Other Parts Discussed in Thread: HALCOGEN,
Measuring the cycle time from start to end of DMA transfer for all mibSPIs shows 1,8 ms. Measuring the cycle time for further cycles from start to end of DMA transfer shows 3,0 ms. Please see the code below. After initialisation phase the code enters an while(1) loop. Within this loop all 4 mibSPs are started sequently taking the HBC Flag into account. At the beginning a PWM Signal is set to 100 % duty and after all DMA channels have completed the transmission the PWM Signal is set to 1 % duty. The 100 % duty is measured with a Digital Storage Oscilloscope. For the first while loop cycle 1,8 ms can be measured. But for all following while loop cycles 3,0 ms are measured. Any idea why there is such a difference?
/* USER CODE BEGIN (0) */ /* USER CODE END */ /* Include Files */ #include "HL_sys_common.h" /* USER CODE BEGIN (1) */ #include "HL_mibspi.h" #include "HL_sys_dma.h" #include "HL_het.h" #include "HL_reg_het.h" /* example data Pattern configuration */ #define D_SIZE 128 #define BUFFER_SIZE 1024 void loadDataPattern(uint32 psize, uint16* pptr); void mibspiEnableInternalLoopback(mibspiBASE_t *mibspi); void dmaConfigCtrlPacket(uint32 sadd,uint32 dadd,uint32 dsize); void mibspiDmaConfig(mibspiBASE_t *mibspi,uint32 channel, uint32 txchannel, uint32 rxchannel); #pragma SET_DATA_SECTION(".sharedRAM") uint16 TXDATA[BUFFER_SIZE]; /* transmit buffer in sys ram */ uint16 RXDATA[BUFFER_SIZE]= {0}; /* receive buffer in sys ram */ uint16 TXDATA2[BUFFER_SIZE]; /* transmit buffer in sys ram */ uint16 RXDATA2[BUFFER_SIZE]= {0}; /* receive buffer in sys ram */ uint16 TXDATA3[BUFFER_SIZE]; /* transmit buffer in sys ram */ uint16 RXDATA3[BUFFER_SIZE]= {0}; /* receive buffer in sys ram */ uint16 TXDATA4[BUFFER_SIZE]; /* transmit buffer in sys ram */ uint16 RXDATA4[BUFFER_SIZE]= {0}; /* receive buffer in sys ram */ #pragma SET_DATA_SECTION() static g_dmaCTRL g_dmaCTRLPKT1, g_dmaCTRLPKT2; /* dma control packet configuration stack */ /* USER CODE END */ /** @fn void main(void) * @brief Application main function * @note This function is empty by default. * * This function is called after startup. * The user can use this function to implement the application. */ /* USER CODE BEGIN (2) */ /* USER CODE END */ void main(void) { /* USER CODE BEGIN (3) */ uint32 i; uint32 j; uint32 m; /* - creating a data chunk in system ram to start with ... */ loadDataPattern(BUFFER_SIZE,&TXDATA[0]); loadDataPattern(BUFFER_SIZE,&TXDATA2[0]); loadDataPattern(BUFFER_SIZE,&TXDATA3[0]); loadDataPattern(BUFFER_SIZE,&TXDATA4[0]); clearDataPattern(BUFFER_SIZE,&RXDATA[0]); clearDataPattern(BUFFER_SIZE,&RXDATA2[0]); clearDataPattern(BUFFER_SIZE,&RXDATA3[0]); clearDataPattern(BUFFER_SIZE,&RXDATA4[0]); /* - initializing mibspi - enabling tg 0 , length 127 (halcogen file)*/ mibspiInit(); /* - enabling loopback ( this is to emulate data transfer without external wires */ mibspiEnableInternalLoopback(mibspiREG1); mibspiEnableInternalLoopback(mibspiREG2); mibspiEnableInternalLoopback(mibspiREG3); mibspiEnableInternalLoopback(mibspiREG4); /* - configuring dma control packets */ g_dmaCTRLPKT1.SADD = (uint32)TXDATA; /* source address */ g_dmaCTRLPKT1.DADD = (uint32)&(mibspiRAM1->tx[0].data); /* destination address */ g_dmaCTRLPKT1.CHCTRL = 0; /* channel control */ g_dmaCTRLPKT1.FRCNT = 8;//1; /* frame count */ g_dmaCTRLPKT1.ELCNT = 32;//D_SIZE; /* element count */ g_dmaCTRLPKT1.ELDOFFSET = 4; /* element destination offset */ g_dmaCTRLPKT1.ELSOFFSET = 0; /* element destination offset */ g_dmaCTRLPKT1.FRDOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT1.FRSOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT1.PORTASGN = PORTA_READ_PORTB_WRITE; g_dmaCTRLPKT1.RDSIZE = ACCESS_64_BIT; /* read size */ g_dmaCTRLPKT1.WRSIZE = ACCESS_16_BIT; /* write size */ g_dmaCTRLPKT1.TTYPE = FRAME_TRANSFER ; /* transfer type */ g_dmaCTRLPKT1.ADDMODERD = ADDR_INC1; /* address mode read */ g_dmaCTRLPKT1.ADDMODEWR = ADDR_OFFSET; /* address mode write */ g_dmaCTRLPKT1.AUTOINIT = AUTOINIT_ON; /* autoinit */ g_dmaCTRLPKT2.SADD = (uint32)&(mibspiRAM1->rx[0].data); /* source address */ g_dmaCTRLPKT2.DADD = (uint32)RXDATA; /* destination address */ g_dmaCTRLPKT2.CHCTRL = 0; /* channel control */ g_dmaCTRLPKT2.FRCNT = 8;//1; /* frame count */ g_dmaCTRLPKT2.ELCNT = D_SIZE; /* element count */ g_dmaCTRLPKT2.ELDOFFSET = 0; /* element destination offset */ g_dmaCTRLPKT2.ELSOFFSET = 4; /* element destination offset */ g_dmaCTRLPKT2.FRDOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT2.FRSOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT2.PORTASGN = PORTB_READ_PORTA_WRITE; g_dmaCTRLPKT2.RDSIZE = ACCESS_16_BIT; /* read size */ g_dmaCTRLPKT2.WRSIZE = ACCESS_64_BIT; /* write size */ g_dmaCTRLPKT2.TTYPE = FRAME_TRANSFER ; /* transfer type */ g_dmaCTRLPKT2.ADDMODERD = ADDR_OFFSET; /* address mode read */ g_dmaCTRLPKT2.ADDMODEWR = ADDR_INC1; /* address mode write */ g_dmaCTRLPKT2.AUTOINIT = AUTOINIT_ON; /* autoinit */ /* upto 32 control packets are supported. */ /* - setting dma control packets */ dmaSetCtrlPacket(DMA_CH0,g_dmaCTRLPKT2); dmaSetCtrlPacket(DMA_CH1,g_dmaCTRLPKT1); /* - setting the dma channel to trigger on h/w request */ dmaSetChEnable(DMA_CH0, DMA_HW); dmaSetChEnable(DMA_CH1, DMA_HW); /* - configuring dma control packets */ g_dmaCTRLPKT1.SADD = (uint32)TXDATA2; /* source address */ g_dmaCTRLPKT1.DADD = (uint32)&(mibspiRAM2->tx[0].data); /* destination address */ g_dmaCTRLPKT1.CHCTRL = 0; /* channel control */ g_dmaCTRLPKT1.FRCNT = 8;//1; /* frame count */ g_dmaCTRLPKT1.ELCNT = 32;//D_SIZE; /* element count */ g_dmaCTRLPKT1.ELDOFFSET = 4; /* element destination offset */ g_dmaCTRLPKT1.ELSOFFSET = 0; /* element destination offset */ g_dmaCTRLPKT1.FRDOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT1.FRSOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT1.PORTASGN = PORTA_READ_PORTB_WRITE; g_dmaCTRLPKT1.RDSIZE = ACCESS_64_BIT; /* read size */ g_dmaCTRLPKT1.WRSIZE = ACCESS_16_BIT; /* write size */ g_dmaCTRLPKT1.TTYPE = FRAME_TRANSFER ; /* transfer type */ g_dmaCTRLPKT1.ADDMODERD = ADDR_INC1; /* address mode read */ g_dmaCTRLPKT1.ADDMODEWR = ADDR_OFFSET; /* address mode write */ g_dmaCTRLPKT1.AUTOINIT = AUTOINIT_ON; /* autoinit */ g_dmaCTRLPKT2.SADD = (uint32)&(mibspiRAM2->rx[0].data); /* source address */ g_dmaCTRLPKT2.DADD = (uint32)RXDATA2; /* destination address */ g_dmaCTRLPKT2.CHCTRL = 0; /* channel control */ g_dmaCTRLPKT2.FRCNT = 8;//1; /* frame count */ g_dmaCTRLPKT2.ELCNT = D_SIZE; /* element count */ g_dmaCTRLPKT2.ELDOFFSET = 0; /* element destination offset */ g_dmaCTRLPKT2.ELSOFFSET = 4; /* element destination offset */ g_dmaCTRLPKT2.FRDOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT2.FRSOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT2.PORTASGN = PORTB_READ_PORTA_WRITE; g_dmaCTRLPKT2.RDSIZE = ACCESS_16_BIT; /* read size */ g_dmaCTRLPKT2.WRSIZE = ACCESS_64_BIT; /* write size */ g_dmaCTRLPKT2.TTYPE = FRAME_TRANSFER ; /* transfer type */ g_dmaCTRLPKT2.ADDMODERD = ADDR_OFFSET; /* address mode read */ g_dmaCTRLPKT2.ADDMODEWR = ADDR_INC1; /* address mode write */ g_dmaCTRLPKT2.AUTOINIT = AUTOINIT_ON; /* autoinit */ /* upto 32 control packets are supported. */ /* - setting dma control packets */ dmaSetCtrlPacket(DMA_CH2,g_dmaCTRLPKT2); dmaSetCtrlPacket(DMA_CH3,g_dmaCTRLPKT1); /* - setting the dma channel to trigger on h/w request */ dmaSetChEnable(DMA_CH2, DMA_HW); dmaSetChEnable(DMA_CH3, DMA_HW); /* - configuring dma control packets */ g_dmaCTRLPKT1.SADD = (uint32)TXDATA3; /* source address */ g_dmaCTRLPKT1.DADD = (uint32)&(mibspiRAM3->tx[0].data); /* destination address */ g_dmaCTRLPKT1.CHCTRL = 0; /* channel control */ g_dmaCTRLPKT1.FRCNT = 8;//1; /* frame count */ g_dmaCTRLPKT1.ELCNT = 32;//D_SIZE; /* element count */ g_dmaCTRLPKT1.ELDOFFSET = 4; /* element destination offset */ g_dmaCTRLPKT1.ELSOFFSET = 0; /* element destination offset */ g_dmaCTRLPKT1.FRDOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT1.FRSOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT1.PORTASGN = PORTA_READ_PORTB_WRITE; g_dmaCTRLPKT1.RDSIZE = ACCESS_64_BIT; /* read size */ g_dmaCTRLPKT1.WRSIZE = ACCESS_16_BIT; /* write size */ g_dmaCTRLPKT1.TTYPE = FRAME_TRANSFER ; /* transfer type */ g_dmaCTRLPKT1.ADDMODERD = ADDR_INC1; /* address mode read */ g_dmaCTRLPKT1.ADDMODEWR = ADDR_OFFSET; /* address mode write */ g_dmaCTRLPKT1.AUTOINIT = AUTOINIT_ON; /* autoinit */ g_dmaCTRLPKT2.SADD = (uint32)&(mibspiRAM3->rx[0].data); /* source address */ g_dmaCTRLPKT2.DADD = (uint32)RXDATA3; /* destination address */ g_dmaCTRLPKT2.CHCTRL = 0; /* channel control */ g_dmaCTRLPKT2.FRCNT = 8;//1; /* frame count */ g_dmaCTRLPKT2.ELCNT = D_SIZE; /* element count */ g_dmaCTRLPKT2.ELDOFFSET = 0; /* element destination offset */ g_dmaCTRLPKT2.ELSOFFSET = 4; /* element destination offset */ g_dmaCTRLPKT2.FRDOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT2.FRSOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT2.PORTASGN = PORTB_READ_PORTA_WRITE; g_dmaCTRLPKT2.RDSIZE = ACCESS_16_BIT; /* read size */ g_dmaCTRLPKT2.WRSIZE = ACCESS_64_BIT; /* write size */ g_dmaCTRLPKT2.TTYPE = FRAME_TRANSFER ; /* transfer type */ g_dmaCTRLPKT2.ADDMODERD = ADDR_OFFSET; /* address mode read */ g_dmaCTRLPKT2.ADDMODEWR = ADDR_INC1; /* address mode write */ g_dmaCTRLPKT2.AUTOINIT = AUTOINIT_ON; /* autoinit */ /* upto 32 