TMS570LS3137: CAN bit rate
Part Number: TMS570LS3137
I need to know how to change the CAN bit rate on running program. I want to reduce it from 1000Kbps to 125Kbps. Is it possible?
Thanks and regards,
Leandro
  • Hi Leandro,
    To configure the CAN bit timing, you have to set both Init (initialization) and CCE (configure change enable) bits in CAN control register. When Init bit is set, the CAN module enters initialization mode, the message from and to the CAN bus is stopped.
    You can change the bit timing any time, but the current transmitting or receiving is interrupted or stopped.
