL_GIOB_7_SHIFT))
    #define SIGNAL_GIOB_7_P3		((uint32)((uint32)0x2U << SIGNAL_GIOB_7_SHIFT))
    #define SIGNAL_MDIO_F4		((uint32)((uint32)0x1U << SIGNAL_MDIO_SHIFT))
    #define SIGNAL_MDIO_G3		((uint32)((uint32)0x2U << SIGNAL_MDIO_SHIFT))
    #define SIGNAL_MIBSPI1NCS_4_U10		((uint32)((uint32)0x1U << SIGNAL_MIBSPI1NCS_4_SHIFT))
    #define SIGNAL_MIBSPI1NCS_4_N1		((uint32)((uint32)0x2U << SIGNAL_MIBSPI1NCS_4_SHIFT))
    #define SIGNAL_MIBSPI1NCS_5_U9		((uint32)((uint32)0x1U << SIGNAL_MIBSPI1NCS_5_SHIFT))
    #define SIGNAL_MIBSPI1NCS_5_P1		((uint32)((uint32)0x2U << SIGNAL_MIBSPI1NCS_5_SHIFT))
    #define SIGNAL_MII_COL_W4		((uint32)((uint32)0x1U << SIGNAL_MII_COL_SHIFT))
    #define SIGNAL_MII_COL_F3		((uint32)((uint32)0x2U << SIGNAL_MII_COL_SHIFT))
    #define SIGNAL_MII_CRS_V4		((uint32)((uint32)0x1U << SIGNAL_MII_CRS_SHIFT))
    #define SIGNAL_MII_CRS_B4		((uint32)((uint32)0x2U << SIGNAL_MII_CRS_SHIFT))
    #define SIGNAL_MII_RX_DV_U6		((uint32)((uint32)0x1U << SIGNAL_MII_RX_DV_SHIFT))
    #define SIGNAL_MII_RX_DV_B11		((uint32)((uint32)0x2U << SIGNAL_MII_RX_DV_SHIFT))
    #define SIGNAL_MII_RX_ER_U5		((uint32)((uint32)0x1U << SIGNAL_MII_RX_ER_SHIFT))
    #define SIGNAL_MII_RX_ER_N19		((uint32)((uint32)0x2U << SIGNAL_MII_RX_ER_SHIFT))
    #define SIGNAL_MII_RXCLK_T4		((uint32)((uint32)0x1U << SIGNAL_MII_RXCLK_SHIFT))
    #define SIGNAL_MII_RXCLK_K19		((uint32)((uint32)0x2U << SIGNAL_MII_RXCLK_SHIFT))
    #define SIGNAL_MII_RXD_0_U4		((uint32)((uint32)0x1U << SIGNAL_MII_RXD_0_SHIFT))
    #define SIGNAL_MII_RXD_0_P1		((uint32)((uint32)0x2U << SIGNAL_MII_RXD_0_SHIFT))
    #define SIGNAL_MII_RXD_1_T3		((uint32)((uint32)0x1U << SIGNAL_MII_RXD_1_SHIFT))
    #define SIGNAL_MII_RXD_1_A14		((uint32)((uint32)0x2U << SIGNAL_MII_RXD_1_SHIFT))
    #define SIGNAL_MII_RXD_2_U3		((uint32)((uint32)0x1U << SIGNAL_MII_RXD_2_SHIFT))
    #define SIGNAL_MII_RXD_2_G19		((uint32)((uint32)0x2U << SIGNAL_MII_RXD_2_SHIFT))
    #define SIGNAL_MII_RXD_3_V3		((uint32)((uint32)0x1U << SIGNAL_MII_RXD_3_SHIFT))
    #define SIGNAL_MII_RXD_3_H18		((uint32)((uint32)0x2U << SIGNAL_MII_RXD_3_SHIFT))
    #define SIGNAL_MII_TX_CLK_U7		((uint32)((uint32)0x1U << SIGNAL_MII_TX_CLK_SHIFT))
    #define SIGNAL_MII_TX_CLK_D19		((uint32)((uint32)0x2U << SIGNAL_MII_TX_CLK_SHIFT))
    #define SIGNAL_N2HET1_17_A13		((uint32)((uint32)0x1U << SIGNAL_N2HET1_17_SHIFT))
    #define SIGNAL_N2HET1_17_F3		((uint32)((uint32)0x2U << SIGNAL_N2HET1_17_SHIFT))
    #define SIGNAL_N2HET1_19_B13		((uint32)((uint32)0x1U << SIGNAL_N2HET1_19_SHIFT))
    #define SIGNAL_N2HET1_19_G3		((uint32)((uint32)0x2U << SIGNAL_N2HET1_19_SHIFT))
    #define SIGNAL_N2HET1_21_H4		((uint32)((uint32)0x1U << SIGNAL_N2HET1_21_SHIFT))
    #define SIGNAL_N2HET1_21_J3		((uint32)((uint32)0x2U << SIGNAL_N2HET1_21_SHIFT))
    #define SIGNAL_N2HET1_23_J4		((uint32)((uint32)0x1U << SIGNAL_N2HET1_23_SHIFT))
    #define SIGNAL_N2HET1_23_G19		((uint32)((uint32)0x2U << SIGNAL_N2HET1_23_SHIFT))
