Part Number: TM4C1230H6PM
Hi Team,
My customer is using TM4C1230H6PM to acquire the temperature info. but it looks like the result is not the same as that measured with external temperature sensor.
Here are test results:
1) External temp sensor = 30 degrees, TM4 temp read out = 21 degrees.
1) External temp sensor = 40 degrees, TM4 temp read out = 24 degrees.
1) External temp sensor = 70 degrees, TM4 temp read out = 30 degrees.
Have you met this issue before? or do you have some suggestions to debug?
thanks a lot.
Yang
