Part Number: TM4C1230C3PM
Good day. Our customer has the inquiry below about the TM4C1230C3PM.
My project use Micrcocontroler TM4C1230C3 and XTAL 8MHz, with PLL.
1) I configure SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_PLL | SYSCTL_XTAL_8MHZ | SYSCTL_OSC_MAIN);
I get value ui32SysClock=SysCtlClockGet();
ui32SysClock= 12500000; (12,5 M) (is it correct value in this situation? )
And
I configure SysCtlClockSet(SYSCTL_SYSDIV_16....
it is equal Value ui32SysClock = 12500000; (12,5 M)
When I configure SysCtlClockSet(SYSCTL_SYSDIV_4...
ui32SysClock= 50000000; (50M)
How does it configure correctly SysCtlClockSet? My question: Is it possilble PLL configure to 100MHz?
2)When I am using SYSCTL_SYSDIV_1... (12,5 M)
SSIConfigSetExpClk(SSI1_BASE, SysCtlClockGet(), SSI_FRF_MOTO_MODE_0, SSI_MODE_MASTER, 4000000, 8);
My system run with display. It is ok!
But I am using ...SYSDIV_1...(50 M) and other freq
My system doesn´t run!
Thank you for your help.
Cedrick