    #define SIGNAL_N2HET1_25_M3		((uint32)((uint32)0x1U << SIGNAL_N2HET1_25_SHIFT))
    #define SIGNAL_N2HET1_25_V5		((uint32)((uint32)0x2U << SIGNAL_N2HET1_25_SHIFT))
    #define SIGNAL_N2HET1_27_A9		((uint32)((uint32)0x1U << SIGNAL_N2HET1_27_SHIFT))
    #define SIGNAL_N2HET1_27_B2		((uint32)((uint32)0x2U << SIGNAL_N2HET1_27_SHIFT))
    #define SIGNAL_N2HET1_29_A3		((uint32)((uint32)0x1U << SIGNAL_N2HET1_29_SHIFT))
    #define SIGNAL_N2HET1_29_C3		((uint32)((uint32)0x2U << SIGNAL_N2HET1_29_SHIFT))
    #define SIGNAL_N2HET1_31_J17		((uint32)((uint32)0x1U << SIGNAL_N2HET1_31_SHIFT))
    #define SIGNAL_N2HET1_31_W9		((uint32)((uint32)0x2U << SIGNAL_N2HET1_31_SHIFT))
    #define SIGNAL_N2HET2_00_D6		((uint32)((uint32)0x1U << SIGNAL_N2HET2_00_SHIFT))
    #define SIGNAL_N2HET2_00_C1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_00_SHIFT))
    #define SIGNAL_N2HET2_01_D8		((uint32)((uint32)0x1U << SIGNAL_N2HET2_01_SHIFT))
    #define SIGNAL_N2HET2_01_D4		((uint32)((uint32)0x2U << SIGNAL_N2HET2_01_SHIFT))
    #define SIGNAL_N2HET2_02_D7		((uint32)((uint32)0x1U << SIGNAL_N2HET2_02_SHIFT))
    #define SIGNAL_N2HET2_02_E1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_02_SHIFT))
    #define SIGNAL_N2HET2_03_E2		((uint32)((uint32)0x1U << SIGNAL_N2HET2_03_SHIFT))
    #define SIGNAL_N2HET2_03_D5		((uint32)((uint32)0x2U << SIGNAL_N2HET2_03_SHIFT))
    #define SIGNAL_N2HET2_04_D13		((uint32)((uint32)0x1U << SIGNAL_N2HET2_04_SHIFT))
    #define SIGNAL_N2HET2_04_H3		((uint32)((uint32)0x2U << SIGNAL_N2HET2_04_SHIFT))
    #define SIGNAL_N2HET2_05_D12		((uint32)((uint32)0x1U << SIGNAL_N2HET2_05_SHIFT))
    #define SIGNAL_N2HET2_05_D16		((uint32)((uint32)0x2U << SIGNAL_N2HET2_05_SHIFT))
    #define SIGNAL_N2HET2_06_D11		((uint32)((uint32)0x1U << SIGNAL_N2HET2_06_SHIFT))
    #define SIGNAL_N2HET2_06_M1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_06_SHIFT))
    #define SIGNAL_N2HET2_07_N3		((uint32)((uint32)0x1U << SIGNAL_N2HET2_07_SHIFT))
    #define SIGNAL_N2HET2_07_N17		((uint32)((uint32)0x2U << SIGNAL_N2HET2_07_SHIFT))
    #define SIGNAL_N2HET2_08_K16		((uint32)((uint32)0x1U << SIGNAL_N2HET2_08_SHIFT))
    #define SIGNAL_N2HET2_08_V2		((uint32)((uint32)0x2U << SIGNAL_N2HET2_08_SHIFT))
    #define SIGNAL_N2HET2_09_L16		((uint32)((uint32)0x1U << SIGNAL_N2HET2_09_SHIFT))
    #define SIGNAL_N2HET2_09_K17		((uint32)((uint32)0x2U << SIGNAL_N2HET2_09_SHIFT))
    #define SIGNAL_N2HET2_10_M16		((uint32)((uint32)0x1U << SIGNAL_N2HET2_10_SHIFT))
    #define SIGNAL_N2HET2_10_U1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_10_SHIFT))
    #define SIGNAL_N2HET2_11_N16		((uint32)((uint32)0x1U << SIGNAL_N2HET2_11_SHIFT))
    #define SIGNAL_N2HET2_11_C4		((uint32)((uint32)0x2U << SIGNAL_N2HET2_11_SHIFT))
    #define SIGNAL_N2HET2_12_D3		((uint32)((uint32)0x1U << SIGNAL_N2HET2_12_SHIFT))
    #define SIGNAL_N2HET2_12_V6		((uint32)((uint32)0x2U << SIGNAL_N2HET2_12_SHIFT))
    #define SIGNAL_N2HET2_13_D2		((uint32)((uint32)0x1U << SIGNAL_N2HET2_13_SHIFT))
