MCU-PLUS-SDK-AM243X: MCU-PLUS-SDK-AM243X
Part Number: MCU-PLUS-SDK-AM243X
I am rejecting this solution this is not using standard sockets based solution. Also I have seen issues opening more than 2 sockets at a time ? Why is there a limitation on TCP sockets can you please forward me the documentation ??
Hi Dinesh,
 Good day!
 Can you please check  if below helps?
 AM243x MCU+ SDK: LwIP with Ethernet Example (ti.com)
 Please use below early availability release of our 8.1 SDK which has support for LP.
 MCU-PLUS-SDK-AM243X 08_01_00_14 - TI.com
 Please check this related e2e thread if it helps. https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1039168/lp-am243-ethernet-example-for-launchpad
 If it does not help, please consult our TI specialist by posting your inquiry using this link: https://e2e.ti.com/p/addpost
 However, we haven’t heard back so we're assuming you have found the resolution to your inquiry. For now,  I will now put this case to resolve status but you can always reject if you will be needing a further assistance.
 I hope we have helped you on your inquiry. please let us know if you will be needing any further assistance.
 Have a great day and keep safe at all times.
Jonathan Navor
Texas Instruments | Customer Support Center