control packets are supported. */ /* - setting dma control packets */ dmaSetCtrlPacket(DMA_CH4,g_dmaCTRLPKT2); dmaSetCtrlPacket(DMA_CH5,g_dmaCTRLPKT1); dmaReqAssign(DMA_CH4, DMA_REQ14); dmaReqAssign(DMA_CH5, DMA_REQ15); /* - setting the dma channel to trigger on h/w request */ dmaSetChEnable(DMA_CH4, DMA_HW); dmaSetChEnable(DMA_CH5, DMA_HW); /* - configuring dma control packets */ g_dmaCTRLPKT1.SADD = (uint32)TXDATA4; /* source address */ g_dmaCTRLPKT1.DADD = (uint32)&(mibspiRAM4->tx[0].data); /* destination address */ g_dmaCTRLPKT1.CHCTRL = 0; /* channel control */ g_dmaCTRLPKT1.FRCNT = 8;//1; /* frame count */ g_dmaCTRLPKT1.ELCNT = 32;//D_SIZE; /* element count */ g_dmaCTRLPKT1.ELDOFFSET = 4; /* element destination offset */ g_dmaCTRLPKT1.ELSOFFSET = 0; /* element destination offset */ g_dmaCTRLPKT1.FRDOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT1.FRSOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT1.PORTASGN = PORTA_READ_PORTB_WRITE; g_dmaCTRLPKT1.RDSIZE = ACCESS_64_BIT; /* read size */ g_dmaCTRLPKT1.WRSIZE = ACCESS_16_BIT; /* write size */ g_dmaCTRLPKT1.TTYPE = FRAME_TRANSFER ; /* transfer type */ g_dmaCTRLPKT1.ADDMODERD = ADDR_INC1; /* address mode read */ g_dmaCTRLPKT1.ADDMODEWR = ADDR_OFFSET; /* address mode write */ g_dmaCTRLPKT1.AUTOINIT = AUTOINIT_ON; /* autoinit */ g_dmaCTRLPKT2.SADD = (uint32)&(mibspiRAM4->rx[0].data); /* source address */ g_dmaCTRLPKT2.DADD = (uint32)RXDATA4; /* destination address */ g_dmaCTRLPKT2.CHCTRL = 0; /* channel control */ g_dmaCTRLPKT2.FRCNT = 8;//1; /* frame count */ g_dmaCTRLPKT2.ELCNT = D_SIZE; /* element count */ g_dmaCTRLPKT2.ELDOFFSET = 0; /* element destination offset */ g_dmaCTRLPKT2.ELSOFFSET = 4; /* element destination offset */ g_dmaCTRLPKT2.FRDOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT2.FRSOFFSET = 0; /* frame destination offset */ g_dmaCTRLPKT2.PORTASGN = PORTB_READ_PORTA_WRITE; g_dmaCTRLPKT2.RDSIZE = ACCESS_16_BIT; /* read size */ g_dmaCTRLPKT2.WRSIZE = ACCESS_64_BIT; /* write size */ g_dmaCTRLPKT2.TTYPE = FRAME_TRANSFER ; /* transfer type */ g_dmaCTRLPKT2.ADDMODERD = ADDR_OFFSET; /* address mode read */ g_dmaCTRLPKT2.ADDMODEWR = ADDR_INC1; /* address mode write */ g_dmaCTRLPKT2.AUTOINIT = AUTOINIT_ON; /* autoinit */ /* upto 32 control packets are supported. */ /* - setting dma control packets */ dmaSetCtrlPacket(DMA_CH6,g_dmaCTRLPKT2); dmaSetCtrlPacket(DMA_CH7,g_dmaCTRLPKT1); dmaReqAssign(DMA_CH6, DMA_REQ24); dmaReqAssign(DMA_CH7, DMA_REQ25); /* - setting the dma channel to trigger on h/w request */ dmaSetChEnable(DMA_CH6, DMA_HW); dmaSetChEnable(DMA_CH7, DMA_HW); //dmaReqAssign(DMA_CH0, DMA_REQ0); //dmaReqAssign(DMA_CH1, DMA_REQ1); /* - configuring the mibspi dma , channel 0 , tx line -0 , rxline -1 */ /* - refer to the device data sheet dma request source for mibspi tx/rx */ mibspiDmaConfig(mibspiREG1,0,0,1); mibspiDmaConfig(mibspiREG2,0,0,1); mibspiDmaConfig(mibspiREG3,0,0,1); mibspiDmaConfig(mibspiREG4,0,0,1); dmaEnable(); hetInit(); pwmSetDuty(hetRAM1, 0, 1); i = 0; while(1) { i++; pwmSetDuty(hetRAM1, 0, 100); /* - start the mibspi transfer tg 0 */ mibspiTransfer(mibspiREG1,0 ); while(dmaGetInterruptStatus(DMA_CH0, HBC) == FALSE); mibspiTransfer(mibspiREG2,0 ); //while(dmaGetInterruptStatus(DMA_CH0, BTC) == FALSE); while(dmaGetInterruptStatus(DMA_CH2, HBC) == FALSE); mibspiTransfer(mibspiREG3,0 ); while(dmaGetInterruptStatus(DMA_CH4, HBC) == FALSE); mibspiTransfer(mibspiREG4,0 ); while(dmaGetInterruptStatus(DMA_CH6, BTC) == FALSE); //while(dmaGetInterruptStatus(DMA_CH6, BTC) == FALSE); //while(dmaGetInterruptStatus(DMA_CH0, BTC) == FALSE); //while(dmaGetInterruptStatus(DMA_CH2, BTC) == FALSE); //while(dmaGetInterruptStatus(DMA_CH4, BTC) == FALSE); pwmSetDuty(hetRAM1, 0, 1); mibspiDisableTransfer(mibspiREG1,0); mibspiDisableTransfer(mibspiREG2,0); mibspiDisableTransfer(mibspiREG3,0); mibspiDisableTransfer(mibspiREG4,0); dmaREG->BTCFLAG = 0xFFFFFFFF; dmaREG->HBCFLAG = 0xFFFFFFFF; dmaDisable(); mibspiDmaConfig(mibspiREG1,0,0,1); mibspiDmaConfig(mibspiREG2,0,0,1); mibspiDmaConfig(mibspiREG3,0,0,1); mibspiDmaConfig(mibspiREG4,0,0,1); m = 0x00000000; for(j = 0; j < BUFFER_SIZE; j++) { if((TXDATA[j] != RXDATA[j]) || (TXDATA2[j] != RXDATA2[j]) || (TXDATA3[j] != RXDATA3[j]) || (TXDATA4[j] != RXDATA4[j])) { m = 0xFFFFFFFF; } } clearDataPattern(BUFFER_SIZE,&RXDATA[0]); clearDataPattern(BUFFER_SIZE,&RXDATA2[0]); clearDataPattern(BUFFER_SIZE,&RXDATA3[0]); clearDataPattern(BUFFER_SIZE,&RXDATA4[0]); dmaEnable(); } pwmStop(hetRAM1, 0); while(1); /* loop forever */ /* USER CODE END */ } /* USER CODE BEGIN (4) */ /** void mibspiEnableLoopback(mibspiBASE_t *mibspi ) * * enabling internal loopback on mibspix */ void mibspiEnableInternalLoopback(mibspiBASE_t *mibspi ) { /* enabling internal loopback */ mibspi->GCR1 |= 1U << 16U; } void mibspiDisableTransfer(mibspiBASE_t * mibspi, uint32_t group) { mibspi->TGCTRL[group] = (mibspi->TGCTRL[group] & 0x7FFFFFFFU); } /** void mibspiDmaConfig(mibspiBASE_t *mibspi,uint32 channel, uint32 txchannel, uint32 rxchannel) * * configuring mibspi dma with * * channel > mibspi dma channel number * txchannel > transmit channel dedicated for mibspi * rxchannel > receive channel dedicated for mibspi */ void mibspiDmaConfig(mibspiBASE_t *mibspi,uint32 channel, uint32 txchannel, uint32 rxchannel) { uint32 bufid = D_SIZE - 1; uint32 icount = 0; /* setting large count */ mibspi->DMACNTLEN = 0x00000001; /* setting initial count of DMA transfers */ mibspi->DMACOUNT[channel] = BUFFER_SIZE << 16; /* setting transmit and receive channels */ mibspi->DMACTRL[channel] |= (((rxchannel<<4)|txchannel) << 16); /* enabling transmit and receive dma */ mibspi->DMACTRL[channel] |= 0x8000C000; /* setting Initial Count of DMA transfers and the buffer utilized for DMA transfer */ mibspi->DMACTRL[channel] |= (icount << 8) |(bufid<<24); } /** void loadDataPattern(uint32 psize, uint16* pptr) * * loading a randam data chunk into system ram * * pptr > sys ram address * psize > chunkl size * */ void loadDataPattern(uint32 psize, uint16* pptr) { unsigned int i; for(i= 0; i < psize; i++) { *pptr = i; pptr++; } } void clearDataPattern(uint32 psize, uint16* pptr) { unsigned int i; for(i= 0; i < psize; i++) { *pptr = 0; pptr++; } } /* USER CODE END */
