Part Number: AM2432
Hi Team,
My customer has a few questions regarding reset as below.
1) I expect that if we use CortexR5F core (in MAIN domain) only, we don't have to care about starting cortexM4F core(in MCU domain). but datasheet and TRM say that system clock is supposed to be input to MCU_OSI_XI terminal and cold reset is supposed to be input to MCU_PORz terminal. Both terminals belong to MCU domain, right?
Do you have some documents that describe the relationship between MAIN domain and MCU domain?
2) Figure 5-660 High Level Reset Flow in TRM says MAIN domain start first, and then MCU domain is boot up by MAIN domain.
Why does MAIN domain have warm reset (RESET_REQz) only?
Why does MCU domain have cold reset and warm reset?
Do you have recommended reset sequence for power on?
Do you have recommended reset sequence for reset while operating?
3) Regarding datasheet p196, is there Power On Reset circuit inside AM243x? Asserting MCU_PORz at the timing shown in Figure 7-3 is needed?
Mari
