Part Number: LP-AM243
i try to flash the AM243X-EVM board like referred here: Flash SOC Initialization Binary
AM243x MCU+ SDK: EVM Setup (ti.com)
Command line argument:
py uart_uniflash.py -p COM11 --cfg=sbl_prebuilt/am243x-evm/default_sbl_null.cfg
default_sbl_null.cfg Content:
# First point to sbl_uart_uniflash binary, which function's as a server to flash one or more files
--flash-writer=sbl_prebuilt/am243x-evm/sbl_uart_uniflash.release.tiimage
# When sending bootloader make sure to flash at offset 0x0. ROM expects bootloader at offset 0x0
--file=sbl_prebuilt/am243x-evm/sbl_null.release.tiimage --operation=flash --flash-offset=0x0
Result off execution:
C:\ti\mcu_plus_sdk_am243x_08_01_00_36\tools\boot>py uart_uniflash.py -p COM11 --cfg=sbl_prebuilt/am243x-evm/default_sbl_null.cfg
Parsing config file ...
Parsing config file ... SUCCESS. Found 2 command(s) !!!
Executing command 1 of 2 ...
Found flash writer ... sending sbl_prebuilt/am243x-evm/sbl_uart_uniflash.release.tiimage
Sent flashwriter sbl_prebuilt/am243x-evm/sbl_uart_uniflash.release.tiimage of size 297212 bytes in 34.13s.
Executing command 2 of 2 ...
Command arguments : --file=sbl_prebuilt/am243x-evm/sbl_null.release.tiimage --operation=flash --flash-offset=0x0
Send normally
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 1%|▉ | 2058/221724 [00:01<01:36, 2267.16bytes/s]send error: expected ACK; got b'\x18' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 1%|█▎ | 3087/221724 [00:01<01:03, 3456.27bytes/s]send error: expected ACK; got b'\x18' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 2%|█▊ | 4116/221724 [00:01<01:02, 3456.27bytes/s]send error: expected ACK; got b'0' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 2%|██▏ | 5145/221724 [00:01<01:02, 3456.27bytes/s]send error: expected ACK; got b'1' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 3%|██▋ | 6174/221724 [00:01<00:28, 7671.06bytes/s]send error: expected ACK; got b'0' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 3%|███ | 7203/221724 [00:01<00:27, 7671.06bytes/s]send error: expected ACK; got b'0' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 4%|███▌ | 8232/221724 [00:01<00:24, 8568.37bytes/s]send error: expected ACK; got b'0' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 4%|███▉ | 9261/221724 [00:01<00:24, 8568.37bytes/s]send error: expected ACK; got b'0' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 5%|████▎ | 10290/221724 [00:01<00:23, 9171.42bytes/s]send error: expected ACK; got b'0' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 5%|████▊ | 11319/221724 [00:01<00:22, 9171.42bytes/s]send error: expected ACK; got b'0' for block 2
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 6%|█████▏ | 12348/221724 [00:01<00:21, 9560.95bytes/s]send error: expected ACK; got b'0' for block 2
send error: NAK received 11 times, aborting.
Sending sbl_prebuilt/am243x-evm/sbl_null.release.tiimage: 6%|█████▏ | 12350/221724 [00:02<00:21, 9560.95bytes/s]
[ERROR] XMODEM send failed, no response OR incorrect response from EVM OR cancelled by user,
Power cycle EVM and run this script again !!!
I tried this with different options, but always in combination with xmodem the script is not running.
Is it possible that xmodem not works because of the characters are sent from the AM243X-EMV?
The ASCII symbols are the same as shown in the terminal after a reset
CCþ01000000011a0000616d36347800000000000000475020200000010000000100CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC01000000011a0000616d36347800000000000000475020200000010000000100CCCCCCCCCCCCCCCCCCCCC01000000011a0000616d36347800000000000000475020200000010000000100CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC01000000011a0000616d36347800000000000000475020200000010000000100CCCCCCCCCCCCCCCCCCCCC01000000011a0000616d36347800000000000000475020200000010000000100CCCCCCCC
Kind Regards,
Steffen
