Part Number: AM2432
Hi Expert,
In our project, we need Ethernet/IP for industrial protocol communication and also need a general TCP/IP socket interface for firmware upgrade and other management purposes.
When Ethernet/IP is enabled, can the application use the standard TCP/IP socket? If not, do we have to enable both stacks, Lwip(Enet) and Ethernet/IP? and can both stacks use 2 RJ45 ports simultaneously as a switch mode?
I would appreciate it if you share your experience and knowledge on this.
Moonil