    #define SIGNAL_N2HET2_13_C5		((uint32)((uint32)0x2U << SIGNAL_N2HET2_13_SHIFT))
    #define SIGNAL_N2HET2_14_D1		((uint32)((uint32)0x1U << SIGNAL_N2HET2_14_SHIFT))
    #define SIGNAL_N2HET2_14_T1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_14_SHIFT))
    #define SIGNAL_N2HET2_15_K4		((uint32)((uint32)0x1U << SIGNAL_N2HET2_15_SHIFT))
    #define SIGNAL_N2HET2_15_C6		((uint32)((uint32)0x2U << SIGNAL_N2HET2_15_SHIFT))
    #define SIGNAL_N2HET2_16_L4		((uint32)((uint32)0x1U << SIGNAL_N2HET2_16_SHIFT))
    #define SIGNAL_N2HET2_16_V7		((uint32)((uint32)0x2U << SIGNAL_N2HET2_16_SHIFT))
    #define SIGNAL_N2HET2_18_N4		((uint32)((uint32)0x1U << SIGNAL_N2HET2_18_SHIFT))
    #define SIGNAL_N2HET2_18_E3		((uint32)((uint32)0x2U << SIGNAL_N2HET2_18_SHIFT))
    #define SIGNAL_N2HET2_20_T5		((uint32)((uint32)0x1U << SIGNAL_N2HET2_20_SHIFT))
    #define SIGNAL_N2HET2_20_N2		((uint32)((uint32)0x2U << SIGNAL_N2HET2_20_SHIFT))
    #define SIGNAL_N2HET2_22_T7		((uint32)((uint32)0x1U << SIGNAL_N2HET2_22_SHIFT))
    #define SIGNAL_N2HET2_22_N1		((uint32)((uint32)0x2U << SIGNAL_N2HET2_22_SHIFT))
    #define SIGNAL_nTZ1_1_N19		((uint32)((uint32)0x1U << SIGNAL_nTZ1_1_SHIFT))
    #define SIGNAL_nTZ1_1_C3		((uint32)((uint32)0x2U << SIGNAL_nTZ1_1_SHIFT))
    #define SIGNAL_nTZ1_2_F1		((uint32)((uint32)0x1U << SIGNAL_nTZ1_2_SHIFT))
    #define SIGNAL_nTZ1_2_B2		((uint32)((uint32)0x2U << SIGNAL_nTZ1_2_SHIFT))
    #define SIGNAL_nTZ1_3_J3		((uint32)((uint32)0x1U << SIGNAL_nTZ1_3_SHIFT))
    #define SIGNAL_nTZ1_3_D19		((uint32)((uint32)0x2U << SIGNAL_nTZ1_3_SHIFT))
    /** @fn void muxInit(void)
    *   @brief Initializes the PINMUX Driver
    *   This function initializes the PINMUX module and configures the selected
    *   pinmux settings as per the user selection in the GUI
    void muxInit(void);
    /* USER CODE BEGIN (1) */
    /* USER CODE END */
    #ifdef __cplusplus
    #endif /*extern "C" */
    #endif
  • The SCI4 configuration looks good:
    /** - set pins functional mode: GIO */
    sciREG4->PIO0 = (uint32)((uint32)0U << 2U) /* tx pin */
                                  | (uint32)((uint32)0U << 1U); /* rx pin */
    /** - set pins direction: output */
    sciREG4->PIO1 = (uint32)((uint32)1U << 2U) /* tx pin */
                                | (uint32)((uint32)1U << 1U); /* rx pin */
    /** - Disable open drain enable */
    sciREG4->PIO6 = (uint32)((uint32)0U << 2U) /* tx pin */
    I will check on my launchpad.
  • Just tested, it works.
    gioToggleBit(sciPORT1, 2); /* Toggle sciPORT3 "SCI1TX" in GIO Mode. */
    gioToggleBit(sciPORT1, 1); /* Toggle sciPORT3 "SCI1RX" in GIO Mode. */
    gioToggleBit(sciPORT3, 2); /* Toggle sciPORT3 "SCI3TX" in GIO Mode. */
    gioToggleBit(sciPORT3, 1); /* Toggle sciPORT3 "SCI3RX" in GIO Mode. */
    But the following definition is not correct, should not be used.
    PIN_SCI_TX = 4U,
    PIN_SCI_RX = 2U
    The right definition should be
    PIN_SCI_TX = 2U,
    PIN_SCI_RX = 1U
