Part Number: TMS570LS3137
Hello there,
We enable ESM Group1 Channel 31 "CCM-R4F - self-test" error to have influence on the nERROR ESM output signal, therefore if the requested CCM-R4F self-test failed, the nERROR signal will be asserted to reset the MCU (hard-wired by hardware).
However, at TRM SPNU449C para. 9.3.2, it is saying that:
- During self-test, the compare error module output signal is deactivated. Any fault detected inside the CCM-R4F will be flagged by ESM error “CCM-R4F - self-test”.
- During the self-test operation, the compare error signal output to the ESM is inactive irrespective of the compare result.
Does this mean that the nERROR pin will never to activated by ESM Group1 Channel 31 "CCM-R4F - self-test" error?
Thank you!
